Old 10-15-2007, 02:38 PM   #286
masterbrewer
TDMster
masterbrewer's Avatar
Oddometer: 2,683
The missus says it's "That Damn Machine"
masterbrewer is offline   Reply With Quote
Old 10-15-2007, 06:23 PM   #287
bynder
digity digity
bynder's Avatar
Oddometer: 913
so these TDMs that are here in the states, how is parts availability, can you get parts from a dealer or are they all from online? contemplating getting one just worried about the parts.
bynder is offline   Reply With Quote
Old 10-16-2007, 11:42 AM   #288
toneski
flange buttress manifold
toneski's Avatar
Oddometer: 22
doesnt seem to be too much problem for the guys on Carpe, the main parts are just comsumables and yammie uses the same parts across a lot of models
eg. brake discs are same as the older fazer6, same with bearings, seals etc
other parts, like regulator are common generic parts
toneski is offline   Reply With Quote
Old 10-16-2007, 11:58 AM   #289
itsatdm
itsatdm's Avatar
Oddometer: 4,904
engine bars
So about 3mos ago I decide that I am going to need some engine bars if I continue to ride the TDM off pavement. Renntech, makes some for the MK1 models and I order a set from the American supplier in Ga. Numerous calls and explanations for why they haven't arrived later, I get a notice from UPS I got a package coming. A visit to my CC website shows a charge from the us supplier. I got engine bars arriving today!!
Revs Performance told me that they had never ordered a set before for the TDM and I think it may have been a case of the supplier making the bars in batches as the demand required it. So I will post a pic for the US TDM riders when i get them installed.
Old 10-16-2007, 04:44 PM   #290
djg
Oddometer: 462
engine bars
Thanks.
djg is offline   Reply With Quote
Old 10-17-2007, 07:04 PM   #291
itsatdm
itsatdm's Avatar
Oddometer: 4,904
engine bars
UPS delivered as promised and I had them installed in about an hour. I obtained the bars from .http://www.revsperformance.com/renntec/engine_bars.htm
The bars are very well made and come with all the attaching hardware. They fitted right up. The top replaces and existing motormount and the bottom uses a replacement rod for the existing skid place mount.
I mounted the bar over my modified stock skid plate which stiffened it up considerably.
Front view, you can see how much they stick out from the engine cases.
Masterbrewer commented in one of his threads that the bars add no protection to the fuel tank and I agree. His solution was to weld an additional loop on each side up to at least the bottom of the tank. Probably
the route I will take because I do want the ability to convert back to stock. Another option is to recreate the radiater supports out of tubing so that they project past the fuel tank. Hmmm a set of headers off a Tenere would give me a couple more inches of ground clearance.
Old 10-25-2007, 03:10 PM   #292
Dfrnt
Just pluggin' along
Dfrnt's Avatar
Oddometer: 1,008
Tank protection
I'm thinking I ought to get me a set of those bars. Protective and makes you look tougher at the same time. It almost looks like you could mount a couple of frame sliders like they put on sport bikes, maybe 3"~4" long, on the engine mount location for the bars. It should protect the tank on pavement or hard dirt roads just fine. Probably not much good in sand though. I'll measure tonight when I get home and see if I can find a source. Thanks for the info.
"Roads? Where we're going we don't need roads" Doc Brown
Dfrnt is offline   Reply With Quote
Old 10-25-2007, 03:53 PM   #293
toneski
toneski's Avatar
Oddometer: 22
i offered up the new stainless set of headers i've bought for my super tenere onto my TDM and they will fit if you dont mind losing the rear brake and rider peg
no?
guess not then
Old 10-26-2007, 03:25 AM   #294
tzolea
George
tzolea's Avatar
Oddometer: 11
My TDM
1997
850cc
45.000 km
Givi Windshield
Hepco Crash Bar
tzolea is offline   Reply With Quote
Old 10-26-2007, 04:10 AM   #295
masterbrewer
TDMster
Oddometer: 2,683
Hi Itsatdm
I found that it was well worth the effort to weld these extensions onto bars like that, as I found .............(on more than one occasion............... )
The original bars being so low on the bike that they actually worked as a pivot to slam the top fairing into the ground even harder.
Just got sick of mending the top fairing all the time.
Good luck with ya dirt riding.........................the TDM just eats it up (bearing it mind its limitations of course)......................now get out & get it "dirty"
Cheers
Old 10-26-2007, 04:19 PM   #296
itsatdm
itsatdm's Avatar
Oddometer: 4,904
Oh I have been riding but around here it is mostly in conditions like this:
Which brings up a question. Very happy with my suspension, didn't know that 6.5 inches would work that good But that 4.10 tire in front is about 1+ inches bigger in diameter that a stocker and I really notice the change in geometry. Stable to a fault, How do you turn this thing at speed when you are trying to stay atop sand or gravel?
Old 10-26-2007, 06:07 PM   #297
masterbrewer
TDMster
Oddometer: 2,683
[/quote]Which brings up a question. Very happy with my suspension, didn't know that 6.5 inches would work that good But that 4.10 tire in front is about 1+ inches bigger in diameter that a stocker and I really notice the change in geometry. Stable to a fault, How do you turn this thing at speed when you are trying to stay atop sand or gravel?[/quote]
Not sure what you mean by "stable to a fault"
I found the TDM has a very different riding position & technique to what "off road bikes" have.
When the surface gets sandy or loose I find that rather than fully standing up on the pegs, I bend & raise my elbows above my hand line which forces me to sit slightly forward & weight the pegs slightly. That gives me better control over flapping tank slapping handle bars in the really loose stuff.
You really have to push the TDM over going into corners.
Hope it helps
Cheers
Old 10-26-2007, 10:57 PM   #298
itsatdm
itsatdm's Avatar
Oddometer: 4,904
Originally Posted by masterbrewer
"stable to a fault"
Hope it helps
Cheers
Thats exactly what I meant, in order to turn in the soft stuff, you have to lean it over way more than I am comfortable with doing and trust it won't slide out from under you. The gravel roads around here tend to be narrow and twisty. Think I will tinker with either raising the rear or lower the front to see if I can get some of that nuetral feeling back.
Old 11-28-2007, 10:40 PM   #299
masterbrewer
TDMster
Oddometer: 2,683
Here's the latest fun in South Oz
http://www.advrider.com/forums/showthread.php?t=288804
Hope you enjoy
Cheers
TDMKym
masterbrewer screwed with this post 11-28-2007 at 11:18 PM
Old 11-29-2007, 07:16 AM   #300
FXRocket
Phoneticide Squad
FXRocket's Avatar
Oddometer: 5,315
Hey Bynder, I found this on line... Check it out.
http://216.37.204.206/xtremepowerspo...?Type=12&A=120
If you say "Gullible" slowly it sounds like "Oranges".
FXRocket is offline   Reply With Quote
Times are GMT -7.   It's 01:47 AM.
