Go Back   ADVrider > Bikes > Battle Scooters
Old 06-07-2014, 06:12 AM   #1
9secondsflat OP
Oddometer: 323
TWO STROKE ENGINE EXPERTS- HELP please
9secondsflat screwed with this post 06-23-2014 at 02:51 PM
9secondsflat is offline   Reply With Quote
Old 06-07-2014, 06:55 AM   #2
B02S4
Aye
B02S4's Avatar
Oddometer: 1,123
What "vacuum pump"?
If the theory is that fuel isn't getting to the carb because of a bad fuel valve or blocked vacuum line, then try a temporary gravity feed bypass to he carb, from an aux. tank if necessary.
If that works, then either the tank is empty, the valve is defective, or the vacuum line is plugged...
B02S4 is offline   Reply With Quote
Old 06-07-2014, 08:40 AM   #3
9secondsflat OP
Oddometer: 323
Old 06-07-2014, 09:19 AM   #4
tortoise2
tortoise2's Avatar
Oddometer: 576
The pulse-pump troubleshooting guidelines in this lawn mower video may apply.
tortoise2 is offline   Reply With Quote
Old 06-07-2014, 09:40 AM   #5
9secondsflat OP
Oddometer: 323
thank you for the vid...a few more things to check.
Old 06-07-2014, 09:55 AM   #6
scubabiker
Oddometer: 117
i was actually working on one of these at work not so long ago, that pump can be a pain, check your compression and check your oil tank, if its ran dry of oil its knackered, the one at work had a habit of filling the motor with oil if it was stood (the oil pump leaked through)
if its any help the engine is the same as an air cooled suzuki estilette or suzuki katana.
hope my rambling helps
this is how we use the greatest minds in science, not a cure for cancer but a profit for giants, they blind the clients with advertisements as security heightens that 'aint progress it's violence
joined the darkside, got a GS
scubabiker is offline   Reply With Quote
Old 06-07-2014, 10:41 AM   #7
9secondsflat OP
Oddometer: 323
9secondsflat screwed with this post 06-23-2014 at 02:52 PM
Old 06-07-2014, 03:08 PM   #8
B02S4
Aye
B02S4's Avatar
Oddometer: 1,123
Originally Posted by 9secondsflat View Post
the fuel tank is under the scooter on this model, the vacuum pump is about 10 inches above the bottom pick up of the tank...no gravity here.
Hmmm...sorry I can't help with that one.
Old 06-09-2014, 06:42 AM   #9
MORT666
MORT666's Avatar
Oddometer: 214
Change the plug cap, this can break down under load.
MORT666 is offline   Reply With Quote
Old 06-09-2014, 07:31 AM   #10
rufus
We're burning daylight...
rufus's Avatar
Oddometer: 4,273
Check the fuel tank vent hose. If it is plugged it will not allow fuel to flow. Like when you hold your finger over the end of a drinking straw.
rufus is offline   Reply With Quote
Old 06-10-2014, 01:07 PM   #11
9secondsflat OP
Oddometer: 323
Old 06-11-2014, 04:26 AM   #12
creighta
Oddometer: 128
pulse pumps go bad. i have changed several. if you just stuck on the line nothing is going to happen, you need a vacuum pulse so suck, release, suck.... you get the idea. if it is good you will know. the most common two stroke issue i have had is the oil injection pump filling the carb with oil if you try to start the bike unsuccessfully a time or two. when this happens you have to take the carb apart and clean the excess oil out of it. if you replace your fuel pump and it still doesn't start try that.
fwiw i did have a Yamaha atv get a plugged vacuum line to the fuel pump that prevented the pump from running. it was a 4t though
creighta is offline   Reply With Quote
Old 06-11-2014, 05:11 AM   #13
9secondsflat OP
Oddometer: 323
Old 06-11-2014, 02:30 PM   #14
creighta
Oddometer: 128
the $5 pump is going to go bad faster than the $40 one, but you could replace it several times for the price. if the bike was bigger i would suggest an electric swap. not sure the 50 puts out enough power
Old 06-12-2014, 11:45 AM   #15
Mucka
Oddometer: 226
Why don't you think it is getting fuel? If you sprayed starting fluid into the cylinder and it did not start that would lead me to think it is not a fuel issue. I may have read your post incorrectly!!!
I am not familiar with this engine. How does the timing work? If you have fuel, air, spark and compression it should run. Did you try a new spark plug. Is the old plug gapped correctly?
I am old and confused most of the time, so I may have missed something.
Good luck
Russ
Mucka is offline   Reply With Quote
Times are GMT -7.   It's 09:18 PM.
