Ducati is airing Episode 4 of its Ducati World Premiere 2022 series.  This time around, Ducati is showing off two new Streetfighter models, the Streetfighter V2 and the “uber exotica” Streetfighter V4 SP.  As is the case with its previous episodes, a video provides information on both machines.  This time around, the video is nearly 22 minutes long.
But if you don’t have the time to watch it all, here are some of the specs for both of the new Streetfighters.
V2 Streetfighter
  • Engine: 955 cc Superquadro V-twin engine (bore & stroke – 100 X 60.8 mm)
  • Power: 153 hp at 10,750 rpm and 75 lb-ft (101.4 Nm) of maximum torque at 9000 rpm.
  • Euro 5-approved shares the exhaust of the Panigale V2
  • Fuel Injection: 62 mm throttle bodies controlled independently with a full Ride by Wire system
  • Six-speed gearbox with quick shifter
  • Frame: Moocoque aluminum
  • Front Suspension:  Showa fully adjustable BPF 43 mm fork.
  • Front Wheel:  5 spoke, light-alloy
  • Rear suspension: Fully adjustable Sachs mated to an aluminum single-sided swingarm.
  • Rear Wheel: 5 spoke, light-alloy
  • Front Brake: Dual 320 mm semi-floating discs with radially mounted Brembo Monobloc M4.32 4-piston calipers with Bosch Cornering ABS EVO.
Ducati Streetfighter V2
The 2022 Ducati Streetfighter V2.
V2 Continued
  • Rear Brake: 245 mm disc with 2-piston caliper and Bosch Cornering ABS EVO
  • Wheelbase: 1,465 mm
  • Tires: Pirelli Diablo Rosso
  • Display 4.3 inch TFT color
  • Dry Weight: 392 pounds (178 kg)
  • Kerb Weight: 441 pounds (200 kg)
  • Fuel Capacity:  4.5 gallons (17 l)
  • Safety Equipment: Riding modes, power modes, Bosch Cornering ABS EVO, Ducati Traction Control (DTC) EVO 2, Ducati Wheelie Control (DWC) EVO, Engine Brake Control (EBC) EVO, Auto Tire Calibration
  • Standard Equipment:  Ducati Quick Shift (DQS) up/down EVO 2, Full LED lighting with Daytime Running Light (DRL), Sachs steering damper, Auto-off turn indicators
  • Maintenance Service Intervals: 7,500 miles (12,000 km) / 12 months
  • Valve Clearance Check Interval: 15,000 miles (24,000 km)
  • MSRP: $16,995
 V4 SP Streetfighter
  • Engine: 1,103 cc V-4 Desmosedici Stradale 90 degree, rearward rotating crankshaft with 4 desmodromically actuated valves per cylinder.  (bore & stroke – 81 X 53.5 mm)
  • Power: 208 hp at 13,000 rpm and 90.4 lb-ft (123 Nm) of maximum torque at 11,500 rpm.
  • Fuel Injection: Twin injectors per cylinder with full ride-by-wire elliptical throttle bodies
  • Six-speed gearbox with up/down quick shifter EVO 2
  • Frame: Aluminum alloy “front frame.”
  • Front Suspension:  Öhlins NIX30 43 mm fully adjustable fork with TiN treatment.  Electronic compression and rebound damping adjustment with Öhlins Smart EC 2.0 event-based mode.
  • Front Wheel:  5-split spoke, carbon fiber 3.5″ X 17″ with Pirelli Diablo Rosso Corsa II tire.
  • Rear suspension: Fully adjustable Öhlins TTX36 with electronic compression and rebound damping adjustment and Öhlins Smart EC 2.0 event-based mode mating to an aluminum single-sided swingarm.
  • Rear Wheel: 5 split-spoke carbon fiber 6″ X 17″  with Pirelli Diablo Rosso Corsa II 200/60 ZR17
The Ducati Streetfighter V4 SP.
V4 SP continued
  • Wheelbase: 1,488 mm
  • Display: Last generation digital unit with 5-inch TFT color
  • Dry Weight: 390 pounds (177 kg)
  • Kerb Weight: 432 pounds (196 kg)
  • Fuel Capacity:  4.23 gallons (16 l)
  • Safety Equipment: Riding modes, power modes, Bosch Cornering ABS EVO, Ducati Traction Control (DTC) EVO 2, Ducati Wheelie Control (DWC) EVO, Engine Brake Control (EBC) EVO, Ducati Slide Control DSC, Auto Tire Calibration
  • Standard Equipment:  Ducati Power Launch (DPL) Ducati Quick Shift (DQS) up/down EVO 2, Full LED lighting with Daytime Running Light (DRL), Ducati Electronic Suspension (DES) EVO with Öhlins suspension and steering damper, Quick adjustment buttons, Auto-off turn indicators, Carbon Fiber Wheels, Carbon Fiber front mudguard, Wings in carbon fiber, adjustable aluminum rider footpegs with carbon fiber heel guard.
  • MSRP: $35,500
All photo credit: Ducati
