Old 04-25-2014, 08:00 AM   #1
toates89 OP
Oddometer: 286
Push Pull Cable
I have a dr350 and the throttle wont close while off and will while running. After pulling the cables i notice the push cable creates just enough friction to cause me some issues.
Ive read that many just remove it. I was wondering does anyone disconnect and leave it there incase their original cable snaps they could re route the push to be a secondary pull cable?
toates89 is offline   Reply With Quote
Old 04-25-2014, 08:34 AM   #2
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,764
Sometimes too much tension between the two cables can cause an issue. Try putting a little slack into the close cable and see if it helps.
Old 04-25-2014, 01:47 PM   #3
ttpete
Oddometer: 6,039
It's all too easy to create a binding condition by misadjusting the cables. Both cables pull, there's no pushing involved.
Start by slacking off the closing cable. Then adjust the opening cable so there's minimal slack when opening the throttle. Now, adjust the closing cable so there's just a little slack in it. That way, neither cable interferes with the other. The only reason the closing cable is there is to provide positive throttle closure in case a return spring fails or something binds up. Otherwise, it serves no function and just goes along for the ride.
Old 04-25-2014, 04:30 PM   #4
JohnCW
Oddometer: 1,361
Before you consider whether to disconnect it or fix it so it works properly, ask yourself why the original manufacturer put it there in the first place. Was it:
(a) he had an excess number of cables in stock so needed to use em up,
(b) was being considerate by supplying a spare.
(c) thought 2 cables looked cooler than one.
(d) fitted it as a safety device to pull the throttle shut in the slim chance the return spring snapped or opening cable jammed.
JohnCW is offline   Reply With Quote
Old 04-25-2014, 05:48 PM   #5
Hesaid
Hesaid's Avatar
Oddometer: 1,394
It's "C" isn't it?
What do I win?
MV
DR Feelgood , Tipsy Wombat, Pinkfoot, FatCat, and how they got their names: What the hell is a wombat? And now, the tales of their adventures.
Hesaid is online now   Reply With Quote
Old 04-25-2014, 09:50 PM   #6
ER70S-2
ER70S-2's Avatar
Oddometer: 6,920
Pull open, pull closed.
+1
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 04-25-2014, 11:14 PM   #7
REALGRAVEROBBER
LEAVING GRAVES EMPTY
REALGRAVEROBBER's Avatar
Oddometer: 366
In my humble opinion, I have found:
Keeping things very close to stock causes LESS problems.
Maybe you adjust your fuel idle mixture, get the carb changed for your altitude, but overall KISS (Keep It Simple Sweetheart).
The previous posters are right on about been careful to make some slack between the cables to they are not binding the assembly. I've also had good luck with taking the whole throttle assembly apart and wash it in hot soapy water (dishwashing soap works well). Clean plastic is slippery.
Also, worn-out throttle cables will have some drag in them as the plastic liner-friction bushings wear out and the cables rub against metal at some internal aspect. Sometimes new (or less used, ie from eBay used) will cure the sticking or dragging throttle. I've fixed a few bikes that wouldn't allow the throttle to return unless the handlebars were turned just so and the throttle would snap back closed ... due to the throttle cables being worn out and friction happening inside the cable liners at certain angles.
After a lot of hours trying to fix a lot of my own and customers bikes ...
that is my $0.02 :)
We have a lot to do with how the world receives us.
Dr. Frazier Writing
REALGRAVEROBBER is offline   Reply With Quote
Old 04-26-2014, 03:56 AM   #8
dovetailredux
Oddometer: 74
You might also try lubing the cables.
dovetailredux is offline   Reply With Quote
Old 04-26-2014, 05:27 AM   #9
markk53
jack of all trades...
markk53's Avatar
Oddometer: 9,013
I've often wondered if they felt it wasn't needed on all those two strokes why was it suddenly needed on all the four strokes? I haven't removed either of mine, but it does make one curious. Even the ATVs with the thumb throttles on virtually the same bikes use one cable on slide and CV carbs.
Just makes you wonder... Of course if you did have the throttle kind of jam or want to stick open the pull-return will definitely be of value, should that "lightning strike" happen.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens!
Mark - klx678
95 KLX650C w/Vulcan piston bigbore, Now an 09 KLX250S, selling my 90 Zephyr 550
markk53 is offline   Reply With Quote
Old 04-26-2014, 05:38 AM   #10
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,764
My brother had the throttle stick open on his Ducati monster. The internal sheathing of his cable pulled out and wedged itself in the throttle mechanism. He was doing a track day at the time and got stuck at WFO. Bit of a pucker moment to pull the clutch and find the kill switch.
Bet he wished his duc was equipped with a pull to close cable.
Old 04-26-2014, 04:49 PM   #11
lnewqban
Ninjetter
lnewqban's Avatar
Oddometer: 291
Cool2
I have a dr350 and the throttle wont close while off and will while running. After pulling the cables i notice the push cable creates just enough friction to cause me some issues..............
Bowden cables can cease to function smoothly, particularly if water or contaminants get into the housing.
Unless one (or both) of the cables is fraying, proper service (cleaning plus lubrication) will reduce excessive friction between:
1) Cables and housings.
2) Right handle and handlebar.
3) Butterfly valve's pivot and bushings.
lnewqban is offline   Reply With Quote
Old 04-27-2014, 05:17 AM   #12
markk53
markk53's Avatar
Oddometer: 9,013
Bowden what? I'm sorry, that's too in-depth for understanding on the ADVrider forum... You will have to dumb it down more...
Mark - klx678
Old 04-27-2014, 07:21 AM   #13
JohnCW
Oddometer: 1,361
You might have time to reach for a kill switch on the track and get away with just a big scare, but on the road with far more 'deadily' objects a stuck open throttle may have you in serious trouble way before our slow brains can figure what has happened and what do we need to do to deal with it.
Old 04-28-2014, 10:38 AM   #14
toates89 OP
Oddometer: 286
I am currently running one cable for now.
Old 04-28-2014, 11:13 AM   #15
markk53
markk53's Avatar
Oddometer: 9,013
Or get their gas pedal unstuck from the floor mat...
Mark - klx678
Times are GMT -7.   It's 08:51 PM.
