Old 06-19-2014, 08:22 AM   #1
TX1911fan OP
Oddometer: 58
Products from Evotech and MotoPerformance-- ADV Inmate Discount Offer
April 15, 2015--Update: Due to increased international shipping costs, we are only able to offer a 10% discount to Inmates. We're sorry for any inconvenience this has caused, but hope that you will still find value in our products.
____________________________
I'll try to regularly post relevant products available from Evotech Performance. You can go to my website, www.motoperformanceusa.com to check them out. Use the code "Inmate" (without the quote marks) to receive a 10% discount.
Today's product, Triumph Tiger 800 and 800XC Engine Guard/Crash Protection
http://www.motoperformanceusa.com/Cr.../bun000909.htm
Evotech’s Triumph Tiger 800 crash bobbins are incredibly easy to fit. Simply attach to your bike’s existing mounting points and hit the tarmac modification free. These crash bobbins are made from high performance engineering polymer that will protect your motorcycle’s fairing in the event of a spill. The mounts are CNC machined from aircraft quality aluminium and powder coated. Two bobbins, mounts, hardware and instructions are included in the kit. We supply individual components should you require replacements. When you absolutely have to have presidential-level protection while retaining your Triumph’s good looks, Evotech’s superior crash bobbins deliver every time.
MotoPerformance
Tail tidies, radiator guards, crash protection, levers and more.
TX1911fan screwed with this post 04-19-2015 at 09:34 AM
TX1911fan is offline   Reply With Quote
Old 06-20-2014, 08:31 AM   #2
TX1911fan OP
Oddometer: 58
Ducati's Multistrada is a fantastic piece of machinery. We have some interesting parts for it, which can be found at www.motoperformanceusa.com. Parts like this one:
http://www.motoperformanceusa.com/Oi.../bun000316.htm
Ducati Multistrada 1200 Radiator/Oil Cooler Guard Set
Evotech’s savvy design means the Ducati multistrada radiator guards attach to your bike modification-free.. The elegantly designed matrix is pierced with hexagonal holes to optimise airflow while providing maximum protection from road debris. The Ducati Multistrada 1200 radiator guards boast remarkable strength to weight ratio, the set weighing only 333 grams. Only the best will do for Ducati Multistrada riders, the guard is CNC machined from aircraft quality aluminium. Finished in durable black powder coating, the Ducati Multistrada 1200 cooler guard kit includes hardware and easy to follow instructions.
MotoPerformance
TX1911fan screwed with this post 09-15-2014 at 01:18 PM
Old 06-22-2014, 08:36 AM   #3
TX1911fan OP
Oddometer: 58
Headlight Guards
Evotech Performance makes a couple different headlight guards. These are fantastic products, made from high grade aluminum and covered in tough powder coat. I have one on my Triumph Tiger 800 and it looks and works great. The quick release makes it easy to take off to clean the headlights and reattach. Check them out, and all our other parts, at www.motoperformanceusa.com. As always, Inmates get a 10% discount using the code "Inmates" at checkout.
Headlight Guard for BMW R1200GS
http://www.motoperformanceusa.com/He.../bun001454.htm
BMW R 1200 GS Headlight Guard
Evotech headlight guards fit like original factory equipment, using the existing mountings and requires no modification to your BMW R 1200 GS.
Elegant in concept, the matrix is pierced with hexagonal holes to provide maximum protection from road debris.
They have a remarkable strength to weight ratio, our headlight guard only weighs 300g.
Our guards are CNC machined from aircraft quality aluminium and finished in a durable black powder coat.
The quality of our headlight guard is superior to anything that we have seen from our competitors and we are sure that you will be proud to have one on your BMW R 1200 GS.
We operate a 'no-quibble' returns policy if you are not completely satisfied.
A broken headlight is not only an inconvenience and very expensive, peace of mind is only one step away.
