Old 10-05-2005, 07:14 AM   #1
Steverino OP
Arrogant Horse's Ass #1
Oddometer: 36,668
Does Your Scooter Ping?
Ad if it does will running a higher octane fuel stop it?
Steverino is offline   Reply With Quote
Old 10-05-2005, 07:31 AM   #2
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,311
You are a funny dude.
2T scooters will ping from excess carbon build-up, too much ignition timing, too little octane, or from being jetted too lean. Any other questions?
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
"bueller, you ARE an island of reason in a sea of bullshit" - quasigentrified
Bueller is offline   Reply With Quote
Old 10-05-2005, 07:32 AM   #3
Steverino OP
Oddometer: 36,668
Will increasing the octane rating decrease the incidence of pinging?
Old 10-05-2005, 08:51 AM   #4
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,311
That depends on the cause. Pinging can be caused by several factors, so to answer your question you must know the cause of the ping. If the ping is coming from compression-induced spontaneous ignition, higher octane fuel will help. If it is caused by another ignition source (such as a hot spot or carbon build-up) higher octane will probably not help.
Compression-induced pinging can be caused by too much compression for a particular octane rating, or by having the timing too far advanced. The first one is easy to understand, but the timing issue gets a little more complex. In the case of over-advanced ignition timing here is what happens. The piston is still approaching top dead center, compression is heating the mixture. If the spark plug lights it off too early the additional increase in pressure from the burn combined with the fact that the piston is still rising will cause whatever portion of the mixture that is not yet burning to spontaneously detonate. The noise you hear is caused by the two flame fronts meeting. If left unchecked it can do massive damage.
Higher octane will fix pinging caused by higher static compression. But it will only fix the symptom of pinging in the case of over-advanced ignition timing, and even if higher octane gets rid of the pinging you are still going to have to deal with the extra heat generated by the advanced timing, something that has been known to cause seizure in 2t engines. A better solution would be to properly dial in the timing.
How 'bout a tall glass of koolaid?
Old 10-05-2005, 09:03 AM   #5
Photog
Charismatic Megafauna
Photog's Avatar
Oddometer: 46,308
Um
Uh, Steverino, mine pings because I'm a dumbass about this kind of stuff.
Jeebus, it's got 4 moving parts in the motor (literally) and it's still over my head.
Only an XR1200 owner knows why Cthulhu hangs its head out a car window.
Like I like. Yep.
Photog is offline   Reply With Quote
Old 10-05-2005, 01:53 PM   #6
ilmostro
Under Da Sea
ilmostro's Avatar
Oddometer: 29,256
No.
I've got stay the fuck out of it written on a stone tablet in my bedroom. - Con Stapleton
ilmostro is offline   Reply With Quote
Old 10-05-2005, 01:54 PM   #7
Rad
Just me
Rad's Avatar
Oddometer: 12,176
Only the ones that say BMW on the side, ping
Rad is offline   Reply With Quote
Old 10-05-2005, 03:25 PM   #8
GearWhore
Running fans the flames
GearWhore's Avatar
Oddometer: 477
Does your Scooter ping?
No, but it does Ring and Ding.
Gear Whore
GearWhore is offline   Reply With Quote
Old 10-05-2005, 05:15 PM   #9
VespaFitz
No-good-son-of-a-bitch
VespaFitz's Avatar
Oddometer: 41,051
Gear Whore
Mine sort of ning-ning-nings.
My other car was crushed by the Feds
AKA "Ham Steak" - Bumfucked Hillbillies MC
VespaFitz is offline   Reply With Quote
Old 10-05-2005, 06:08 PM   #10
ilmostro
Under Da Sea
ilmostro's Avatar
Oddometer: 29,256
Thanks Revvy
Old 10-05-2005, 06:13 PM   #11
Photog
Photog's Avatar
Oddometer: 46,308
150db of Two Stroke Froggy.
Damn, I need to get some packing in that JL exhaust.
Like I like. Yep.
Times are GMT -7.   It's 03:09 AM.
