Old 04-25-2014, 06:52 AM   #1
96R1100GS OP
96R1100GS's Avatar
Oddometer: 64
Dealing with deer
I livein rural Virginia and have just gotten back into motorcycling. I have hit two deer with my car and am worried about hitting one on the bike. The only solution I can come up with is to slow WAY down when on a back road where deer may be lurking. I do kill and eat them too. Any thoughts?
Sent from my SCH-S968C using Tapatalk
96R1100GS is offline   Reply With Quote
Old 04-25-2014, 07:02 AM   #2
packerbacker
packerbacker's Avatar
Oddometer: 201
you need to buy one of these:
http://www.advrider.com/forums/showthread.php?t=948701
and two of these:
http://stores.advmonster.com/model-3...ad-spot-light/
braaaaaaaap
packerbacker is offline   Reply With Quote
Old 04-25-2014, 11:30 PM   #3
TexaNate
TexaNate's Avatar
Oddometer: 398
Ride slower - that's the only thing that's guaranteed to help. Avoid dawn and dusk as well, and ride especially slowly when you're near woods or blind shoulders.
Deer whistles are $6 a pop. When you think about it, if they only have a 1% chance of saving you $600 (and/or a .1% chance of saving you $6,000), they're worth the investment.
2014 690 Enduro R
TexaNate is offline   Reply With Quote
Old 04-26-2014, 12:12 AM   #4
GBAUTO
Bambi Assassin
GBAUTO's Avatar
Oddometer: 110
I don't think that there is any guaranteed way to prevent from smacking 'Bambi' while riding. They are all over the place where I live and I have had an encounter with a kamikaze doe on the SV. It was about 30 minutes after sundown and she bolted directly in front of me in a blind corner.
I don't ride after dark anymore-that's the only way I can increase my odds because I have a better chance of seeing them and making some evasive actions.
Best advice I can give is to kill all of them...with extreme prejudice.
Spending my time exploring the woods and carving the corners of N. GA/ W. NC
'12 KLX250(351)S
'06 GSXR1000
'03 SV1000S
GBAUTO is offline   Reply With Quote
Old 04-26-2014, 12:16 AM   #5
bananaman
transcontimental
Oddometer: 7,558
Lights! Bright lights. It's easy to wire a set of PIAA's and a set of Hella's. I always used to have the Hella's aimed to brighten the shoulders, and the PIAA's to brighten the road. The 1100GS has more than enough alternator power to keep up with the load.
I wired mine on a fused relay directly to the battery, with separate handlebar mounted switches. I used the headlight as my simple On through the relay.
You can make a light bar with a $15 piece of aluminum stock. There are two screws under the headlight assembly on your GS. Perfect for mounting the bar. Just try to keep the lights close enough to the center of the bike so that when you drop the bike, the crash bars protect them.
I had great luck with these lights, until I changed the relay and had them turn Off with the Dim switch.
From now on I'm leaving them On unless I'm in heavy traffic. In heavy traffic I'll turn off the PIAA's.
I am Charlie.
bananaman is offline   Reply With Quote
Old 04-26-2014, 05:29 AM   #6
manic mechanic
manic mechanic's Avatar
Oddometer: 161
I've hit 3 deer with bikes, hopefully no more. All were in daytime. ATGATT helped. but broken bones still can happen. The critters can come out of anywhere besides forests, such as overgrown ditches, farm fence rows, etc. Be aware, not paranoid. Keep scanning using peripheral vision for movement. And remember, if you see one, look for others. Right now is a good time to see deer moving, as they're starting to drop fawns. The worst time is in fall, during the rut and when harvesting is occurring. Best advice is to just keep on the lookout.
And it's not just out in the woods and farms, we have deer strikes here in town. I've had close calls on a 4-lane residential boulevard.
'76 R90/6, '07 K1200GT
Rounder #6
MOA Ambassador
RA WI Regional Rep
manic mechanic is offline   Reply With Quote
Old 04-26-2014, 05:32 PM   #7
Balootraveler
Balootraveler's Avatar
Oddometer: 348
Bright lights and ride slower, deer are out anytime day or night just be aware of the ambush spots.
If I grow up I'll be taller.
