Old 04-22-2014, 06:25 PM   #1
scootrboi OP
scootrboi's Avatar
Oddometer: 1,623
Does wheel size -tire height- influence lean angle?
I would like to know more than I do about the changes in handling that occur in relation to the height of the wheels. I am good with geometry and physics.
42 years on a Heinkel Tourist
scootrboi is offline   Reply With Quote
Old 04-22-2014, 06:59 PM   #2
Al Goodwin
Al Goodwin's Avatar
Oddometer: 1,303
Smaller diameter wheels more twitchy, quicker turning...like a Vespa,,,SQUIRRLY...
Larger diameter=more stable.....
I came from the 80's, and the era of 16in. front wheels...believe me...17's are much better on the sportbikes.
Now, tire sidewall/profile is another story...depends on the tire manufacturer mote so than size...
My 1990 FZR1000 Came with Pirelli MP7 tires, the front a 130...very triangulated profile...off handling ....
Allen
2013 Yamaha Super Tenere(the new girl in town)
'06 Kawasaki KLR650(72,000+ miles)
'04 Honda XR400
'76 Yamaha TY250
Al Goodwin is offline   Reply With Quote
Old 04-24-2014, 04:38 AM   #3
scootrboi OP
scootrboi's Avatar
Oddometer: 1,623
lean angle
The Vespa rider doesn't lean over very far. Why is that?
Old 04-24-2014, 05:55 AM   #4
popscycle
Fahren Away
popscycle's Avatar
Oddometer: 1,542
If you're good with math and physics, you might glean some information from a Bicycle and Motorcycle Dynamics writeup.
Reality extends beyond the limits of our perception.
Goodbye Cruiserface, Hello Happyface!
2014 R1200GS | 2010 MX5 | BMW MOA
popscycle is offline   Reply With Quote
Old 04-24-2014, 05:58 AM   #5
Yossarian™
Deputy Cultural Attachι
Yossarian™'s Avatar
Oddometer: 9,663
Because he's riding it like a flat tracker.
Could he lean off? Yes.
Old 04-24-2014, 06:15 AM   #6
crofrog
Oddometer: 1,455
It doesn't really effect lean angles. Tire contact patch shape does and that can be influenced by the differences in tire design of different size wheels.
Smaller wheels have the following traits though:
  • Stiffer
  • Less unsprung mass and steering inertia
  • They have less gyro which allows the use of a wider (and heavier) tire with out undo effort at the bars
  • They drop farther into holes and have higher suspension velocities (and ergo more demand on the suspension) when exiting holes. This produces a rougher ride over uneven ground and reduces the tires contact with the road
  • For a given tire section (tread width) a larger wheel puts more rubber on the road. This is the trade off (smaller wheel needs a bigger tire section to produce same contact patch size, but it ends up being lighter and stiffer overall)
This list was paraphrased from Motorcycle Handling and Chassis Design: The Art and Science
crofrog is offline   Reply With Quote
Old 04-24-2014, 06:33 AM   #7
scootrboi OP
scootrboi's Avatar
Oddometer: 1,623
A quick glance through it
Gyroscopic aspect of wheels does not affect tipping. Surprise!
Old 04-24-2014, 06:39 AM   #8
klaviator
klaviator's Avatar
Oddometer: 6,365
Size of wheels doesn't affect lean angle for a given speed and curve. However, scooters with small wheels usually have limited cornering clearance which limits how far you can lean before scraping hard parts.
As far as handling in general, smaller wheels tend to result in easier & quicker reactions to steering inputs. Bigger wheels = slower & more stable steering. Riders who are used to more stable bikes tend to think of small wheel scooters as twitchy and unstable. Personally I like prefer to think of it a quick and responsive.
I have a scooter with 14" wheels. Fairly large for a small scooter but small compared to a motorcycle. I think the overall handling and steering is fantastic. However, lack of cornering clearance doesn't allow me to take advantage of that fantastic steering & handling on a twisty road.
I ride, Therefore I Am.
klaviator is offline   Reply With Quote
Old 04-24-2014, 06:52 AM   #9
crofrog
Oddometer: 1,455
That's only indirectly related to the wheel size though. They could have built the rest of the bike higher or with greater clearance. Of course, then you'd have to have it be narrower (or taller) both of which would mean you couldn't step through like a scooter.
