Old 05-30-2014, 05:41 AM   #16
davesupreme
grand poobah
Oddometer: 1,466
excellent report!!!... this is real racing, grassroots style effort.... put it together, let's see what happens?....
really enjoying it, keep it coming!!.....
davesupreme is offline   Reply With Quote
Old 05-30-2014, 03:44 PM   #17
dmcd
dmcd's Avatar
Oddometer: 570
Nice, to meet you this evening, how did practice go?
dmcd is offline   Reply With Quote
Old 05-30-2014, 06:24 PM   #18
canoli
human
canoli's Avatar
Oddometer: 1,669
Hay man we need some eye candy. Post up some pics of the bike!
Canoli
canoli is offline   Reply With Quote
Old 05-31-2014, 04:19 AM   #19
Buckeye56 OP
Batoutahelius
Buckeye56's Avatar
Oddometer: 202
It started off really well but didn't turn out so hot. A one point Rob was averaging better than 97 MPH. But the battery pack power dropped off and slowed him sown to 89 and change. We are discussing options as I type. I will let folks know how things are going.
2012 Super Tenere
Trying is the first step towards failure.
Buckeye56 is offline   Reply With Quote
Old 06-01-2014, 02:24 AM   #20
Buckeye56 OP
Batoutahelius
Buckeye56's Avatar
Oddometer: 202
We have decided to reconfigure the battery pack where the batteries failed in Fridays practice to improve cooling flow through that section of the pack. We did pack spares in the crate with the bike so the biggest issue is getting them charged up so we can bring the final balancing for the race. We skipped yesterday's practice as the bike is in pieces in the paddock. So there may not be much more news in the next few days. Oh, and the power switch on the main battery charger has failed! Fortunately one of the other bike teams let us use their charger and since we use a different piece of equipment to do the balancing so we are OK assuming nothing else goes wrong!
Rob had a rough SuperBike race yesterday. He had chunked the rear slick in the Friday practice and was not happy about it. In the race, the tire chunked again but the bigger problem was the chain failed tearing up the sprocket, wheel and rear tail of the bike. It looks like it came real close to hitting him too which would have been much worse!
2012 Super Tenere
Old 06-02-2014, 12:47 AM   #21
Buckeye56 OP
Batoutahelius
Buckeye56's Avatar
Oddometer: 202
Today folks got to sleep in a bit as we were still determining the best course of action and sourcing materials to complete repairs to RW-2.x. We did have two more set backs. Both the high power charger and the one used to balance the pack have failed. On the high powered unit it looks like the on/off/breaker switch failed, the balancing charger did not show any obvious problems, it just stopped working. In a turn of good luck, ARC EV from the UK had exact copies of both of our chargers with the proper plugs and generously loaned them to us! Thanks guys! We charged the bussed part of the pack as high as we could and then started peaking up the replacement cells to the same level. Then balancing began. I was told this morning that it appears the replacement cells can be charged to a higher level than first thought. Every bit of energy we cram into the cells is a very good thing.
Modifications to the upper pack frame continue to accommodate the change in orientation of the cells. Final calculations are in progress to determine the best gearing to run on Wednesday. I don't understand the dynamics of the vehicle well enough to explain the choice options but it comes down to limiting top speed such that we do not run out of energy before the end of the race. Need less to say, there has been much lively discussions on this topic the last few days!
Monday we need to make a parts run early since the course closes at 10am. We hope to find a new switch for the Manzanita charger, a new PL8 (used for balancing) and some fasteners ended to finish the upper pack mods. Then it is back to beating RW-2.x back into racing condition. Wish us good luck!
2012 Super Tenere
Old 06-02-2014, 12:50 AM   #22
Buckeye56 OP
Batoutahelius
Buckeye56's Avatar
Oddometer: 202
Canoli
See Picts here:
www.current.osu.edu
Click on the photos link. There are shots of both last year and this year's version of the bike. Enjoy!
