Old 06-06-2014, 09:30 AM   #1
woodsrider-boyd OP
Wow, these guys are fast
woodsrider-boyd's Avatar
Oddometer: 503
2002 Derbi GP1 50 Project
Hey folks,
I thought I would start a thread about my new project, a 2002 Derbi GP1 50, since there is hardly any info out there on these Spanish beauties. Just picked it up and I'm chomping at the bit to get into it. Non-runner with a reported coolant leak from the water pump. Was running fine otherwise according to the PO. We will see.
I have a garage full of bike and car projects lined up, but this one may have to jump to the top of the list. Here it is settled in next to a friends Honda 70 that I am giving a spring freshen up to.
Question: can anyone recommend another good scooter forum or two where I can learn about the Derbi and it's Piaggio engine?
I found a few part suppliers and have both a soft copy and hard copy of the service manual so I'm good to go that way.
Been wanting a scooter forever, so hopefully this will work out, can't wait to see.
Ed
I don't know karate but I do know ca-razy.
'06 Husqvarna WR125
woodsrider-boyd is offline   Reply With Quote
Old 06-06-2014, 11:50 AM   #2
Dan V.
Dan V.'s Avatar
Oddometer: 157
Looks like a nice one! Luckily you have the Piaggio engine in it, otherwise you might have been fooked. I have a Derbi Atlantis - basically the same engine - and it is one fast and fun scoot. I have a DR70cc cyl installed with a mild pipe and it rocks. The Piaggio engine is the same as in many models of Vespa and Piaggio scoots, so finding info on the engine is no problem, as well as obtaining engine parts. I have a Haynes manual for Piaggio, so that is a must have if you are getting into scoots.
Bad news is - it is a Derbi. Derbi parts are unobtainum here in the US. Was a time when parts were available out of Florida, but Ozzie sold all his stock. You may have to haunt Ebay, or try overseas for Derbi parts.
Good Luck with your project. The GP1 was a top end scoot in it's day - and still very desirable.
How many scoots are too many?
Dan V. is offline   Reply With Quote
Old 06-07-2014, 10:32 AM   #3
villageidiot
Oddometer: 2,010
For most any engine related stuff, try 50cc.nl
They're a mega 2 stroke small bore supersite. I've had good(great) experiences with them. Used to get pallet loads a month delivered.
villageidiot is online now   Reply With Quote
Old 06-07-2014, 10:37 AM   #4
woodsrider-boyd OP
Oddometer: 503
I was able to do just a bit of research before I bought it, and I did note that its quite the little performer and that it had the fairly common Piaggio engine. If it had not I would not have even considered it.
And if I find the top end is toast I am considering going with a 70 cc kit, might as well.
Fortunately I didn't pay much for it, and the guy selling it is a scooter guy, seemed like an honest guy, so I'm pretty sure I'm getting what he described.
Again, we will see. Worse comes to worse I decide its not worth fixing up and sell it as is for what I paid for it, or I part it out and recoup my meager investment.
But I have a history of resurrecting otherwise dead bikes, so I'm hoping for the best with this one.
Let the games begin!
'06 Husqvarna WR125
Old 06-07-2014, 03:39 PM   #5
Chillis
Land Barge Pilot
Chillis's Avatar
Oddometer: 4,102
You can make that bike fly! I would get on racing planet USA website and get a shopping list going.
Easy 70mph bike can be made of it.
You could also do a skelley or however they spell it. Strip the bodywork and have a tube framed bike.
Chillis is offline   Reply With Quote
Old 06-08-2014, 09:47 AM   #6
woodsrider-boyd OP
Oddometer: 503
Thanks for the links guys. Right now the plan is to get it running reliably and safely, probably keep it stock. Maybe put a 70 cc kit on it if the top end is toast.
It will be shared with between myself and my two teenage daughters so I don't want to let them loose on a crazy fast scooter right off the bat, especially since this thing is reportedly pretty fast right from the factory.
If they end up not riding for whatever reason, then yes, perhaps some performance mods if I end up loving it and becoming a super scooter nerd (I could easily see that happening).
'06 Husqvarna WR125
Old 06-09-2014, 12:19 AM   #7
rspratley
Oddometer: 26
Hi, you can find information here http://modernvespa.com/forum/
Its mainly piaggio but also has other brands.
rspratley is offline   Reply With Quote
Old 06-09-2014, 11:02 AM   #8
woodsrider-boyd OP
Oddometer: 503
Excelente, muito obrigado!
'06 Husqvarna WR125
Old 06-09-2014, 12:26 PM   #9
scubabiker
Oddometer: 117
im a member of a website called scootershack.co.uk very good webiste, is yours the version with the stupid chain drive? the engine is the samme as a gilera runner sp50, aprilia sr50 a piaggio nrg 50 and many others, lots of good tuning parts available from places like adrenalin pedstop, pmtuning and a few more.
this is how we use the greatest minds in science, not a cure for cancer but a profit for giants, they blind the clients with advertisements as security heightens that 'aint progress it's violence
joined the darkside, got a GS
scubabiker is offline   Reply With Quote
Old 06-09-2014, 12:30 PM   #10
scubabiker
Oddometer: 117
http://www.scootershack.co.uk/
heres the link if it works
Old 06-09-2014, 09:00 PM   #11
woodsrider-boyd OP
Oddometer: 503
More good links, thanks!
And no final drive chain, its belt driven.
'06 Husqvarna WR125
Old 08-21-2014, 11:17 AM   #12
woodsrider-boyd OP
Oddometer: 503
Finally got some time to work on the Derbi. I was hoping to get the water pump and shaft pulled and replaced without having to split the cases, but the water pump impeller is stripped off its mounting nut, so I have to split the cases to replace the impeller.
At this point I think I'm just going to replace the crankshaft bearings and seals and put in a new piston, rings, and small end bearings plus gaskets, seals, etc. Keep it stock on the piston size, no big bores at the moment.
Will call Racing Planet in the next day or two and see if they can help me get the right parts ordered up.
The waterpump and its seized up shaft are behind the oil pump on the shaft on the lower left.
The waterpump, shaft and bearings were frozen in the cases bad. Did days of soaking with penetrant, heat, cold, couldn't get it to budge. Finally got a threaded rod welded to the end of the shaft, then rigged a brace and wrenched the water pump out. Watched a youtube video with narration in a language I did not understand to get that tip. Been watching a lot of Piaggio engine rebuild videos in languages that I do not understand. Lots of narration and explaining that I am not getting.
Backing the waterpump out.
'06 Husqvarna WR125
Old 08-21-2014, 11:23 AM   #13
woodsrider-boyd OP
Oddometer: 503
Finally freeing it up.
And its out. What a mess.
Pulled the seal in there, will clean it all up when I split the cases.
Gave the bike a thorough washing before I got into it.
Next up is ordering up some parts and removing the motor, then splitting the cases.
Only problem is that my Lectron carb just showed up for my Husky 125 so I may get diverted for a bit while I install and fiddle with that and of course get out on some test rides.
'06 Husqvarna WR125
Times are GMT -7.   It's 03:48 PM.
