Old 06-12-2014, 12:04 PM   #16
9secondsflat OP
Oddometer: 336
9secondsflat screwed with this post 06-23-2014 at 02:52 PM
9secondsflat is offline   Reply With Quote
Old 06-12-2014, 07:09 PM   #17
creighta
Oddometer: 117
stupid question but is your emergency kill switch on?
creighta is offline   Reply With Quote
Old 06-12-2014, 08:36 PM   #18
maddiedog
PCX or GTFO
maddiedog's Avatar
Oddometer: 272
Originally Posted by 9secondsflat View Post
i pulled the vacuum line off and sucked and cant get the fuel to flow even when its not connected to the carb. i ordered another pulse pump and will replace the stock one...time will tell if this is the issue on my friends scooter or not.
Check your fuel petcock, I bet it's stuck closed...
Honda PCX 170 / WeeStrom 650
http://www.hondapcx.org
maddiedog is offline   Reply With Quote
Old 06-12-2014, 08:46 PM   #19
Hot Stuff
Road Dragon
Hot Stuff's Avatar
Oddometer: 343
Just to recap for the OP (and please correct me if i'm wrong), he verified that he has fuel going INTO the pulse pump, but no fuel is coming OUT of the pulse pump. Therefore, he will be replacing the pulse pump. Update to follow.
Hot Stuff is offline   Reply With Quote
Old 06-13-2014, 12:12 AM   #20
9secondsflat OP
Oddometer: 336
9secondsflat screwed with this post 06-23-2014 at 02:53 PM
Old 06-14-2014, 07:08 AM   #21
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,425
its not stupid, years back when I was working on one of my bikes, the kill switch was off and like a dope didnt think to check the position prior to trying to fix an ignition issue...
I pushed a motorcycle two blocks before I discovered I did this.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 06-17-2014, 12:08 PM   #22
Mucka
Oddometer: 224
I thought the OP mentioned he tried some starting fluid and that did not work. In my mind even if the pump is bad it should run for a short time until the starting fluid is exhausted. That is why I mentioned some other thoughts.
Let us know how the new pump works and if that was the issue.
Good luck.
Russ
Mucka is offline   Reply With Quote
Old 06-17-2014, 02:57 PM   #23
baloneyskin daddy
bikaholic
Oddometer: 2,139
HOW DOES A SPARK JUMP AN INCH INTO HIS HAND? He tried to foul the plug? How does he know it has compression . It probably doesn't have enough and therefor not enough vacuum to operate the pump. Kind of answers the ? of why it didn't at least fire with starting fluid.
baloneyskin daddy is offline   Reply With Quote
Old 06-18-2014, 06:45 AM   #24
baloneyskin daddy
bikaholic
Oddometer: 2,139
Apparently this thread is dead but vacuum fuel pumps don't work simply from vacuum ,but the pulsing vacuum created by a running engine which rapidly opens and closes a diaphragm causing a pumping action in the pump. Simply applying a vacuum pump to it does nothing but open the diaphragm one time.
Old 06-19-2014, 06:44 AM   #25
9secondsflat OP
Oddometer: 336
Times are GMT -7.   It's 12:56 PM.
