04-29-2012, 09:33 AM
#2626 | |
Parallel Reality
Oddometer: 683
Yeah, happy to help. Thanks. Here is a pic of the needle spacer/washer sequence. It was a bit of detective work as the bike had dynojet needles in it when I first opened it up. I believe this is the correct sequence though. The large metal washer underneath the plastic spacer is a friction fit and holds the plastic piece snug to the clip. There's also (not in the pic) a small metal washer that I put on top of the clip to act as a smooth bearing surface for the plastic insert that fits in the spring. Also, two of the four old shaft seals which stiff and slightly formed compared to the new ones which are pliable. Also, an original throttle plate screw and a new allen one for comparison. Hope this helps and yeah, a post on how it comes along would be good. Cheers, Rich
AdvRich screwed with this post 04-29-2012 at 09:36 AM Reason: hehe, forgot pic |
04-29-2012, 09:35 AM
#2627 | |
Parallel Reality
Oddometer: 683
Cheers, Rich |
04-29-2012, 06:24 PM
#2628 |
Parallel Reality
Oddometer: 683
Starkmojo, I forgot to mention about your reference to SW Motech rack. I don't have the rack, but I do have the pannier mounts if that's any help with installation info.
04-30-2012, 01:24 PM
#2629 |
Hail Eris!
Oddometer: 78
New Bike!
Picked me up a purty, new (old ass) tdm a couple weeks ago and finally got some proper pictures this weekend. Loving this bike so far. I've had this thread bookmarked for like 3 years, now I finally get to use it. Threw some brand new shinko 705's on it after a long tire search and they seem awesome.
05-01-2012, 11:21 AM
#2631 |
Oddometer: 4
05-01-2012, 01:41 PM
#2632 |
Chief Totberry
Oddometer: 201
I got them on. I was just irritated at the lack of directions in English. I also thought that the lack of a longer bolt for the mount that attaches to the exhaust mount was short sighted and frankly kinda dangerous. With the stock bolt only about 1/2 the threading of the nut is being used. This means the nut is more likely to come of and the bolt is more prone to shearing.
05-01-2012, 02:44 PM
#2633 |
Parallel Reality
Oddometer: 683
The bolt was too short on the muffler side on mine too with the Staintune. I bought a longer allen bolt and self locker nut. The other side worked out good without the muffler tab. The rear tab bracket uses the plastic fender and license plate as a mount point and it's a bit jiggly. At some point, I'd like to modify it so it is beefier for some of the longer gravel/dirt sections I'd like to run. |
05-01-2012, 11:31 PM
#2634 |
Chief Totberry
Oddometer: 201
I had to remove the lisence plate holder and drill new mounnts into the rear fender to make it work on my bike. The aftermarket plate holder that came with my bike did not have the right spacing. Also they are not shitting about the loctite- I drove 100 miles on pavement without loctite ( I didnt have any on assembly day and once I knew I would have to take it apart again anyway for the exhaust bolts I figured I might as well figure out how to put the damn thing together) and half the bolts were looser!
![]() For the exhaust I used flanger 8mm x 1.25x 50mm with self locking nuts- pretty much exactly the same as the ones already there but longer. I could shorten them a little but I saw no interference so I suspect that shortning them will go on the "sure I will get to it someday" list of things to do... it is a pretty long list. The other thing I would never have figured out is the use of the little circlips if I didnt have a complete set that came with the boxes. They attach to keep the quick releases from flying off should they ever dissengage. Bet it would suck to have to find a small black bolt on tarmac somewhere- probably at night too with my luck. I just think a diagram with some directions or even just some pictures would be great. I spent a good hour just getting the orientation down before starting installation. |
05-03-2012, 09:58 PM
#2635 |
Oddometer: 26
05-04-2012, 09:44 AM
#2636 |
Oddometer: 4
Hello rackam_le_rouge, thanks for your reply... I'm talking about some problems in the instalation itself, any kind of troubles... the projector went well? Did you had to make some hole? Is it really plug and play? Thanks once again... :)
05-05-2012, 10:39 AM
#2637 |
Oddometer: 26
Hi Zeribas
Viewing this tutorial from the TDM Greek forum. --> http://www.tdmhellas.gr/smf/index.ph...&topic=18712.0 |
05-06-2012, 12:08 PM
#2638 |
Oddometer: 173
oe key code
curious if i could get from someone, the key code from a stock key and the tag code from the ignition cylinder. from a 93 model year. I need it for a code starting point.
![]() i'm trying to get new keys made. the key that came with the bike is a toyota key. it does not engage the steering lock tumblers. so, at some point a previous owner lost the original key and made something work. ![]() thanks in advance!!!
i wanna ride
05-07-2012, 02:05 PM
#2639 | |
Oddometer: 4
05-09-2012, 02:52 AM
#2640 |
Oddometer: 519
Oil change
Did my first oil change on my 2002 TDM today. Previous owner had overfilled it, I presume because he didn't understand how to check dry sump bikes. However, I must admit to being a bit confused too, the manual says "total amount 4.7l, without filter 3.8l, with filter 3.9l". It's usually another 100ml when you swap the oil filter, so my bet was on 3.9l. Bloody ambiguous though
. Maybe the previous guy assumed he had to put in 4.7l?Now, on the checking procedure, I took the bike for a 15 min ride, turned off and let it sit for a few minutes before checking. My query is how long can I leave it until I have to take it for a run again? (ie. does the tank slowly drain back to the sump?).