Balootraveler is offline   Reply With Quote
Old 04-26-2014, 05:40 PM   #8
Auto-X Fil
Oddometer: 662
Scan the woods and slow down. That's all you can do, other than bright lights if your stockers are a little weak. I whacked one last summer - I was going slower than normal because it was prime deer time and location, so I bumped it without going down. It only cost me $300 in plastic. Another 10-20mph and to could have been much worse.
Auto-X Fil is offline   Reply With Quote
Old 04-26-2014, 06:44 PM   #9
khager
Oddometer: 985
Yeah, we have had some deer strikes in town too. Damn things are everywhere!
What I don't understand is why deer hunting is so regulated. It should be open season, year round with no limits. Not looking to make them extinct, just get their #'s down to a maneagable size. There are more around now, than before the first Europeans arrived, many moons ago.
khager is offline   Reply With Quote
Old 04-26-2014, 07:05 PM   #10
ThatGuy
Brownie
ThatGuy's Avatar
Oddometer: 5,172
After riding up here and then riding in the midwest I am not used to scanning for them. Almost took one straight one a few years ago, lucky for me he moved at the last second. On the other hand we have moose and I have learned to scan now.
Disclaimer: The writer does not represent any organization, employer, entity or other individual. The views expressed are those only of the writer. In the case of a sarcastic, facetious, nonsensical, stirring-the-pot, controversial or devil's advocate-type post, the views expressed may not even reflect those of the writer.
ThatGuy is offline   Reply With Quote
Old 04-26-2014, 09:05 PM   #11
Flynch
Oddometer: 168
I've hit two on a motorcycle, (and I quit counting in four wheeled vehicles,) I live in old abandoned farm country which are now thick wooded baited deer farms.
Lights, Lights, Lights and learn the deer routes, for 20 years the deer on my farm have followed the same routes, crossed at roads, followed the same paths and bedded down at the same times, and changed those times only during weather changes...and deer never travel alone, if there is one, there's probably three.
Watch where the out of town hunters bait deer to, deer will change their pattern for the sweet flavored baits and grass seed they use to draw the deer to their stands.
But all of that goes out the window during rut. Both deer's I hit were during rut, both in areas where they usually didn't cross, both at full speed run. One daylight, one early evening; Actually rut had started a few weeks earlier and I noticed the deer's changing patterns but it was bow hunting only and the deer were not panicked, but once gun season started, the deer started running. I should have waited a few weeks to ride after the majority of gun hunters had gotten their Bucks, and the deer would have settled back into their usual activity.
Lights.
ATGATT
Rotten eggs mixed with hot pepper will keep them out of your gardens and seedlings.
atlasflynched.blogspot.com
Flynch is offline   Reply With Quote
Old 04-26-2014, 10:08 PM   #12
Homey
Homey's Avatar
Oddometer: 596
You guys have it all wrong. It's really the government that's behind the rash of deer attacks. Clandestine government agents hide in the bushes with sophisticated, top secret, deer cannons and wait for unsuspecting motorists to drive by. When least expected they shoot deer at them with alarming speed. It's big brother at his worst!! Protect yourself!
btw, we've tried rotten eggs/hot pepper and a litany of other home made anti-deer recipes and they still eat my wives plants. If they are hungry they'll eat anything. The Rottweiler is the only thing that keeps them out of the yard now...
Homey is offline   Reply With Quote
Old 04-26-2014, 10:40 PM   #13
Veteran Noob
Unremarkable
Oddometer: 417
I don't know why but 4 or 5 years ago (after 25 years of riding) I developed an overwhelming fear of hitting a deer. I understand the risk, and have always understood the risk but I now have this primal fear, completely disproportionate to the actual risk; to the point of being irrational (degree of fear, not the actual respect for the risk). Just sitting here thinking about and my mouth goes dry, my stomach turns and I get that super antsy feeling, like I've downed about a dozen red bulls. I'm convinced if I ever buy the farm on a bike it will be due to a deer strike. I can deal with it (though I wish it would pass), I've given up riding from dusk to dawn, but I hope it doesn't progress to other potential dangers.
If you're not part of the solution, you're part of the precipitate.
Veteran Noob is offline   Reply With Quote
Old 04-26-2014, 11:19 PM   #14
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
I prefer to blind the bastards.
Danjal is offline   Reply With Quote
Old 04-27-2014, 07:09 AM   #15
DAKEZ
DAKEZ's Avatar
Oddometer: 19,739
Wheelie over them.
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Times are GMT -7.   It's 03:15 AM.
