'08 GS Adventure: Maintenance on side/center stand?
Discussion in 'GS Boxers' started by 200GRLSWC, Sep 17, 2019.
  1. 200GRLSWC
    200GRLSWC Been here awhile
    Apr 22, 2013
    150
    Wondering recently if I should be doing any kind of maintenance--I guess just cleaning and lube--on the sidestand or center stand of my '08 GS Adventure.
    Both are working fine, so thinking in terms of preventative maintenance. (There is a little surface rust on the cross-bar of the center stand, guess I should sand that down and paint it.)
    Thoughts?
  2. * SHAG *
    * SHAG * Unstable
    Nov 28, 2001
    5,630
    Bradford, Pa
    I would lube the moving friction areas and not worry too much
    JimVonBaden likes this.
  3. TUCKERS
    TUCKERS the famous james
    Dec 23, 2005
    19,925
    Villa Maria Sanitarium, Claremont, CA. USA
    Just a dab of lube. DO NOT squirt with WD40, is dispels the lube. I also rub down and paint my centerstand frequently without removing it, just the area that gets blasted.
  4. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    9,000
    Tacoma - ish, WA
    I look at the wire and connector for the sidestand cut-off switch to make sure that it's not too loaded up with crap and not flapping around where it's likely to get caught on something. I think I actually added an extra wire tie down there somewhere to help keep it tucked up out of the way.