Old 04-24-2014, 07:44 AM   #10
Rgconner
Oddometer: 1,455
Having owned:
P200 10"
Vespa GTS250 12"
75 Honda CB550 18"
12 BMW F700GS 19"
The most nimble of the bunch is the P200, not twitchy thanks to a good front end shock. (actually better than on any of the bikes)
the CB550 is the most stable
The GTS250 is the most twitchy
BMW has the most neutral handling, not as stable as the CB550, but not twitchy.
Rgconner is offline   Reply With Quote
Old 04-24-2014, 01:59 PM   #11
klaviator
klaviator's Avatar
Oddometer: 6,365
There are other factors besides wheel size but most scooters have a CVT and the engine & drivetrain is all part of the swingarm.This means that the back of the CVT at least is centered on the rear axle and sticking out the side. With a small wheel it is going to compromise clearance on that side. I rode behind a guy riding a Buddy 125 once on a twisty road. His CVT cover was close to touching the ground in every left hand turn. It made me nervous to watch. The buddy has 10" wheels.
Go to a scooter shop some time and look at how much clearance they have. Generally speaking bigger wheels = more clearance and small wheels = poor clearance.
Old 04-24-2014, 03:28 PM   #12
scootrboi OP
scootrboi's Avatar
Oddometer: 1,623
Leaning this scooter over till the floor hits is routine for removing wheels. The floor hits first. I can't imagine leaning this far while in motion.
Old 04-24-2014, 07:53 PM   #13
klaviator
klaviator's Avatar
Oddometer: 6,365
I believe your scooter is different from most modern scooters by not having a CVT or swingarm mounted drivetrain. That makes a big difference.
Also, keep in mind that if you were on the scooter, suspension would compress and your actual cornering clearance is less than in the pic.
Old 04-25-2014, 12:46 AM   #14
Pecha72
Oddometer: 4,061
" if you were on the scooter, suspension would compress and your actual cornering clearance is less than in the pic"
Exactly.
And furthermore, if you hit some potholes or bumps mid-corner, when leaned over, it all gets even more complicated.
Countries ridden • FIN • SWE • NOR • DK • EE • LV • LT • POL • SK • HU • RO • BG • GR • IT • AT • DE • CZ • CH • SMR • LIE • NL • BE • FR • AND • ES • GBR • LUX • SI • HR • BIH • SRB • MK • TR • IR • PAK • IND • TH • KH • LA • MY • ID • AUS • CR • USA • ZA • LS • SWZ • MZ • NA • BW • ZM • ZW
Pecha72 is online now   Reply With Quote
Old 04-25-2014, 04:19 AM   #15
outlaws justice
outlaws justice's Avatar
Oddometer: 1,150
This is more complicated than that.
Tire size (Width and height and circumference) are all calculated to provide the bike with certain dynamics and changing the size of a tire will effect the bike in several ways. It can effect the rake and trail of the bike therefor effecting the steering geometry either positive or negative depending on what changes you make and how the bike was designed to handle and which way you make the change. Changing a tire profile can also effect the ground clearance even if it is minimal. Changing the profile can also effect the bike and how it turns in. does it turn in slow and take a lot of effort to steer or is it twitchy and turns in quick. If you have problems you can sometimes change the problem by changing the brand of tire to a tire with a different shape, or changing the size profile of the tire you are using.
Tire width can impact the size of the contact patch as well. Some people may believe that a wide tire will give you a bigger contact patch, but this is not usually the case either, as you are putting a wider tire on the same width rim and doing so makes the tire bend more to fit the rim and can actually have the reverse effect you might be looking for.
There is a lot involved when we start talking tires and the effects on the motorcycle, it's geometry and traction. I would be happy to discuss further but we could go on for days.
David
2005 KTM950 Adventure, 2007 BMW K1200GT, 2005 Yamaha Vmax, 2005 Suzuki SV650S, 1991 Honda VFR750, 2004 Honda CRF250X, 2000 Buell Blast................
outlaws justice is offline   Reply With Quote
Times are GMT -7.   It's 03:42 AM.
