05 950 Adventure fork rebuild
Discussion in 'Dakar champion (950/990)' started by zoeper, Sep 29, 2019.
  1. zoeper
    zoeper Adventurer
    Dec 28, 2016
    55
  2. zoeper
    zoeper Adventurer
    Dec 28, 2016
    55
    Misery Goat, anydavenow and Helibee like this.
  3. zoeper
    zoeper Adventurer
    Dec 28, 2016
    55
    Helibee likes this.
  4. zoeper
    zoeper Adventurer
    Dec 28, 2016
    55
    One of the adjuster tubes didn't look good and had some hard residue on it. IMG-20190929-WA0004.jpg
  5. zoeper
    zoeper Adventurer
    Dec 28, 2016
    55
  6. zoeper
    zoeper Adventurer
    Dec 28, 2016
    55
  7. zoeper
    zoeper Adventurer
    Dec 28, 2016
    55
  8. zoeper
    zoeper Adventurer
    Dec 28, 2016
    55
    And the stronger springs. These measure 5.5mm vs the 5.2 mm springs that was installed. IMG_20190929_153748.jpg
    #8
    zedtours likes this.
  9. zedtours
    zedtours Been here awhile
    Jan 17, 2006
    686
    Surrey
    That is quite a tool, I used large circlip pliers and lever!
    #9
  10. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,236
    SWEDEN, Norsjö
    Common that the rebound adjusters are stuck on these forks.
    Good to break them apart all the way.
    Doubt that is ever done by most places if handed in for an oil change unless you specify it and you will probably pay a heafty price for it.
    /Johan
    #10
  11. zoeper
    zoeper Adventurer
    Dec 28, 2016
    55
    What else should be checked on these Forks? I plan to give everything a good cleaning and replace all seals and sliding rings. Hope the rebound adjusters clean up well enough to function again. Glad I saw the damage and didn't just do the oil change and left it.
    #11
  12. Stephen
    Stephen Long timer Supporter
    Feb 19, 2002
    3,461
    Austin, Texas, USA
    Yes, good you saw it. When I redid my 04, the dealer pointed me to the "new overhaul kit" which updates the 04 forks to the, uh, much more modern spec. Has all you need and costs less than seals and dust rings. Works great. Yours may already be updated, as the original springs are 4.8 IIRC. The kit is nevertheless the way to go.
    #12
  13. DOREY76
    DOREY76 Been here awhile
    Jun 24, 2015
    216
    WA
    I'd be checking the compression/rebound assembly whilst you're there. I also noticed some inconsistencies in my valve stacks. IMG_20181129_161338_01.jpg
    #13
  14. anydavenow
    anydavenow Long timer
    Nov 30, 2011
    1,117
    Sydney, Australia
    That is a thing of beauty, well done! Although I think you might want to rephrase that as "wanted to make a tool"—I use a $10 one of these!
    :lol3
    #14
  15. zoeper
    zoeper Adventurer
    Dec 28, 2016
    55
    Well Dave you caught me. Had the beer, the tools, the time and the materials. Also used the time to get myself "in the zone" for the job to follow. ...but yes, mostly because I wanted to! :)
    #15
    Misery Goat, Stephen and DirtyADV like this.
  16. anydavenow
    Nov 30, 2011
    1,117
    Sydney, Australia
    Haha. Well, I can only dream of having the skills to procrastinate at that expert level!
    #16
  17. zoeper
    zoeper Adventurer
    Dec 28, 2016
    55
    There is a lot of conflicting info out there on fork oil levels. Does anyone know the "proper" height? (Or what can I use as a good starting point?)
    2005 950 Adventure
    #17
  18. gearheadE30
    gearheadE30 @LC8Adventures Supporter
    Jan 20, 2012
    2,165
    Indiana
    Oil height is a tuning tool so can vary, and I usually run 100mm on my 265mm travel suspension. 90mm is the max I ever see people run, and usually the range is 120mm up to 90mm.
    #18
  19. ander2j2
    ander2j2 Adventurer
    Jun 4, 2015
    10
    Brevard, NC
    Can you link to the kit?
    #19
    mountaincadre likes this.
  20. anydavenow
    Nov 30, 2011
    1,117
    Sydney, Australia
    I also run 100mm on my 210mm forks. I can't remember where I got that from but do remember spending hours trying to find it at the time!
    #20
