007, A Laverda 1200 Story
Discussion in 'Some Assembly Required' started by G 981, Dec 3, 2018.
  1. G 981
    G 981 Been here awhile
    Sep 7, 2010
    767
    West of Glaschu
    At last!
    007's cases arrived this afternoon.
    I'm pretty pleased with the laser weld repairs.
    The cracked upper rear engine mount is solid, the hole where the chain punched through the upper half has been filled, and new bottom engine mount lugs fabricated and laser welded in place.
    Still waiting on the barrels and pistons to come but at least I can start the bottom end rebuild when I find the time.
    [​IMG]2019-05-15 13.54.13 by Grant Duguid, on Flickr
    [​IMG]2019-05-15 13.53.35 by Grant Duguid, on Flickr
    [​IMG]2019-05-15 13.52.10 by Grant Duguid, on Flickr
    [​IMG]2019-05-15 13.51.34 by Grant Duguid, on Flickr
    overlander, JagLite, busa1300 and 5 others like this.
  2. G 981
    Sep 7, 2010
    767
    West of Glaschu
    Had a run out on a bike I just finished. Some running-in miles before first service and re-torque the head.
    Difficult job but somebody has to do it.
    [​IMG]2019-05-15 09.09.43 by Grant Duguid, on Flickr
    JagLite, Bowler, busa1300 and 7 others like this.
  3. G 981
    Sep 7, 2010
    767
    West of Glaschu
    waveydavey, JagLite, Scoozi and 4 others like this.
  4. nickguzzi
    nickguzzi Long timer
    Feb 17, 2010
    7,660
    below the sea
    We're here for emotional support if needed.
    Pecker up. (UK version)
  5. G 981
    Sep 7, 2010
    767
    West of Glaschu
    JagLite, MZRider, Fast Idle and 3 others like this.
  6. G 981
    Sep 7, 2010
    767
    West of Glaschu
    JagLite, Scoozi, Cogswell and 5 others like this.
  7. c1skout
    c1skout Long timer
    Sep 29, 2009
    1,535
    Western PA
    It's great that the case could be saved with the laser welding.
    chris a and villageidiot like this.
  8. G 981
    Sep 7, 2010
    767
    West of Glaschu
    Yes. I have another case to try to save.
    Cracked cross the main bearing seat, previous bodged weld that seems to have cracked again.
    Further complicated due to being an oilway as well.
    Will send it off next week.
    [​IMG]2019-04-16 10.20.26 by Grant Duguid, on Flickr
    [​IMG]2019-04-16 10.20.53 by Grant Duguid, on Flickr
    [​IMG]2019-04-16 10.21.02 by Grant Duguid, on Flickr
    Must have run very badly. Co-incidentally, or not, the small end bush literally fell out of the conrod at this cylinder.
    JagLite, nickguzzi and chris a like this.
  9. Fubars
    Fubars What would Scoobydo?
    Aug 20, 2003
    2,173
    Ventuna, CommieFornia
    That motor got cained pretty good.
  10. G 981
    Sep 7, 2010
    767
    West of Glaschu
    They are incredibly tough engines and can stand dogs abuse but some DPOs seem hell bent on torturing them.
    By the way, this leetle beauty turned up today. Very cute and very rare.
    [​IMG]2019-05-26 11.15.54 by Grant Duguid, on Flickr
    local1, Fubars, JagLite and 4 others like this.
  11. chris a
    chris a Been here awhile
    Oct 22, 2011
    243
    Southern France
    Nice !
  12. G 981
    Sep 7, 2010
    767
    West of Glaschu
    One of 6 second series Formula 500 imported into the UK by Slater Bros (the UK importer at the time).
    Has forged pistons and a close ratio box (60mph in first).
    First series had one piece tank/seat and second series had them separate.
    Original Menani clip-ons, almost zero steering lock.
  13. G 981
    Sep 7, 2010
    767
    West of Glaschu
    JagLite, Rick4003, chris a and 2 others like this.
  14. G 981
    Sep 7, 2010
    767
    West of Glaschu
    JagLite, grub61, nickguzzi and 6 others like this.
  15. G 981
    Sep 7, 2010
    767
    West of Glaschu
    L84dinr, waveydavey, Scoozi and 3 others like this.
  16. Scoozi
    Scoozi Been here awhile
    Jun 6, 2016
    976
    London
    I've always thought that Laverda built very attractive roadsters, which get completely overshadowed by their more sporty cousins. The 500cc models are quite rare, I can't remember the last time I saw one. That's a nice example, with a non-stock paint job and indicators I believe?
  17. G 981
    Sep 7, 2010
    767
    West of Glaschu
    Should have a black frame and there were various colour options on the bodywork. I have seen black, light blue and red, maybe more but the Alzheimers light is kicking in.
    Apart from the very first batch of Montjuics they were all pretty much the same spec internally as the Alpino.
    First batch had a close ratio gearbox and forged pistons from the Formula 500.
    Main differences for the Montjuic vs Alpino were the straight through Sito exhaust system, no airbox and carb internal changes, oh and the fibreglass handlebar fairing and seat unit.
    The Formula 500 is a rare beast, and becoming very sought after these days. The factory ran a one make race with only Formula 500s in Italy.
    Fubars and chris a like this.
  18. Fubars
    Aug 20, 2003
    2,173
    From my experience, the brand does not matter. Torture/abuse is mandatory for alot of PO's.
  19. G 981
    Sep 7, 2010
    767
    West of Glaschu
    Back on the blue bike engine again (project Phoenix).
    Some parts arrived today that allowed me to do some more on the engine.
    Fitted new spacer and circlip to the clutch drum, fitted the primary drive sprockets and Duplex chain. Better and quieter than the previous Triplex chain fitted as standard, as this is a Mercedes timing chain.
    Then the outrigger bearing and support, and finally the primary chain casing and tensioner blade.
    Next will be to fit the alternator assembly on the other side but then things will slow down as I'm still waiting on the cylinders/pistons and I need to save up to get the damaged head (smashed guide, broken valve, damaged combustion chamber, buckled cam bucket and potentially bent camshaft) repaired.
    Poco a poco.
    [​IMG]2019-06-05 13.30.11 by Grant Duguid, on Flickr
    [​IMG]2019-06-05 14.06.05 by Grant Duguid, on Flickr
    [​IMG]2019-06-05 14.32.33 by Grant Duguid, on Flickr
    Scoozi, JagLite, AK650 and 2 others like this.
  20. G 981
    Sep 7, 2010
    767
    West of Glaschu
    Time to start the 007 engine rebuild.
    Although I'm still waiting on the cylinders and pistons I felt there was enough work to justify a bottom end build.
    Refitted all the through bolts and studs
    Selector drum and forks, tensioning mechanism and then main and layshafts.
    Crank and cam chain
    High output oil pump
    Torqued it all down
    Next step will be to build up the primary drive system.
    The bike will be up for sale when finished, but already there is interest in it.
    [​IMG]2019-06-07 09.41.11 by Grant Duguid, on Flickr
    [​IMG]2019-06-07 11.33.25 by Grant Duguid, on Flickr
    [​IMG]2019-06-07 11.33.18 by Grant Duguid, on Flickr
    [​IMG]2019-06-07 11.50.55 by Grant Duguid, on Flickr
    [​IMG]2019-06-07 10.24.15 by Grant Duguid, on Flickr
    [​IMG]2019-06-07 11.57.42 by Grant Duguid, on Flickr
    Scoozi, Steve G., JagLite and 2 others like this.
