Old 06-05-2014, 12:23 AM   #1
MNzach OP
MNzach's Avatar
Oddometer: 12
CT90 big bore...
Alright I've got a 77 ct90 and was thinking about getting the dr. atv big bore and cam to give it a little bit more get up but then I saw this http://www.ebay.com/itm/110cc-Kit-Bi...p2054897.l4275 Has anyone used this one instead? It would be easier than having the old one bored out and I could always go back to it if I didn't like the new one.
MNzach is offline   Reply With Quote
Old 06-05-2014, 08:41 PM   #2
fullmetalscooter
Let me take this duck off
fullmetalscooter's Avatar
Oddometer: 2,923
From my reading here most rather go to dr.atv and do an engine change out by getting one of the kits they sell . That way you end up with a replacement engine to save or sell.
Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting WHAT A RUSH, WHAT A RIDE.
"Life is a tragedy when seen in close-up, but a comedy in long-shot." Charlie Chaplin
fullmetalscooter is offline   Reply With Quote
Old 06-06-2014, 01:29 PM   #3
SRG
SRG
SRG's Avatar
Oddometer: 1,255
If you swap out the motor (for a non original one) you loose the dual range transmission - which is a big part of the CT's appeal.
I did the DRATV big bore, performance cam & 22mm carb to my '75. I'm happy w/ it but for the price of that ebay big bore kit, I might have done that instead. You'll still want the Dr's cam and a 22mm carb.
Lazy Traveler
SRG is offline   Reply With Quote
Old 06-06-2014, 05:39 PM   #4
MNzach OP
MNzach's Avatar
Oddometer: 12
Yea, the dual range is the main reason I haven't just swapped a Lifan into it. I think I'm gonna give this a shot whenever I get free time again. If I don't like how it works I can always put the stock cylinder back in.... but I doubt that would happen.
Old 06-11-2014, 05:37 PM   #5
oldxr
oldxr's Avatar
Oddometer: 1,134
The dratv piston is 53mm or 54 mm.That kit has a 52 mm cylinder.The head gaskit in that kit does not look correct for a ct90.If you make the engine bigger you will have to rejet the oem carb or get a new carb+ possably do some jetting work.I have a 1969 sl90 with the dratv 54mm piston+cam .The engine had a 22mm carb oem.My jetting is 92 main 38 pilot.With the 54mm piston you get 104cc.With a 52mm piston you will get 96+cc.The ct90 engine needs more stroke.I am working on a 125cc+ engine using a atc125m crank.The air intake in the rack is restrictive.The easiest hop-up I ever did on a ct based bike was a ct110.I removed the rubber boot from the rack and the baffle from the muffler.Then I put in a bigger main jet.The owner was very happy.
oldxr is offline   Reply With Quote
Old 06-30-2014, 03:02 PM   #6
MNzach OP
MNzach's Avatar
Oddometer: 12
Thanks for the info! I didn't make the connection to the different size compared to the dratv piston. I'll have to do some more research before I do anything.
Old 09-02-2014, 07:53 PM   #7
injuhneer
injuhneer's Avatar
Oddometer: 21
So what did you finally do? I am working on a 146cc dual range motor for my ST-90. The thread is over in the "Old's Cool" forum.
Mike O in AZ
1974 ST-90 FrankenHonda
1984 Yamaha TT600(L)
injuhneer is offline   Reply With Quote
Times are GMT -7.   It's 01:10 AM.
