08-11-2006, 07:29 AM
#46 |
Wannabe Adventure Tourer
Oddometer: 2,019
Man, you guys and your sweet looking TDMs make my rat bike look even rattier.
![]() I'm at decision time; do I sink a couple grand into fixing up the TDM [shock, body work & gas tank (crash damage), possibly carbs (for more power), possibly rings (using oil)] or do I sell it and buy another bike (like a DL650). What to do, what to do. |
08-11-2006, 02:44 PM
#47 |
Oddometer: 56
TomS thats the same tires I ran on my 93. They worked pretty good but I was always leary of the lower speed rating of the front tire especialy tagging the throttle on the slab. They definitly worked better on the fire trails but as the front wore it gave up some on the tarmac.
Looking for the road less travelled
08-11-2006, 05:36 PM
#48 | |
NoMoTDM still Gary
Oddometer: 3,705
08-11-2006, 09:34 PM
#49 | |
Pouring Rain
Oddometer: 105
http://www.advrider.com/forums/showthread.php?t=158485
2006 Harley Davidson Fat Boy |
08-11-2006, 10:28 PM
#50 |
Oddometer: 18
hi, I also own a TDM900!
DP tire options is THE issue... In the 900 the rear rim is a 5.0x17 and front is the 3.5x18. My plan is to swap the front rim to a 3.5x17 (yamaha yzf r6/r1) and use supermoto rain tires or pirelli MT60R... 120x70 and 160x60... Other problems for DP convertion is the bashplate and low level side exhausts...
Regards, Paulo Sousa Azores/Portugal 02' TDM900 '71 BSA B25SS |
08-12-2006, 08:29 AM
#51 |
That ... Umm ..... "Dude"
Oddometer: 5,260
Greetings everyone ......
K ... I do have this somewhat strange issue going on with my TDM that I have yet been able to truly deduce. First, I'll give ya all the symptoms, and then a little history on what's been done on her ... Symptoms: It seems like, if I don't start and / or ride her (mind you all I just got out of a cast for a broken foot so I haven't been riding for the last 7 weeks) so if I don't at least start her like every 3 days this happens; She labors while running, seriously. Like I have the choke all the way out, and she labors to keep the idle (even after the engine warms up) at 1.5 rpm. If I put the choke in, she'll stall. With the choke out and you apply throttle, she still labors, like the engine is definitely not running smoothly. I'm an o.k. mechanic for minor things, and I can follow instructions in my Haynes manual to do stuff, but for advanced troubleshooting on what might be wrong .... welllll ....... I really am more of a jockey. At first I thought it was a total fuel related issue, but this can happen when there's still gallons of gas in the tank ..... so that has led me to think that maybe it's more of an air issue ..... dunno. After the mystery symptom happens, if I go out and start the TDM every day after work, it will get better and better, and finally after about 2 or 3 days of starting her with the choke all the way out, she's fine again. If I run her every other day after that she's fine. If I wait, let's say, 5 days before I start her, the problem could (but not always) happen again, and the cycle repeats. History: Back in Jan of this year, while replacing the battery in her, I got a break in one of the fuel lines ..... not fun. So I trailered her into the shop and they did the following; Replaced the fuel lines Cleaned and synced the carbs Performed an over all tune-up on her So. Unless there was something up with the actual tank, I can't see how it would be a fuel delivery issue, which also really doesn't fit the cycle of symptoms, at least not in my mind. I can't see how it would be related to the carbs, since they were worked on 8 months ago. Before my little fall off my back deck, when I was literally her every day, she had no, as in zero, problems with this ....... so the only thing that I can find as a pattern, is that if I don't run her for a number of days, this problem may, or may not, happen. And as I stated above, when it does happen, it seems to work it's way out after a couple of days ......... Does anyone have any suggestions, or has anyone ever encountered this with their TDM ???????? Take it easy everyone ...... G.
03 Caponord "The Funness out-weighs the Dumbness ....." - Mr. Jetmoto |
08-12-2006, 09:12 AM
#52 | |
NoMoTDM still Gary
Oddometer: 3,705
08-12-2006, 11:47 AM
#53 |
Oddometer: 2,019
^I agree with itsatdm. Some people on the TDM mailing list reported similar issues and solved it by replacing the fuel pump. Here's a link for some details on swapping for an electric fuel pump. I want to do this mod myself.
http://www.carpe-tdm.net/ipb/index.php?showtopic=201 |
08-14-2006, 01:50 AM
#54 |
TDMster
Oddometer: 2,202
TDM 850 Adventurer
08-14-2006, 11:21 AM
#55 | |
Oddometer: 5,260
Yo .... Masterbrewer
Also ... what tires are ya runnin on that thang? They look great! Cheers ............. G.
08-15-2006, 06:05 AM
#56 |
TDMster
Oddometer: 2,202
[quote=mandango45]I'm gonna pm ya as well .... but what manufacturer made your crash guards? I want to get some for my TDM, and I like the looks of yours!
Also ... what tires are ya runnin on that thang? They look great! Cheers ............. Bent the bash plate up myself from 4mm aluminium...bolted it to the original bash plate at the front and brackets bolted under the foot pegs bracket at the rear. With a couple of angle bars bolted in line in the middle to give it strength. Piece of cake !!!! Good luck Tyres.... Fronts are IRC 110's reversed rears Rears TKC 80's Here's a few more pics just uploaded http://www.advrider.com/forums/showthread.php?t=159182 Cheers
08-15-2006, 08:26 AM
#57 |
Freeeeze
Oddometer: 1,036
IRC shows the 110 as a tube type... Any issues running it as tubeless or are you putting in tubes?
Also, how is the wear on a big bike like these? will they last a long tour - trip? |
08-15-2006, 02:53 PM
#58 | |
TDMster
Oddometer: 2,202
Initially tried tubeless but wasn't successful so I am running a tube at the front. Great handling and sure footed braking. 5,000kms so far with about 1/4 worn. The TKC 80's is a different matter, much faster wearing, but I did find some fantastic roads recently as per the pics & couldn't help myself having fun. Still very happy with result. Cheers
08-15-2006, 05:11 PM
#59 | |
Oddometer: 56
I'd like to find one somewhat cosmeticaly chalenged just for that reason. Unfortunatly most for sale are pristene street bikes for more money than I'd like to spend. Now if I could find one ready to strip I have some crazy ideas in my head. The only thiong that stopped me on the last one was the cost of repairing the crank. Spun a rod bearing I think. Now looking back I wish it was still in my garage.
08-15-2006, 10:06 PM
#60 |
Sonambulistic
Oddometer: 14
Still in the TDM club
Sorry to butt into your thread, but as some of you may have noticed, I'm trying to sell my TDM to help pay off the KTM.
http://www.advrider.com/forums/showthread.php?t=158485 There has got to be somebody who needs this bike!! If I can't sell it, I may go the route of Masterbrewer (Outstanding job, by the way). I would have to change my name to Goose or the Lord Humongous to duke with that damn thing. God that thing looks tough....
If you wish to drown, do not torture yourself with shallow water. - Bulgarian proverb |
