Old 04-18-2014, 09:31 AM   #1
Beezer OP
Oddometer: 5,789
1100gs transmission noise
I recently acquired a '95 1100GS with 41,000 miles. the build date is 3/94, so it should have a M94 tranny. it has pretty good maintenance records & no history of drive problems. it runs strong & shifts well, no unusual sounds when I drive it, but it has a very pronounced whirr in neutral. it goes silent when the clutch is pulled in. best guess from a pro is mainshaft bearing getting loose (tapered design). obviously the right answer is to rebuild the box with the new style bearing. ... I can't do that right now, sooooooooooooo.........
how long until it explodes? will it go with no warning?
Beezer is offline   Reply With Quote
Old 04-18-2014, 10:28 AM   #2
go4mini
Oddometer: 106
They all do that.
go4mini is offline   Reply With Quote
Old 04-18-2014, 11:16 AM   #3
Trailing Jack
Dr. Acula
Trailing Jack's Avatar
Oddometer: 1,129
Mine did the same thing.
Input shaft bearing.
Replaced the tranny with a used M97.
Trailing Jack is offline   Reply With Quote
Old 04-19-2014, 09:27 AM   #4
Trailing Jack
Dr. Acula
Oddometer: 1,129
Well I will tell you that mine did that for a year and a half until I finally got it fixed.
Input shaft bearing ,weeping seals, clutch, had to replace all kinds of things.
As I said, ended up swapping the tranny for a used M97.
Funny thing was, it ran fine, shifted fine.
The clutch didn't even slip.
Probably would have kept riding it like that except the nuetral light would only come on in 2nd gear by the time I finally bit the bullet.
It never did explode, like you say.
Here's the thread I started about my problem a while back.
Good luck.
I see I never did update that thread with the fact that I ended up swapping transmissions.
http://www.advrider.com/forums/showthread.php?t=727022
Trailing Jack screwed with this post 04-19-2014 at 09:37 AM
Old 04-20-2014, 08:14 AM   #5
Beezer OP
Oddometer: 5,789
thanks Jack.... thats the kind of input I wanted to hear. anybody else? good, bad, indifferent.... just gotta know so i can plan
like I said, seems normal, no leaks, etc... except the noise.
Times are GMT -7.   It's 12:50 AM.
