Old 04-17-2014, 12:54 PM   #1
pizellu OP
Oddometer: 44
Smells like fuel!
Hi to all, after a very nice ride today with my new to me 1150gs, my wife commented that my clothes smell of fuel!! My sense of smell is dead so I never noticed it!! Could my 1150 be running rich? Any idea of what tweaks should I try? When starting from cold it still needs 'choke'. The 1150 is a 2001 single spark and fuel here could be the worst grade in the world! Any suggestions are welcome :)
pizellu is offline   Reply With Quote
Old 04-17-2014, 01:30 PM   #2
RFK
Oddometer: 139
Check the fuel couplers under the tank on the right side... they could be weeping fuel if the o-ring is worn or possibly a loose clamp on a fuel line.
RFK is offline   Reply With Quote
Old 04-17-2014, 08:40 PM   #3
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,844
Could be cracked tank vent hoses or the tank cap was not closed tight.
I'm now so old I forgot my last birthday. Does this make me younger?
def is offline   Reply With Quote
Old 04-17-2014, 09:54 PM   #4
teomannaskali
teomannaskali's Avatar
Oddometer: 826
First get a friend with a calibrated nose yo help you.
teomannaskali is offline   Reply With Quote
Old 04-17-2014, 10:00 PM   #5
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,198
If your fuel lines are getting old and hard they will sometimes weep/leak where they are clamped to the fuel distributor. (right side under the cover)
Start by checking there (engine running)
If so replace with 5/16" fuel injection hose SAE type R9
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 04-18-2014, 04:52 AM   #6
pizellu OP
Oddometer: 44
I have checked the fuel pipes fir leaks while engine is running, no leaks! The smell comes from the exhaust! It is running rich i guess. How do you lean the mixture?
Old 04-18-2014, 08:29 AM   #7
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,198
What is the mileage?
If you have access to a GS 911, scan it for for faults, 02 sensor, temp sensors etc.
Check the plugs, are they black or very light tan/white? Are they both the same?
Get the injectors tested for flow and shutoff
Old 04-18-2014, 09:06 AM   #8
motoree
motoree's Avatar
Oddometer: 213
Have you removed the canister recently?
If you obey all the rules you'll miss all the fun !
motoree is offline   Reply With Quote
Old 04-18-2014, 09:49 AM   #9
jdbalt
Oddometer: 196
Recall
That is the warning that they give in the recall for 2005 - later
2010 R 1200 GS
jdbalt is offline   Reply With Quote
Old 04-18-2014, 10:17 AM   #10
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,198
Wrong series of bike.
Were are talking Oilhead, not Hexhead.
Old 04-18-2014, 12:58 PM   #11
pizellu OP
Oddometer: 44
Milage is 28k km's , no access to gs911!! But I will check the plugs.. What canister you mean? Air filter? If so I changed it to a new k&n last dec when i got the bike!
Old 04-18-2014, 08:18 PM   #12
def
def's Avatar
Oddometer: 10,844
Did you overoil the K&N?
Old 04-18-2014, 08:21 PM   #13
def
def's Avatar
Oddometer: 10,844
Non US bike. No charcoal cannister.
Old 04-18-2014, 11:37 PM   #14
estlerd
TXRider
estlerd's Avatar
Oddometer: 192
Laugh Fuel lines
Remove the fuel tank & replace both fuel lines. They are weeping at the connections. Be sure to use new clamps designed for fuel injection lines.
Dave in Denton
Current
01 R1150 GS
Former
99 Ducati Monster
97 BWW F650
96 Honda CBR 600
91 GSXR 750
90 Honda CBR1000F
83 Suzuki GS1100E
79 BMW R100RS
77 BMW R75/7
more dirt bikes than I can remember
estlerd is offline   Reply With Quote
Old 04-19-2014, 03:03 AM   #15
roger 04 rt
roger 04 rt's Avatar
Oddometer: 2,371
Did you get fuel on your hands or clothes at the gas station?
roger 04 rt is offline   Reply With Quote
Times are GMT -7.   It's 02:57 AM.
