Old 08-07-2008, 03:14 AM   #796
dicky1
dicky1's Avatar
Oddometer: 240
Hi DualDog
I'm not aware of any after market products in the UK. The norm here would be to try the bike breaker yards or another bike with bad engine / mechanicals going very cheap.
Dicky
2009 TDM 900
1997 Suzuki 250RT
2009 Varadero 1000 (hers)
1996 TTR 250 (hers)
dicky1 is offline   Reply With Quote
Old 08-07-2008, 05:19 AM   #797
SlipChip
Adventure Commuter
SlipChip's Avatar
Oddometer: 3,319
Hey DualDog, there are parts out there. Check BikeBandit and fleabay....
Chip
`92 Yamaha TDM 850
“Discoveries are often made by not following instructions, by going off the main road, by trying the untried.” - Frank Tyger
"Life begins at the end of your comfort zone." - Neale Donald Walsch
SlipChip is offline   Reply With Quote
Old 08-07-2008, 05:31 AM   #798
SlipChip
Adventure Commuter
SlipChip's Avatar
Oddometer: 3,319
`92 TDM Stops, and fixes itself...
Well, not exactly, but...
I got home from work yesterday, park the bike and shut it off, then decide to move it. Turn key, push starter button, get half a second of starter turning over then click, nothing. No lights, fuel pump, nothing. I come out a hour later and start checking fuses and wiggling connectors. There is power from the battery, but nothing works. I turned on the ignition and un plugged and replugged the connectors to the ignitor box, nothing, two seconds later, bink, the power comes back on.
Any Ideas? I had been running the brights on a fairly warm day if that matters...
Edit, did it again this morning. Turn key, thumb starter button, grrr, click, dead....
Chip
`92 Yamaha TDM 850
SlipChip screwed with this post 08-07-2008 at 06:50 AM
Old 08-07-2008, 07:50 AM   #799
dicky1
dicky1's Avatar
Oddometer: 240
Hi SlipChip,
My partner had exactly the same problem on her Varadero recently,
After stripping the starter motor and cleaning the regulator/relay connections, finally tracked the problen down to corrosion in the starter button. (the after effects of a recent tumble in seawater).
A quick clean-up with emery cloth and a lube with vasaline and its been fine since.
Warning: there were lots of tiny bits/springs in the Varadero starter button so go carefully, I expect the TDM button is similar. Might be worth a quck squirt of WD40 into the starter button first followed by checking the connections to the starter motor and relay, as these are probably more straight forward than openning the starter button (Not sure on your model)
Dicky
2009 TDM 900
1997 Suzuki 250RT
1996 TTR 250 (hers)
dicky1 screwed with this post 08-07-2008 at 08:06 AM
Old 08-07-2008, 09:11 AM   #800
TDMTAM
TDMTAM's Avatar
Oddometer: 112
Try checking the main power wire at the conector block for the Ignition switch I have seen than corriode through causing int. starting faults.
TAM
TDMTAM is offline   Reply With Quote
Old 08-07-2008, 03:34 PM   #801
masterbrewer
TDMster
masterbrewer's Avatar
Oddometer: 2,584
G'day SlipChip
I use spray "brake parts cleaner"............ sprays wet dries immediately, cleaned up contacts fine.
Good Luck
Cheers
TDMKym
masterbrewer is offline   Reply With Quote
Old 08-07-2008, 10:20 PM   #802
SlipChip
Adventure Commuter
SlipChip's Avatar
Oddometer: 3,319
Thanks for ideas guys. Connections all look good thouhgh I haven't gotten under the bike to look at the starter yet. Switches on handlebars looked good when I changed the bars a few weeks back. (Uly bars)
I am thinking the starter relay. This is the unit that is doing the clicking and sticking apparently. It clicks back over while the igniton is on, seemingly at random.
Ya know, that Yamaha shop manual is good for some things and worthless at others...
