Old 05-09-2014, 08:34 AM   #31
mattness
mattness's Avatar
Oddometer: 48
honda shadow with fuel injection makes 37. i think the older ones are more like 32.
http://www.mcnews.com/mcn/technical/2013JanPerfIndx.pdf
mattness is offline   Reply With Quote
Old 05-10-2014, 01:03 AM   #32
ZZ-R Rider
Captain Fantastic
ZZ-R Rider's Avatar
Oddometer: 687
I'm sure the Shadows do better than 32HP?? ... Suzuki's LS650 does 28-30HP; I've owned both and even with the extra bulk, the Shadow seems like it has more grunt & top end than the Savage/S40 ...
Before you diagnose yourself with depression or low self esteem, first make sure that you are not, in fact, just surrounded by arseholes ...
ZZ-R Rider is offline   Reply With Quote
Old 05-10-2014, 05:40 PM   #33
frog13
frog13's Avatar
Oddometer: 1,346
Originally Posted by theloop View Post
Had a 2003 750 ACE, in 2004 Honda replaced it with the Aero. I liked the ACE much better, it had 2 carbs, the Aero only had one, and the ACE was chain drive and I replaced the 41 tooth rear sprocket to a 38 tooth sprocket.
It was a decent little bike, but I like my CB500x much better.
Why do you like the CB500X better ?......eventhough it has shimmed valves and the Shadow has screw type valve adjustments . TIA
frog13 is offline   Reply With Quote
Old 05-11-2014, 05:27 AM   #34
kraven
Hegelian Scum
kraven's Avatar
Oddometer: 4,824
Originally Posted by hexnut View Post
This website list carb as 43, FI at 44 and dyno rear wheel HP at 38.3.
http://www.vt750dc.com/factory-specs/vt750c2
Chain vs shaft drive makes a significant difference in wheel hp too. And you can fiddle with sprocket ratios on the chain whereas shaft leaves you with what you got.
So there I was walking into a biker bar in Chattanooga with liberty spikes on my head and a drag queen beside me... - bcurvin
kraven is offline   Reply With Quote
Old 05-11-2014, 05:35 AM   #35
kraven
Hegelian Scum
kraven's Avatar
Oddometer: 4,824
The RS is chain drive.
Times are GMT -7.   It's 05:15 AM.