2012 Super Tenere
Old 06-03-2014, 02:14 PM   #23
Buckeye56 OP
Batoutahelius
Buckeye56's Avatar
Oddometer: 202
Yet another busy day at the TT. The electrical team has bussed, charged and balanced the reconfigured battery pack and sorted out an issue with the rider display. We want to make sure Rob is able to monitor the energy in the pack so that he can go as fast as he can while not running out of juice before the finish line. Tonight they will be tweaking the data acquisition system.
The mechanical team modified and installed the covers on the packs, reinstalled the front wheel and did the final tightening and safety wiring of the fasteners. One of the things that had been the center of discussion for the past few days was what gearing to run. After crunching numbers and analyzing mounds of data, we pretty much took a WAG and threw a 40 tooth sprocket on the rear wheel. Actually we talked it over with Rob and he agreed with our choice.
So tomorrow we need to put the fairings on and go racing! We have serious competition for third from Sarolea, a team from Belgium who have made a beautiful machine that looks like a vintage cafe racer. As you might imagine, we are all getting just a wee bit nervous! Many will be glad once it is over and we know how well we did!
Once more I want to say how proud I am of the team. This year has been one problem after another and even though they were bummed out at times, they pulled together and refused to quit. They are the best!
2012 Super Tenere
Old 06-03-2014, 04:35 PM   #24
dmcd
dmcd's Avatar
Oddometer: 570
Good Luck!
Old 06-03-2014, 07:35 PM   #25
BOOTLACE
Bikie Scum.
BOOTLACE's Avatar
Oddometer: 3,891
For sure! Hang in there.....!
bootlace
BOOTLACE is offline   Reply With Quote
Old 06-04-2014, 02:12 AM   #26
Fast_Boy_Slim
Don't call me Wighty
Fast_Boy_Slim's Avatar
Oddometer: 3,046
Some great coverage on the TV last night. Bruce Ansty was saying he was really impressed by the power of the Mugen. They also featured a lovely looking bike built by a Belgian guy. Maybe it will be your turn tonight?
go steady and don't forget to say hello to the fairies!
Go Jane Go
Treat your throttle and brakes like a pair of b**bies! You go grabbing them hard and you're going to get slapped. You want to massage them nice and smooth. That way the bike will kiss you. Chris Carr
Fast_Boy_Slim is offline   Reply With Quote
Old 06-04-2014, 04:02 AM   #27
canoli
human
canoli's Avatar
Oddometer: 1,669
Listening live. Cool stuff.
Old 06-04-2014, 09:35 AM   #28
Buckeye56 OP
Batoutahelius
Buckeye56's Avatar
Oddometer: 202
June 4
So after months of design, fabrication and fighting with multiple battery and equipment failures, today we battled Team Sarolea the entire 37.73 miles of the famed Mountain Course. They started 10 seconds before us and Rob chased them the whole race and in the end we pulled out third place by a scant .037 seconds! The winners circle was kind of awkward as the stewards waved Sarolea in instead of us.it took about 5 minutes for race control to correct the finishing order. The problem was Sarolea's transponder was intermittent and no one was sure who was third until they reviewed the finish. Once again we were drinking champaign in the late morning, hugging, taking turns wearing the wreath and feeling relived that we were able to back up our podium finish in 2013. Props to Rob Barber for riding the wheels off RW2.x and bringing home another trophy! We ran the race in 24 minutes 12.23 seconds with an average speed of 93.531 mph. That is a little ore than 2 mph faster than what we ran last year.
Now we begin planning on next year's bike. We would love to come back to the TT to see if we can improve on the results we archived this year.
2012 Super Tenere
Old 06-04-2014, 09:37 AM   #29
dmcd
dmcd's Avatar
Oddometer: 570
Kind of funny watching it go past a petrol station
Old 06-04-2014, 09:49 AM   #30
spezjag
spezjag's Avatar
Oddometer: 8,358
Congratulations to Team Buckeye!
Gary
Only a motorcyclist knows why a cheetah hangs its head out the window. - Peterman
http://m.youtube.com/watch?v=DZ6jy8o...ure%3Dyoutu.be
spezjag is online now   Reply With Quote
Times are GMT -7.   It's 06:38 PM.
