Old 06-12-2014, 12:55 PM   #1
herman7196 OP
Oddometer: 27
1987 ch150 power loss & return... skipping? popping?
I've read up on this issue I'm having with my 3600 mile, 1987 ch150 and found that the cdi can go bad.
So, I bought a new one on ebay (chinese clone for around $10 shipped). I put it in and the scooter still goes into these phantom and very random power losses where the engine cuts out and seems to run at 1/2 power.
Eventually & and also very randomly, it'll come back to full power. Sometimes it'll stay at 1/2 power for the entire 2-3 mile inner city ride. Other times it'll stutter for 3-10 seconds and come right back to full power. Other times it';; feel like it's threatening to go into the 1/2 power mode but it never does.
It sounds and feels like an ignition issue.
I say this because it feels & sounds as if while riding, I've shut the kill switch off while keeping the throttle open... like a backwards, light popping but the engine still has 1/2 power and runs.
I have lost some top end. I used to be able to jump on the highway and run up to 60mph pretty easy but now I'm struggling to hit 55mph.
I removed the carb and cleaned it. It's fine. I currently have no air filter on it. The issue did still happen when I had a K&N pod filter on it. I'm pretty certain it has nothing to do with air filtration. I also adjusted the valves.
The only thing I haven't checked it the fuel filter and that's because I changed it 2 years ago. The fuel tank has been por 15'ed so it's clean inside. The gas is fresh and new.
I'm at a loss.
herman7196 is offline   Reply With Quote
Old 06-12-2014, 04:29 PM   #2
k-moe
k-moe's Avatar
Oddometer: 2,892
Have you checked for an air/ exhaust leak?
Mixing metaphors is like killing two birds with a dog that won't hunt.
k-moe is online now   Reply With Quote
Old 06-12-2014, 04:56 PM   #3
baloneyskin daddy
bikaholic
Oddometer: 2,161
Chec k for cracked intake manifold or pinhole or holes in throttle carb slide diaphragm.
baloneyskin daddy is offline   Reply With Quote
Old 06-12-2014, 05:48 PM   #4
herman7196 OP
Oddometer: 27
The way the problem happens... randomly and infrequently... I don't think its an air or exhaust leak but I will look it over closer for those things.
If there was a crack allowing an air or exhaust leak, I'd think it would always be leaking... not leaking off and on, randomly?
Old 06-12-2014, 06:30 PM   #5
tortoise2
tortoise2's Avatar
Oddometer: 564
Might try running the engine in darkness and look for any electrical arcing.
tortoise2 is offline   Reply With Quote
Old 06-12-2014, 07:38 PM   #6
Warney
Warney's Avatar
Oddometer: 568
Won't run right without an air filter. Put on a clean Honda OEM paper filter. Throw out the Chinese CDI. Sounds like a piece of junk is intermittently plugging the main jet or some other part of the carb. Remove, disassemble, soak in 49-state Berryman B-12 Chemtool or other decent carb cleaner overnight. Blow it out with high pressure air. That Gumout with a straw doesn't work. As others mentioned carefully examine the rubber insulator boot between the carburetor and cylinder head.
Warney is offline   Reply With Quote
Old 06-13-2014, 07:08 AM   #7
herman7196 OP
Oddometer: 27
thanks for the advice guys
Times are GMT -7.   It's 07:58 AM.
