Old 10-03-2005, 05:00 PM   #1
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
found oil seep. bad?? (pic included)
After cleaning up this evening, i found where there's been a seep for awhile (apparently) due to a buildup of oil and road grime.
I cleaned it off and will monitor it, but wanted to know if this is a big deal.
See graphic below:
http://www.datchew.com/r100/r100-engine.jpg
well, though hosted, i cannot seem to post a graphic.
tried the "[img]www.website.com[img] and tried the little button on the menu by teh smiley faces, but neither worked. you'll just have to click on the link
datchew is offline   Reply With Quote
Old 10-03-2005, 05:06 PM   #2
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,864
seems like a pushrod seal. Not a big deal. Sometimes, if I'm sending the bike in for a valve adjust, I'll ask them to either change it, or pound it in a little harder. It just makes my engines dirty, but it only offends my aestetics.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 10-03-2005, 05:15 PM   #3
JamesJWeg
"Speedy"
JamesJWeg's Avatar
Oddometer: 1,736
I wouldn't worry about it, but all my bikes stay dirty as hell.
James.
Hold my beer and watch this!
http://pics.jamesjweg.com
00100
JamesJWeg is offline   Reply With Quote
Old 10-03-2005, 05:24 PM   #4
BlackHoof
REMF
BlackHoof's Avatar
Oddometer: 244
Weepy Push Rod Seals
Ed Korn will sell you a tool to help pound these seals back in, which
will work unless the rubber is too old & hard.
BlackHoof is offline   Reply With Quote
Old 10-03-2005, 05:25 PM   #5
Rubber Cow
GS Dork
Rubber Cow's Avatar
Oddometer: 5,338
According to the best of BMW mechanincs there are "seeps" , "weeps" and "leaks".
You have pushrod tube leak of some type ....they are very common and easy to replace if you know your way around a torque wrench and a Clymer manual. You'll need to remove the cylinder, change the pushrod tube seals and cyclinder o-rings. The you'll have to recompress the piston rings and re-seal the cylinder to the block followed by a valve train reassemble and adjustment and head retorque.....You can open up a can of worms or you can wipe your motor down every so often ....
It's a great job for a tech day.
Cheers,
Jorge
"He had that rare weird electricity about him--that extremely wild and heavy presence that you only see in a person who has abandoned all hope of ever behaving"normally"."
HST-RIP
"Woof, woof woof woof ...woof woof!!!!!!!!!"
Cricket the Dog-RIP
Rubber Cow is offline   Reply With Quote
Old 10-03-2005, 06:01 PM   #6
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,965
Pushrod tube seals are simple to replace, and can be done without completely removing the cylinder from the bike. Go to www.airheads.org and check out the tech resources and links.
"I'd rather wake up in the middle of nowhere than in any city on Earth."
Steve McQueen
Bigger Al is offline   Reply With Quote
Old 10-03-2005, 07:12 PM   #7
Rubber Cow
GS Dork
Rubber Cow's Avatar
Oddometer: 5,338
Ah yes...the lazy way....I've done this twice and regretted not doing it right with both.
To each their own.
Cheers,
Jorge
HST-RIP
Cricket the Dog-RIP
Old 10-03-2005, 08:09 PM   #8
ducsingle
ducsingle's Avatar
Oddometer: 521
On the later model airheads, I don't think you can tighten the pushrod seals by banging on the pushrod tube rings as the rings are brazed to the tubes. On the earlier airheads this was an option though.
If you recently switched to synthetic oil, switch back to dino-juice and see if the weep goes away after a couple of oil changes. The PO of my ST switched to Mobil 1 and the seals started leaking. I went back to standard stuff and everything was okay.
ducsingle is offline   Reply With Quote
Old 10-04-2005, 04:51 AM   #9
elmoreman
takin' a break, boss
elmoreman's Avatar
Oddometer: 1,768
How Much?
No need to repeat where the leak is coming from, but I suggest you get some kind of manual - this is an extremely common seep. I had a '71 /5 that used to spit oil on my left boot, but it was worse over 60 mph and when the oil level was topped up. I would suggest that if you dont notice any oil dripping underneath the bike when parked or on your boot (or flip flops) when riding, leave it alone. Its not unusual for things to get worse when you try to fix them. From what I understand, the "bang it in a little more" trick works pretty well, too.
elmoreman is offline   Reply With Quote
Old 10-04-2005, 04:56 AM   #10
Rubber Cow
GS Dork
Rubber Cow's Avatar
Oddometer: 5,338
Yep. The later models have a brazed collar on the push rod tubes that presses against the seal. I've never found that tapping this version stops leaks. The synthetic tip is key. Go for plain old 20/50 dyno-oil and you'll likely not have as many seeping problems on these motors.
HST-RIP
Cricket the Dog-RIP
Old 10-04-2005, 05:41 AM   #11
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,475
You can't tap in the later model pushrod seals. And it was a temp fix on the ones you could, the seals get hard and just don't seal well. To replace them is about a hour to and hour and a half each side. You will need new cylinder and stud o rings and head gaskets besides the seals themselves, they are the cheap part. Check out snowbums website for a complete description of the work. Many folks decarbon their heads and piston tops every couple of years so its a good time to do that also. I don't know how many miles are on the bike but new piston rings are also a idea if it's got more that 60-70 thou. JT
jtwind is offline   Reply With Quote
Old 10-04-2005, 06:28 AM   #12
Bigger Al
Bigger Al's Avatar
Oddometer: 7,965
To each their own.
Cheers,
Jorge
Sorry to offend your delicate sensibilities, Jorge. I've been doing it this way on Airheads for 20 years. If one has the time, then by all means remove the cylinder and do a thorough cleanup at the same time. De-carboning the piston, perhaps new rings and a hone, disassembly of the head, etc., are all easy jobs. The question that was asked concerned a weeping seal, which can easily and quickly be replaced, leaving more opportunity to ride.
Steve McQueen
Old 10-04-2005, 06:40 AM   #13
Rubber Cow
GS Dork
Rubber Cow's Avatar
Oddometer: 5,338
Nothing delicate and no need to apologize....sincerely or not...
I was given the same advice from two long-time experts years ago, twenty in fact almost to the month and it simply didn't work then or a few years later on another airhead. I've helped several friends with the same issue had the same results on their airheads. It has work once for me on an older airhead without the brazed collars and then it was for about a month until the weather cooled off and the rubber hardened.
Just my $.02
Cheers,
Jorge
HST-RIP
Cricket the Dog-RIP
Old 10-04-2005, 07:59 AM   #14
Malindi
Zen Adventurer
Malindi's Avatar
Oddometer: 5,420
The you'll have to recompress the piston rings and re-seal the cylinder to the block Jorge
You can remove the cylinder without removing the piston. Just keep it inside far enough to allow removal of the piston pin, but no far enough for the rings to show.
Back in YVR after riding around the world for 2 years. www.nohorizons.net
Malindi is offline   Reply With Quote
Old 10-04-2005, 09:35 AM   #15
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Well, i didn't ever expect to get so much feedback.
Most of my other questions took quite a while to get anything.
However, thanks much. I now know lots and lots on this pushrod seal.
Will get it taken care of one way or another.
2 questions:
What is tech day?
What is snowbums? Did a google, but didnt' get anything about motorcycles.
Times are GMT -7.   It's 06:24 AM.
