007, A Laverda 1200 Story
Discussion in 'Some Assembly Required' started by G 981, Dec 3, 2018.
  1. busa1300
    busa1300 Been here awhile
    Feb 22, 2014
    368
    Frozen North...
    Are you using 86-87 GSXR 18 inch wheels?
    I see a lot of guys running in vintage racing that use them when rules specify 18's
    I have a set of 4 and 2.75's for one of my projects
    They look good on any older bike.
  2. fast1075
    fast1075 Not a Lemming Supporter
    Dec 28, 2013
    2,007
    Flaw'da
    I'm a fan of using Suzuki wheels too.
    local1 likes this.
  3. G 981
    G 981 Been here awhile
    Sep 7, 2010
    764
    West of Glaschu
    Yes, but availability is drying up as the early slab sided GSXRs are becoming collectable these days.
    No engineering needed for the rear wheel, just the cush drive to line up the chain run, and the disc mounts on the front wheel, plus a speedo drive mount for the helical gear needs to be fabbed up.
    Compared to a tubed crossply and solid cast iron disc-shod front it's around 3kg lighter, and the rear is around 1.5kg lighter.
    Also allows for more modern sticky tubeless radials, I use BT016s.
    Also look quite similar to the Oscams used on the SFC1000.
    [​IMG]2014-08-24 15.25.12 by Grant Duguid, on Flickr
    [​IMG]InkedInked2019-02-01 11.17.41_LI by Grant Duguid, on Flickr
    [​IMG]laverda-sfc1000-2003-moto by Grant Duguid, on Flickr
    Scoozi, Fast Idle, Steve G. and 4 others like this.
  4. Mercury264
    Mercury264 Once you go Triple...
    Nov 7, 2005
    24,815
    Masshole
    Absolutely gorgeous looking bikes :thumb
  5. Alexol
    Alexol Chronic Farkoholic
    Dec 21, 2003
    814
    South La., where I-10 has a curve. One curve.
    Is the little flyscreen perhaps Givi? What model is it please?
    Probably should have asked first whether it works or not!
    Would like just a light wind reducer for my bike, and I think my bars a re very similar to yours, Flanders something-or-other. The clip-ons look great but not comfortable at the sort of speeds I tend to ride the bike these days.
    Alex
  6. G 981
    Sep 7, 2010
    764
    West of Glaschu
    The flyscreen was a generic one bought off Ebay, no idea of the brand.
    Keeps the bugs off the back of the instruments and makes resetting the trip meter a pain.
    And that's about all it does, apart from look cool (to me at least)
    Fast Idle likes this.
  7. Alexol
    Dec 21, 2003
    814
    Thanks...
    Doesn't sound like anything to spend much time seeking out.
    Alex
  8. G 981
    Sep 7, 2010
    764
    West of Glaschu
    Finally got the parts needed to fix the internals of the Ceriani forks.
    So, I'll get on with that and finally have it back on 2 wheels for the first time in decades.
  9. G 981
    Sep 7, 2010
    764
    West of Glaschu
    So, rebuilt the Ceriani forks.
    Pretty straightforward and the new parts fitted perfectly. The piston was no longer available from stock so my friend made me a new one.
    The old one had swollen and broke up when I had to hammer it out.
    Anyway, all built up and will be installed tomorrow.
    [​IMG]2019-03-09 11.23.40 by Grant Duguid, on Flickr
    [​IMG]2019-03-09 12.14.01 by Grant Duguid, on Flickr
    [​IMG]2019-03-09 12.27.20 by Grant Duguid, on Flickr
    [​IMG]2019-03-09 12.36.42 by Grant Duguid, on Flickr
    [​IMG]2019-03-09 12.37.48 by Grant Duguid, on Flickr
    Scoozi, Bowler, busa1300 and 7 others like this.
  10. G 981
    Sep 7, 2010
    764
    West of Glaschu
    Finally got the front end finished this morning. Forks fitted and filled with oil, speedo drive greased and wheel and axle fitted.
