’18 Gas Gas Contact 250 With “E” Start. Motobene’s Lights?
Discussion in 'Trials' started by Harry Potter, Aug 24, 2018.
  1. Harry Potter
    Harry Potter Been here awhile
    Oct 27, 2010
    520
    Comes with a bigger tank, seat, and the ”E” button start. Has anyone tested it? Seems to me with the the E start it should have the goods to run Motobene’s lighting system. I’ve thought a lot about a Beta 300 4 stroke in the sport model (bigger tank & seat) but the Contact is thousands less.
    DyrWolf likes this.
  2. jonnyc21
    jonnyc21 Trials Ninja
    Feb 8, 2011
    3,380
    Boise aria
    Not yet that I know of.
    However there is a likelihood that even if the power isn’t 100% clean it would be a great deal smoother than a standard with the battery system.
  3. Harry Potter
    Oct 27, 2010
    520
    I guess there doesn’t seem to be much interest in this bike.
  4. lamotovita
    lamotovita DAMN SNOWBIRD!
    Oct 5, 2007
    2,709
    WA/AZ, USA
    I was interested enough to go look at one at my local dealer, that was all it took for me to label it a P.O.S. and walk away.
  5. 10K
    10K Trail Runner
    Sep 5, 2004
    2,471
    Arizona
    P.O.S is pretty harsh, check out the video.
  6. lineaway
    lineaway Long timer
    Oct 1, 2011
    9,351
    nm
    I actually saw one at the Ute Cup. It was never unloaded in the three days I was there. It will last years with that amount of riding.:imaposer
    Brewtus likes this.
  7. It's not a horrible bike. It's a normal GG frame and motor with a lot of other budget parts attached to it. Given what it costs this isn't a huge surprise.
    10K likes this.
  8. Takataka
    Takataka Been here awhile
    Sep 26, 2014
    396
    NZ
    Mate of mine has one. It seems to work well and at the level we ride I don't think it's "inferiority" has ever really been exposed...
    #8
    10K likes this.
  9. Yard Sale
    Yard Sale let's be bad guys
    Jan 17, 2008
    3,529
    Northern Nevada
    The seat mounting is a joke and I don't see how anyone else's is going to last much longer than mine did, a few hours. The big tank is nice, good for about two hours. Search this forum only for "Contact" in thread titles and you'll see more about them.
    #9
    Harry Potter likes this.
  10. motobene
    motobene Motoing for 49 years
    Mar 9, 2013
    5,776
    Wichita Mountains SW Oklahoma
    Well fingers crossed and I don't want to get too excited just yet, but I just quick tested a very affordable AC-DC power converter with my Motobene light that worked flicker free on tge 125, which has the roughest AC.
    Will bang away on it on two different bikes tonight. Light quality is obviously excellent. The DMM shows near zero volts AC on the output. If this proves reliable I'll finally have a light for all the carbureted bikes, including the Contact.
    What puzzles me about the Contact is one would think a 250 with a magic button would be a highly desirable innivation for a full competition bike. Makes me wonder if they think the simple direct-to-flywheel design won't hold up in competition? Restarting a stalled bike while balance in a section would be way cool.
    #10
  11. Hoss Cartright
    Hoss Cartright 219.474.6657
    Oct 23, 2016
    572
    Galapagos Islands
    Just wait.... it will happen....
    #11
  12. Hoss Cartright
    Oct 23, 2016
    572
    Galapagos Islands
    When they were working on this, "we" went around and around about this. The GG bikes lost the rear "sub-frame" after the 1999 model year.
    The ergos are simple. when sitting, depending upon the height of the rider, the entire weight of the upper torso is placed somewhere upon the saddle at the rear just above the center of the rear axle. Well behind the end of the actual chassis. Depending upon the riders weight and the speeds and terrain, this can put a huge load upon that rear portion of the saddle.
    The only proper way to do this is to add a rear sub-frame of some kind. (braces to support the rear of the saddle.)
    We had discussed having struts that actually attached to the rear of the footpeg mounting bolts, and ran up the sides of the chassis into a loop under the rear of the saddle. Of course this would bulge the sides of the bike and also had to clear the outside of the silencer on the right side. It made sense by design, but also didn't make sense by practicality.
    What you have is all of that weight and force applied to that aluminum bracket in the front of the saddle. And that bracket actually attaches to the chassis with two 6mm counter-sunk Allen bolts that are threaded into "clip nuts" and it simply does not work well, and over time things are going to break... And the rear attaching bolt is put into the "PLASTIC" air-box. so, we know that is not strong.
    Ultimately, putting a long saddle on a trials bike that has no rear sub-frame loop just doesn't work well.
    #12
    Nobade likes this.
  13. motobene
    Mar 9, 2013
    5,776
    I believe so too. Some light batteries, maybe just enough Amp hours for a couple of starts in between some charging time....
    And no more splitting of stators between ignition and light/fan please! Three-phase alternators are a more elegant way to make AC.
    And throw a counterbalancer in there somewhere. All the added hardware in 2-stroke format could still wave the weight come in below 70kg me thinks.
    #13
  14. Norman Foley
    Norman Foley Devotee of the Husqvarna Supporter
    Mar 20, 2004
    2,822
    New York... The Finger Lakes
    #14
    laser17, jonnyc21 and Hoss Cartright like this.
  15. motobene
    Mar 9, 2013
    5,776
    Turn the alternator into a motor so no separate starter is needed?
    Interesting!
    #15
  16. laser17
    laser17 Long timer
    Mar 6, 2008
    1,453
    Boston,Massachusetts
    I wonder when we will see electric snowmobiles?
    #16
  17. 2whlrcr
    2whlrcr gooligan
    Jan 30, 2005
    13,034
    Dubuque, Iowa
    Lol
    #17
  18. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    3,144
    Upper Michigan
    It has been done before on 70,s Japanese dual sport bikes.I forget which models but believe it was suzuki.Tangled with a few in my younger days buying used beaters to fix up.Sort of remember yamaha had them on a few bikes also.I also remember I never could get them to work once they were broken.
    #18
    Norman Foley likes this.
  19. motobene
    Mar 9, 2013
    5,776
    Yamaha AT-1 had the magic button and a more bulbous magneto-area cover. I thought maybe it was a DC motor just left of the alternator. Can't remember exactly, but it did have brushes. The CT (175) and DT (250) models did not have the magic button because of lack of starting umph.
    #19
    Norman Foley and Junglejeff1 like this.
  20. Norman Foley
    Mar 20, 2004
    2,822
    The question is..... can it be done again?
    #20
