    Dismiss Notice
~£}*~{{*{^\|££***!!! Tire help please.
Discussion in 'The Garage' started by Carlo Muro, Mar 10, 2018.
  1. rubline
    rubline Coddiwomple
    Mar 20, 2012
    365
    Gray Maine
    I work at a auto repair shop and get a few of these issues every year. After 30 seconds with a tire machine and lots of air pressure the tire is seated on the rim and the owner of the tire is
    :eek2
    Having the right tools is great.
    #21
    Bigger Al likes this.
  2. Carlo Muro
    Carlo Muro Herr Schadenfreude
    May 2, 2008
    4,607
    Tropic of Sir Galahad
    You has tools but I has fire
    :super
    #22
  3. dtysdalx2
    dtysdalx2 Only a matter of time.
    Aug 1, 2004
    26,460
    Moneyapolis, MN
    Saw a bead seater at Northern Tool yesterday. Air tank with a large valve looks like a vacuum cleaner. Wonder if they actually work. :hmmmmm
    #23
    Carlo Muro likes this.
  4. S2P
    S2P Been here awhile
    Feb 14, 2009
    983
    Doylestown OH-IO
    Yes they work well. One of the school systems I go to,I watch the guys seat bus tires with one. I don't do enough tires to have one laying around taking up shop space.
    #24
  5. MotoChris521
    MotoChris521 motominded
    Aug 30, 2007
    3,269
    south west
    We had one at the stealership . Priceless when you needed it .
    They are pretty cheap . Like $60 and up .
    #25
    Bigger Al and lnewqban like this.
  6. Carlo Muro
    May 2, 2008
    4,607
    My guess is that shops that take money use these because the "ring of fire" is likely not an OSHA sanctioned practice.
    #26
  7. gsweave
    gsweave Yinz, blinkers are on, JACKWAD! Super Supporter
    Apr 2, 2005
    23,225
    The Paris of Appalachia
    #27
  8. mitchntx
    mitchntx Visit The wick in Seattle
    Apr 21, 2016
    995
    Texas
    Ahem ...
    Spray inside the tire, then spray a line leading from the tire on the garage floor several feet away.
    Light the end of the line of fluid.
    Works like a fuse.
    Tire and flame is a "safe" distance away.
    Caution:
    If you didn't put enough fluid in the tire carcass to generate the necessary pressure to seat the tire, don't immediately spray more fluid.
    Bad things might occur. Let it cool a bit.
    Don't ask how I know this.
    also, before trying this, it would be a good time to check if your fire extinguishers are fully charged.
    #28
    lnewqban and phreakingeek like this.
  9. ragtoplvr
    ragtoplvr Long timer
    Oct 18, 2007
    11,352
    central USA
    Slime will make rim rust. So I always use a fube. Then add slime. No more leaks. Last fall saw some green. Stoped and pulled out a big thorn. Sealed right up. Plus I can run nice low pressure for less lawn compaction.
    Rod
    #29
  10. MechReclined
    MechReclined Adventurer
    Nov 27, 2014
    32
    I use my clear grease. Slather enough in gap to seal the tire. Air up and wipe off. Back in can it goes. Not used for very much else.
    #30
  11. Mike Ryder
    Mike Ryder Kriegerkuh Supporter
    Oct 11, 2003
    1,604
    Peachland B.C. Canada
    Burning brake cleaner will kill you!!
    #31
    drbike likes this.
  12. mitchntx
    Apr 21, 2016
    995
    Texas
    Yes, some will.
    Not all give off phosphene gas, though.
    It is prudent to stand back ... another reason for the "fuse"
    My assumption was some level of competence in a shop environment.
    #32
  13. kantuckid
    kantuckid Long timer
    Nov 29, 2007
    9,947
    Kentucky-Eastern that is!
    After reading all that "playing with matches crap"- just do the tube and avoid a tire that easily looses air.
    #33