Chip
`92 Yamaha TDM 850
Old 08-08-2008, 02:39 AM   #803
TDMTAM
TDMTAM's Avatar
Oddometer: 112
The starter relay can cause the same symptoms but that tends to be the mkII model may be worth a try.
http://shop.wemoto.com/pictures.dyn?u=2147984qqq3532154
TAM
Old 08-08-2008, 05:22 AM   #804
SlipChip
Adventure Commuter
SlipChip's Avatar
Oddometer: 3,319
TAM
That's the one Tam, I'm going to pick one up at the breakers today...
:crossedfingers hoping it's not the starter.
Chip
`92 Yamaha TDM 850
Old 08-09-2008, 12:29 PM   #805
brooks
Oddometer: 322
Thumb
Dualdog,
All parts are available at your local stealership and through companies like bikebandit. Their name says it all though, every part i have ordered from them is just as expensive as local and if there is a problem the dealer takes care of it. They are a rare bike in the us but they still stock parts for them.
Brooks
brooks is offline   Reply With Quote
Old 08-09-2008, 02:37 PM   #806
AJ..
AJ..'s Avatar
Oddometer: 1,541
I had a great ride today out of 293km worth the fuel burnt..Me and another 3of my TDM friends..one is on his virgin TDM ride.newly bought and just completed the breaking in.
Yes Masterbrewer...i need to recover from those lost time for not having to do some ride.
the babes that tag along.
notice i did'nt type and short stories,its becoz its 4.40am now.the ride was from 11.30am to 9.30pm.had some music jamming session from midnite to 2am with my band,and now just completed uploading the piccies to my multiply.
Hope you guys enjoy it.
East Side TDMers.
HONDA XRV750-02,(woot-woot)BMW R1100GS-'98()BMW F650GS-01
Suzuki XF650Freewind-01
Husqvarna TE510centennial Rallye-04
KTM640ADV,KTM620DUKE projected()[COLOR=red]VF750C-96(project tracker)
http://www.facebook.com/pages/AJs-friends/158711187491373?v=wall[/URL]
AJ.. is offline   Reply With Quote
Old 08-09-2008, 03:48 PM   #807
SlipChip
Adventure Commuter
SlipChip's Avatar
Oddometer: 3,319
TDM Fixey
So, after picking up both the start control relay and the starter relay at the breakers and swapping them out the bike acted differently but still not right and definitely not starting. Pulled the starter and the battery and stopped by the stealership* (I like that,thanks Brooks) and had them checked, starter okay, battery kaput. New battery installed and guess what, it works!
The thing that I don't understand is that I was getting 13.5 volts out of the battery when this problem started and then for it to act different with new components installed? Oh well, back to the lawn mower...
and maybe a little pleasure ride 2morrow...
PS. don't tell anybody that I D/L the H@ynes manual off of Carpe...
Chip
`92 Yamaha TDM 850
Old 08-09-2008, 04:13 PM   #808
masterbrewer
TDMster
Oddometer: 2,584
[quote=AJ.. Yes Masterbrewer...i need to recover from lost time for not having a ride. /quote]
Someone should tell that guy he can ride the TDM out there
I love your bikes' accessories
Well done AJ..
Cheers
TDMKym
Old 08-09-2008, 09:14 PM   #809
AJ..
AJ..'s Avatar
Oddometer: 1,541
yes...infact he does....after jumping over the sand and confirmed that it is safe....
well,not many are as crazy as us dude...
and yah,he just did a front dual sport tyres to...very beefy...great looking knobbs.Its Pirelli MT-60.120/80.its a rear tyre actually...good thing,its tubeless...and tyre rating is up to 190km/hr...he tested on the bike up to 180km/hr and no trouble with headshaking...price :SGD$140
This could be my next front tyre change...but its alittle way too close to the front mudguard...needs to do some alteration.
oh..the accesories,well....
AJ.. screwed with this post 08-09-2008 at 09:29 PM
Old 08-10-2008, 12:57 AM   #810
masterbrewer
TDMster
Oddometer: 2,584
No explanation needed AJ..
We could all tell........................................ by this pic
or was it this pic
no!........... it was this pic me thinks....................we all know what you are about to go through
Congratulations on getting married too AJ..
Cheers
masterbrewer screwed with this post 08-10-2008 at 03:13 AM
Times are GMT -7.   It's 08:30 AM.