Technical specifications:
Material - Billet Aluminium
Finish - Black
Weight - 300g
Fitting Difficulty - 1 ( 1 low - 5 high )
Fitting Time - 20 mins
Headlight Guard for Triumph Tiger Explorer and Tiger 800
http://www.motoperformanceusa.com/He.../bun001453.htm
Triumph Headlight Guard
Evotech headlight guards fit like original factory equipment should, using the existing mountings and requires no modification to your Triumph. The head light guard can be removed in seconds to allow the light to be cleaned. This is down to the unique design aspect of the securing system. Elegant in concept, the matrix is pierced with hexagonal holes to providing maximum protection from road debris. They have a remarkable strength to weight ratio, our headlight guard only weighs 125 grams. Our guards are CNC machined from aircraft quality aluminium and finished in a durable black powder coat. The quality of our headlight guard is superior to anything that we have seen from our competitors and we are sure that you will be proud to have one on your Triumph We operate a 'no-quibble' returns policy if you are not completely satisfied. A broken headlight is not only an inconvenience, but can be very expensive. Peace of mind is only one step away.
Finish - Black
Weight - 125g
Fitting Time - 10 mins
MotoPerformance
TX1911fan screwed with this post 04-19-2015 at 09:36 AM
Old 06-23-2014, 08:33 AM   #4
TX1911fan OP
Oddometer: 58
BMW R1200GS Engine Guards-Crash Protection
Evotech Performance has just released some fantastic engine guards for the R1200GS. Super tough and fantastic to look at, they are just the ticket for those looking for less obtrusive engine protection that the large adventure bars. You can find these and other BMW accessories at www.motoperformanceusa.com.
http://www.motoperformanceusa.com/Cr.../bun001424.htm
BMW R 1200 GS Crash Protection
Evotech Performance crash protection engine guards have been designed and manufactured specifically for your BMW to offer maximum protection.
Using the bike's original mounting points, they are easy to fit and you won't have to modify your bike in any way.
We have used our knowledge and experience to develop innovative mountings brackets that position the crash protection where we feel the bike and biker need it the most.
The kit includes all mounting brackets and necessary hardware and fitting instructions.
The mounts brackets and crash protection arms are CNC machined from aircraft quality aluminium.
We are happy to supply individual replacement parts should you need them.
We are proud of our products and are so confident in our quality and value that we operate a 'no-quibble' returns policy if you are not completely satisfied.
Fitting - 2013+
Finish - Black
Fitting Time - 45 mins
Fitting Difficulty - 2 ( 1 low - 5 high )
MotoPerformance
TX1911fan screwed with this post 09-15-2014 at 02:19 PM
Old 06-24-2014, 12:09 PM   #5
TX1911fan OP
Oddometer: 58
Multistrada Tail Tidy
Back to Ducati for today's product. This tail tidy (fender elimination kit) makes a huge difference to how the Multistrada looks. Relocate the license plate and rear signal lights and clean up the appearance. Find this and many other quality aftermarket motorcycle accessories at www.motoperformanceusa.com.
http://www.motoperformanceusa.com/Fe.../bun000321.htm
Ducati Multistrada 1200 Tail Tidy
Evotech’s tail tidy fully integrates with the sporting lines of your Ducati multistrada 1200 and is easy to fit, using the Ducati's existing mountings. You won't have to modify your bike in any way. All Evotech tail tidy kits contain hardware, instructions and LED rear number plate light. The rear light is undisturbed and the rear indicators are re-positioned using an extra bracket, so fitting the tail tidy is simple. Evotech’s Ducati multistrada 1200 tail tidy is finished in a durable satin-finish powder coating. When you absolutely have to have the best for your Ducati multistrada 1200, Evotech’s tail tidy/fender eliminator is the motorcycle part for you.
Please note this tail tidy does not fit with panniers.
MotoPerformance
TX1911fan screwed with this post 09-15-2014 at 02:20 PM
Old 06-25-2014, 09:59 AM   #6
brianpc
Oddometer: 317
Been thinking of picking up the Evotech rad / oil cooler guard set for my Multi, and finally I saw this thread - thanks!!! Glad I checked out this section. Placed my order today. :)
brianpc is offline   Reply With Quote
Old 06-25-2014, 01:05 PM   #7
TX1911fan OP
Oddometer: 58
Well then I'm glad I posted. Make sure to check out all of our other Multistrada parts.
MotoPerformance
Old 06-25-2014, 01:46 PM   #8
TX1911fan OP
Oddometer: 58
KTM makes fantastic bikes, and Evotech makes parts to enhance their looks and provide protection. Below is some engine protection for the 990 Superduke Supermoto. See this and other products at www.motoperformanceusa.com.
http://www.motoperformanceusa.com/Cr.../bun000185.htm
KTM Superduke / Supermoto R/T Crash Bobbins Specifications:
The mounts are CNC machined from aircraft quality aluminium and color anodised - if it’s good enough for planes, it’s good enough for KTM riders!
