‘12GSA shifter adjustment
Discussion in 'GS Boxers' started by ADKGsa, Oct 11, 2019.
  1. ADKGsa
    ADKGsa Been here awhile
    Jun 20, 2019
    112
    NY
    Does anyone know what the correct way to adjust the shifter position on a cam head GS is? Is it fine to remove the screw and move it on the splines or should this adjustment be made with the linkage? I notice there is a mark on spline shaft where it lines up with the gap on the shifter where you bolt it on.
    I would like to move the shifter just a hair higher to make more room for my boot. Thanks
  2. JimVonBaden
    Feb 11, 2005
    87,895
    Alexandria, VA
    Both are acceptable, so long as you maintain clearance for movement. Shifting a spline moves a lot, linkage adjustments can fine tune.
    Axon man likes this.
  3. ADKGsa
    Jun 20, 2019
    112
    NY
    Copy that Jim.
    I posted the question because I thought I read somewhere that BMW didn’t want the shifter moved on the splines for some reason but I couldn’t find that again when I searched.
  4. JimVonBaden
    Feb 11, 2005
    87,895
    Alexandria, VA
    It is possible to move the shifter on the splines , not sure why they would recommend against it.
    Before and after 1 tooth:
    In your case, using the linkage would likely give you the adjustment you need. How to fine adjust.
    Zurgg likes this.
  5. TTJosh
    TTJosh Adventurer
    Jun 26, 2018
    41
    Maryland
    JVB with the win...again. I had no idea.
    FWIIW I just move it up one / down one.
  6. Sunosauno
    Sunosauno Adventurer
    Aug 8, 2019
    49
    Bali
    +1
