    Dismiss Notice
~£}*~{{*{^\|££***!!! Tire help please.
Discussion in 'The Garage' started by Carlo Muro, Mar 10, 2018.
  1. Carlo Muro
    Carlo Muro Herr Schadenfreude
    May 2, 2008
    4,607
    Tropic of Sir Galahad
    This thing has been kicking my poor butt all day. Friggen lawn mower tire. The old one was a giant PITA to unseat and remove. I ended up using a bottle jack to unseat the bastard. Finally got it off the wheel. Then the new one fought me tooth and nail getting it mounted. I thought I finally had it licked. Now I can't seat it. I've tried the old brake cleaner on fire trick at least 5 times-- nearly burnt the garage down on the final attempt--, the rachet strap trick, everything I could think of. The thing is, as you can see, this tire was distressed in shipping or storage and it's flat on the bottom. I didn't think it would matter but that seems to be what's stopping it from seating. Any ideas? SO thinks I'm an idiot for not taking it to a tire shop and blowing a whole Saturday on it. Perhaps she's right.
  2. gonerydin
    gonerydin Been here awhile
    Feb 14, 2012
    565
    Iowa, USA
    “Brake fluid on fire trick”? Maybe try starting fluid?
    sieg, phreakingeek and FormerOilhead like this.
  3. lnewqban
    lnewqban Ninjetter
    Jan 22, 2012
    1,047
    Florida
    We need to have one side to be seated (as good as possible) in order to have more air rushing through the not seated side.
  4. Carlo Muro
    May 2, 2008
    4,607
    Does it actually matter? I thought the idea was burning something flammable around the rim caused a pressure difference which seated the tire? No? Worked on YouTube
  5. S2P
    S2P Been here awhile
    Feb 14, 2009
    983
    Doylestown OH-IO
    You tried my usual tricks, did you remove the core from the valve stem? I have had some sucess with blowing a blast of air in and then put the core back in after it inflates a little. My last one was with a leaf blower and a little rim and the tire sat flat for a year, had to take it to the tire shop and they put the glue slop on it. I could not get it to seal because of the flat spot.
    lnewqban likes this.
  6. gmk999
    gmk999 ____ as a Rotax
    May 2, 2011
    5,359
    New England
    put a tube in it.
    For a few bucks it will fix your issue and you can always take it out in a few weeks once the tire is trained round again.
    kantuckid and REDBEN like this.
  7. EnduroRdr
    EnduroRdr Woods Racer & D/S Rider
    Feb 15, 2008
    2,722
    Formerly BR-LA, LR-AR, Houston-Tx, now South MS
    I think I’d avoid the poof tricks (lighting WD40, brake fluid and especially starting fluid ), your emergency room bill will be a lot more than the tire shop bill. Worse if garage or truck goes up in flames!
    If the ratchet strap trick no worky then maybe go buy an inner tube.
    Or just say uncle and take it to tire shop.
    I know that’s tuff, would kill my ego after spending most of Saturday on it. Kinda ruins the challenge admitting defeat!
    Carlo Muro likes this.
  8. gonerydin
    Feb 14, 2012
    565
    Iowa, USA
    I’ve never even heard of using brake fluid. Starting fluid (ether) will work if you know what you are doing. Also helps if the tire is warm. If you are working in cold temps, it will be more difficult.
    #8
  9. Carlo Muro
    May 2, 2008
    4,607
    No tube. The valve stem was in. I'm going to take it out later and try that.
    #9
  10. lnewqban
    lnewqban Ninjetter
    Jan 22, 2012
    1,047
    Florida
    The flammable liquid should go inside the tire, not only around the rim.
    Also, use as much lube as possible.
    #10
    dtysdalx2, outty and Carlo Muro like this.
  11. Carlo Muro
    May 2, 2008
    4,607
    Correction... brake cleaner. Not fluid. Been a long day.
    rr
    #11
  12. PineyMountainRacing
    PineyMountainRacing Oops....
    Jul 2, 2008
    6,296
    Sarasota, FL / Sylva, NC
    Be careful with the ether, it works well, but if you use too much you can melt the valve stem.
    #12
    Carlo Muro and lnewqban like this.
  13. Carlo Muro
    May 2, 2008
    4,607
    This. Got it. I wasn't spraying enough inside.
    Thanks for the replies.
    #13
  14. Carlo Muro
    May 2, 2008
    4,607
    You can say that again. I see why the guy in the video did his while mounted. Mine came up off the floor and pinched the long-nosed Bic between the tire and the rim. I can't imagine the pain had it been my finger.
    #14
    lnewqban and gmk999 like this.
  15. gmk999
    May 2, 2011
    5,359
    New England
    I sure hope you took video.. It’s been a slow day here (hint)
    BTW, was the SO impressed ? cause in the end that is all that matters. LOL
    #15
  16. Carlo Muro
    May 2, 2008
    4,607
    Her reply was "yeah I knew you could do that. I saw it on that Alaska show..."
    #16
    rubline likes this.
  17. gmk999
    May 2, 2011
    5,359
    New England
    Bwahahahaha!! She’s a keeper!
    #17
  18. gusthedog
    gusthedog Been here awhile
    Sep 15, 2008
    223
    So did you get the tyre on or burn your shed down and remove your eyebrows in the process?
    TTR and Land Rover tragic...
    #18
  19. Carlo Muro
    May 2, 2008
    4,607
    Tyre's on, shed intact. Eyebrows were questionable there for a second.
    #19
    gusthedog, gsweave and Yinzer Moto like this.
  20. Yinzer Moto
    Yinzer Moto Sloppy 300 rider Supporter
    Jun 13, 2008
    39,356
    Pittsburgh PA
    I just put 4 new tires on the tractor last night. Friggin bastards were difficult to break the beads on. Like you, the fronts were difficult to get to seat. I was able to shoot enough air through the valve stem, with the core removed, to make it work.
    #20
    lnewqban and Carlo Muro like this.