Two bobbins, mounts, fixings and instructions are included in the KTM crash protection kit.
We supply individual replacement motorcycle parts.
(KTM Superduke / Supermoto R/T riders please note that the image is for illustration only.
MotoPerformance
TX1911fan screwed with this post 09-15-2014 at 02:21 PM
Old 06-26-2014, 06:12 PM   #9
TX1911fan OP
Oddometer: 58
Triumph Scrambler Dual Protection
Something for our Triumph fans. Evotech makes fantastic engine and oil cooler protection. This dual protection package is fantastic. Check it, and other products, out at www.motoperformanceusa.com.
http://www.motoperformanceusa.com/Du.../bun001393.htm
Triumph Scrambler Dual Protection System
Evotech Performance have produced a dual protection system for the Scrambler range of motorcycles. Our system incorporates radiator and sump protection and is securely mounted using all original points without any modification to your bike. The elegantly designed matrix is pierced with hexagonal holes to optimise airflow while providing maximum protection from road debris. As only the best will do for your Triumph, the guard is CNC machined from aircraft quality aluminium. Finished in durable black powder coating, the Triumph Dual Protection System guard kit includes hardware and easy to follow instructions. Motorcycle radiator protection has never looked so good!
Weight - 600g
Finish - Black Powder Coat
Fitting Difficulty - 2 (1 low - 5 high)
Fitting Time – 25 mins
MotoPerformance
TX1911fan screwed with this post 09-15-2014 at 02:23 PM
Old 06-30-2014, 07:52 AM   #10
TX1911fan OP
Oddometer: 58
BMW R1200GS Radiator Guards
Here's a product to protect the radiator on your R 1200 GS. Extremely durable, both in materials and powder coat, these guards look fantastic too. You can find this and many more products at www.motoperformanceusa.com where Inmates receive a 10% discount. Just input the coupon code "Inmate".
http://www.motoperformanceusa.com/Ra.../bun001423.htm
BMW R 1200 GS 1200 Radiator Guards
Evotech’s savvy design means our radiator guards are secured in place using original mounting points on the bike. No cable ties in sight.
This is down to the advanced design by people who understand the concept of function, ease of fitting and aesthetics.
The BMW R 1200 GS radiator guards boast remarkable strength to weight ratio, weighing 80 grams each.
Easy to follow Instructions and hardware are supplied with every radiator guard.
As only the best will do for BMW R 1200 GS riders, the guard is CNC machined from aircraft quality aluminium.
The BMW R 1200 GS radiator guard is finished in durable black powder coating.
Weight - 80g each
Finish - Black Powder coating
Fitting Difficulty - 1 ( 1-easy 5-hard )
Fitting Time – 15 mins
MotoPerformance
Old 07-01-2014, 11:55 AM   #11
TX1911fan OP
Oddometer: 58
Ducati Hypermotard crash protection
For those who do not need large and extensive crash bars for engine protection, Evotech offers crash bobbins. These are high-strength polymer bobbins that attach to existing mounting points--meaning easy and quick install and no modification to the bike. And best of all, replacement bobbins are available in case of a spill. Check these and other products out at www.motoperformanceusa.com.
http://www.motoperformanceusa.com/Cr.../bun001141.htm
Ducati Crash Bobbins Specifications:
Evotech Performance have designed crash protection that is easy to fit and will protect you and your bike if the unforeseen does happen.
Simply attach the crash bobbins to your machine using the original mounting points.
Evotech crash bobbins are made from high performance engineering polymer that will act sacrificially to protect your bike.
The mounts are CNC machined from aircraft quality aluminium and powder coated black.
We’re happy to supply individual replacement parts.
This kit includes two bobbins, mounts, all necessary hardware and instructions.
Finish - Black
Weight - 350g (approx)
MotoPerformance
TX1911fan screwed with this post 09-15-2014 at 02:40 PM
Old 07-02-2014, 09:38 AM   #12
TX1911fan OP
Oddometer: 58
Folding Clutch and Brake levers
Todays product is listed for a Triumph Explorer, but we carry folding clutch and brake levers for most motorcycles. Adjustable and great looking, they fold away in the event of spill rather than breaking. You can find these and other brake and clutch levers at www.motoperformanceusa.com. Inmates receive a 10% discount when the enter "Inmate" in the coupon code area on checkout.
http://www.motoperformanceusa.com/Fo.../bun001505.htm
Triumph Folding Clutch and Brake Lever set
From the track to the road our Evotech Performance levers will amplify the riding experience.