    Started fitting the tailpiece but they always, always need finessing, so I'll finish that off another day.
    I crocked my back working on an engine that was on too low a table a few days ago and I'm still suffering, so today I went and bought lots of wood as I'm going to build a long table to work on several engines at once. Will start chopping wood tomorrow.
    [​IMG]2019-03-11 09.51.19 by Grant Duguid, on Flickr
    [​IMG]2019-03-11 10.48.57 by Grant Duguid, on Flickr
    [​IMG]2019-03-11 12.35.55 by Grant Duguid, on Flickr
    [​IMG]2019-03-11 12.37.06 by Grant Duguid, on Flickr
    local1, waveydavey, Scoozi and 5 others like this.
  11. Alexol
    Dec 21, 2003
    814
    Beautiful work! Wish you were on this side of the water - my bike would have been in line for "treatment" for a while now...
  12. G 981
    Sep 7, 2010
    764
    West of Glaschu
    Thanks Alex.
    Buy one over here, let me restore it and import it. Not as expensive as you may think to bring one to the US. I have had 4 shipped over there (2 x California, Florida and N Carolina).
  13. nickguzzi
    nickguzzi Long timer
    Feb 17, 2010
    7,522
    below the sea
    Have you every tried uprating the forks with a cartridge insert? I mean slipping the cartridge inside the original stanchions/sliders, not a fork swap.
    I replaced the guzzi forks with some Marzzochi 38mm - an improvement no doubt - but still harsh. I have heard of people using some Honda ones with no too much difficulty.
  14. G 981
    Sep 7, 2010
    764
    West of Glaschu
    Yes, I had a couple of pairs of forks converted by Maxton, good quality but pricy.
    local1 likes this.
  15. G 981
    Sep 7, 2010
    764
    West of Glaschu
    Scoozi, AK650 and Fast Idle like this.
  16. Alexol
    Dec 21, 2003
    814
    RaceTech Gold Emulators work well...
    Alex
  17. Alexol
    Dec 21, 2003
    814
    I genuinely thought about doing that, but I think it is time to thin the herd anyway, so possibly my Jota and probably the old RS may be sold. Of course, every time I go into the garage and look at them, I change my mind! The latter isn't worth enough to move the financial needle very far, and the other is just special, near unique but not to everyone's taste being a CL-ized Jota as opposed to the other way round, even if not worth a pot of gold. But the Laverda deserves to be ridden which just isn't happening.
    I've been lucky enough to have had a few bikes over the years, although very few have been the kind where you pour a wee dram of the good stuff, pull up a chair and just sit there and savor the view. The Laverda is one.
    My new RT is a wonderful motorcycle but has all the personality of a washing machine.
    Alex
    Kai Ju likes this.
  18. G 981
    Sep 7, 2010
    764
    West of Glaschu
    The brake hoses turned up but due to a communication error they sent male threaded hoses instead of female ones. No biggie, they are sending replacements FOC.
    [​IMG]2019-03-22 13.18.17 by Grant Duguid, on Flickr
    Still no word when when the crank cases or cylinder block will be ready so I moved on to the blue bike.
    Fitted modern rectangular clutch and brake m/cs and today fitted full length brake hoses. Does away with the splitter box attached to the lower yoke as the m/c has a built in pressure switch. Makes bleeding the brakes easier as less corners for air bubbles to lurk in.
    [​IMG]2019-03-23 10.43.14 by Grant Duguid, on Flickr
    [​IMG]2019-03-23 10.43.22 by Grant Duguid, on Flickr
    Rick4003, AK650, chris a and 2 others like this.
  19. G 981
    Sep 7, 2010
    764
    West of Glaschu
    Scoozi, nickguzzi, busa1300 and 4 others like this.
  20. G 981
    Sep 7, 2010
    764
    West of Glaschu
    nickguzzi, busa1300, Scoozi and 3 others like this.
