'05 640 Adventure Tools Question
Discussion in 'Thumpers' started by Gerg, Jun 6, 2005.
  1. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    4,928
    Melbourne - AU
    is Mild Steel
    as Axle Nut is low torque value.... fork pinch bolts do the work and I have actually run without a nut fer 1200kms..... oops - me bad? :loaded
    have had 20 cut.... 5 spoken for..... tag dimension from flat of nut void (giggle!) to bottom edge of tag = 25mm.
    You want me to weld some more length on?..... suggest you drill a hole in yer substrate (tyre lever) and have puddle welded..... neat!
    #41
  2. mcguyver
    mcguyver Long timer
    Dec 24, 2005
    2,167
    STRALIA
    Hey Braap
    You got any of those spanners left? If so How much posted to Brisbane?
    Cheers
    Saab :1drink
    #42
  3. bikemoto
    bikemoto Tyre critic
    Oct 24, 2004
    4,468
    Nelson, New Zealand
    Ah, well, I've just acquired an '03 200EXC. Strangely, it has the 32mm ring spanner welded onto the back of the 27mm hole as braaap! describes.
    Stranger still, the EXC doesn't have a 32mm nut, only 27mm! So those tools are getting swapped over! :lol3
    btw braaap! I've modified your tyre lever end spanner. The edges were really sharp and hurt my hands when using them. A few minutes with a file to round off the edges has made a big improvement.
    #43
  4. J Dupuis
    J Dupuis Adventurer
    Apr 27, 2005
    34
    Reading the brochure " T6 COMBO LEVER These trick tire levers are made
    from forged 7075 T-6 alumunum making them ultra lightweight and strong.
    T6 Tire Levers feature a tire spoon on one end and hex wrench on the
    other " bla, bla, bla " Larger sizes are designed to work on axle nuts of
    22, 24, 27, and 32mm" P/N 08-0289 32mm Sug. Retail 29.90 USD
    motionpro.com my $00.02
    #44
  5. FAST JACK
    FAST JACK Hardcore Dirt bIKER
    Sep 27, 2005
    119
    Missippi-Armpit of the nation
    Just bought one of these and the its the perfect tool for a front fender tube pack.
    http://www.enduroeng.com/item.asp?ItemID=15&Category=Wheel+Accessories&Placeholder=0
    And this makes sure it comes out easily.
    #45
  6. mcguyver
    mcguyver Long timer
    Dec 24, 2005
    2,167
    STRALIA
    Braap
    Are you still around. Would still like to grab on of these if possible.
    #46