The levers esthetics are only surpassed by the quality of the manufacturing.
Our Evotech Performance levers have a 6 positioning adjuster, making those little tweaks has never been easier.
Our quality levers are Machined from billet aluminum and finished in an anodized black coating for protection and longevity.
If quality, looks, and cost are the boxes that need ticking. Then job done.
Weight - 325g
Finish - Black
MotoPerformance
TX1911fan screwed with this post 04-19-2015 at 09:37 AM
Old 07-03-2014, 08:15 AM   #13
TX1911fan OP
Oddometer: 58
Hyperstrada Engine Guard
Ducati makes several fantastic motorcycles, and the Hyperstrada is no exception. Protecting that amazing engine is important, and easy with the Evotech Performance engine guard. Find this and many more products for the Hyperstrada at www.motoperformanceusa.com.
http://www.motoperformanceusa.com/En.../bun001223.htm
Ducati Hypermotard 821 Engine Guard Protector
Strength with beauty!
Evotech engine guards fit like original factory equipment, using the existing mountings and requires no modification.
Our engine guards are CNC machined from aircraft quality aluminium. The unique design allows air flow though the engine guard while still maintaining a high level of protection.
The Ducati Hypermotard engine guard are finished in a black powder coating and the kit includes any required hardware and easy to follow instructions.
The quality of our engine guards is superior to anything that we have seen from our competitors and we are sure that you will be proud to have one on your Ducati.
So confident are we in the quality of our products, that we operate a 'no-quibble' returns policy if you are not completely satisfied.
Finish - Black
Weight - 420g
MotoPerformance
TX1911fan screwed with this post 01-21-2015 at 05:46 PM
Old 07-05-2014, 08:00 AM   #14
TX1911fan OP
Oddometer: 58
Triumph Tiger 800 Sump Guard
Evotech Performance makes a fantastic sump guard for the Tiger 800. Much stronger than the stock piece, it protects your important bits while looking great. Access holes make oil changes a breeze. Check out this and other products for the Tiger 800 at www.motoperformanceusa.com
http://www.motoperformanceusa.com/Su.../bun000919.htm
Strength with beauty! Evotech sump guards fit like original factory equipment, using the existing mountings and requiring no modification to your Triumph Tiger. The guard is CNC machined from aircraft quality aluminium. The Tiger 800 sump guard are finished in silver anodised coating and the kit includes any required hardware and easy to follow instructions. The quality of our sump guards is superior to anything that we have seen from our competitors and we are sure that you will be proud to have one on your Triumph Tiger. So confident are we in the quality of our products, that we operate a 'no-quibble' returns policy if you are not completely satisfied.
MotoPerformance
TX1911fan screwed with this post 09-15-2014 at 02:50 PM
Old 07-06-2014, 04:06 PM   #15
TX1911fan OP
Oddometer: 58
KTM 690 SM Tail Tidy
Today's product is a tail tidy (fender eliminator kit) for the KTM 690 SM. Fantastic build quality and no modifications to your bike. Makes the back end of your KTM look great. Find this product and many more at www.motoperformanceusa.com.
http://www.motoperformanceusa.com/Ta.../bun000158.htm
Look at the sleek and strong design of this Evotech tail tidy and how it blends seamlessly with the sporting lines of your KTM 690.
CNC machined from lightweight aircraft grade aluminium and finished in tough satin black powder coat.
The original rear light is retained and the original rear indicators re-used.
We supply a discreet LED rear license plate light.
The tail tidy has been designed to fit your KTM 690’s existing mountings and no modification to the bike’s bodywork is required.
All hardware and instructions are included in the kit.
We are proud of our products and are so confident in our quality and value that we operate a ‘no-quibble’ returns policy if you are not completely satisfied.
This is a real eye catcher, it’s how your bike was meant to look.
MotoPerformance
TX1911fan screwed with this post 09-15-2014 at 02:52 PM
Times are GMT -7.   It's 03:22 PM.
