Old 10-04-2005, 12:44 PM   #1
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,114
Is my Ohlins shot?
Got it in the mail last night, its used and is going into my R100GS.
When I turn the remote preload knob there is no resistence.... seems like the similar Ohlins I had on a '88 Ducati F1 that I used to have did have a fair amount of resistence.....
Time for a rebuild???????
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 10-04-2005, 02:43 PM   #2
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,582
My Ohlins did this when the nitrogen pressure leaked out. 1st step is to give it a fresh charge of N2.
Personally, if it's a used shock, I would change the oil and give it fresh N2 before you put it in the bike.
-Jeff-
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 10-04-2005, 03:41 PM   #3
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,114
Thanks for the advice...
Pulled off the preload and it's leaking.... off the shop!
R65LazaruS
Old 10-04-2005, 03:55 PM   #4
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,582
Yup. Sounds like all new seals & bushings are in order.
BTW, if you've never rebuilt a shock, it's not the rocket science that many shops would have you believe. If you can get the spring off, the rest of it can usually be done with tools you have in the garage. The only tricky part is bleeding all of the air out, and you can generally rig up a homemade tool for that. Pressing a new bushing in the seal head is easiest with a press, but can also be done in a vice with a little care.
I got tired of running to the shop for N2 every time I changed my shock oil, so I bought a tank and regulator. I drilled the little rubber charging diaphragm out of my Ohlins and put in a regular shrader valve.
Getting Ohlins parts can be a PITA. I'm not sure if there is a knowlegeable shop out there that sells just parts. The last time I needed something, I ended up contacting Ohlins USA.
-Jeff-
Old 10-04-2005, 09:27 PM   #5
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,144
The other aspect that's a bit tricky (besides releasing the spring) is knowing how to make changes to the shim stack if you ever need to change the basic internal dampening. Not rocket science but experience does come into play and can speed up the process of getting it dialed in.
JJ
The hidden harmony is found with joy, while the obvious brings indifference.
The farther you enter into the Truth the deeper your conviction for truth must be.
There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline   Reply With Quote
Old 10-05-2005, 07:51 AM   #6
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,582
JJ
Agreed. I will leave that to the pro's. I don't have the time or inclination to experiment around to get the right valving. That's something best left to a guy who has dialed this in on many other bikes. Most of the valvers consider it a art. Very few apply much science to it.
-Jeff-
Times are GMT -7.   It's 12:46 PM.
