'09 F800GS Speedometer melting?
Discussion in 'Parallel Universe' started by 4jranch, Oct 23, 2011.
  1. 4jranch
    4jranch Been here awhile
    Jul 6, 2011
    944
    Brenham,Texas
    It looks like the piece with the numbers is what has wrinkled. I can't tell if that layer has two parts or is just one piece. As it is working ok for now I haven't taken it apart yet. I will try tinting the shield first. If the problem persists I will take it down and see what I can do with it. Appreciate the comments.
    #21
  2. JoelWisman
    JoelWisman Long timer
    Apr 22, 2009
    1,392
    STL, MO, USA
    It is easy to pull the instrument apart if you end up having to, easier then changing a tire. I wouldn't hesitate to do that if you end up needing to.
    #22
  3. 4jranch
    Jul 6, 2011
    944
    Brenham,Texas
    Thanks for the encouragement. If I do I will post pictures for the ones to follow.
    #23
  4. 4jranch
    Jul 6, 2011
    944
    Brenham,Texas
    With some difficulty applying to such a curved surface here is the Givi with the tint on the inner surface. I hope it will cool things down some.
    #24
  5. ERU
    ERU Been here awhile
    Nov 1, 2009
    227
    Bucharest
    Can u post a picture with your spedometer pls.
    Thx.
    #25
  6. 4jranch
    Jul 6, 2011
    944
    Brenham,Texas
    Can't see the problem in pictures. Hard to see the bubbled up face in person. Here are a couple with the hand stopped. Note the tach with no rpms.
    #26
  7. 4jranch
    Jul 6, 2011
    944
    Brenham,Texas
    Second one.
    #27
  8. 4jranch
    Jul 6, 2011
    944
    Brenham,Texas
    Took the bike to a different dealer after reinstalling the original windshield. They replaced the speedo without question, said they had seen several with the same problem.:clap
    I can tell y'all it had nothing to do with the Givi windshield as after I understood the problem it would only happen when I was riding away from the sun and it was shining directly on the speedometer face.
    Needless to say I will be taking my business to the 2nd dealer.
    #28
  9. schaffer40
    schaffer40 I look lived in.....
    May 5, 2009
    435
    Rowland Heights Ca.
    Put the stock one on and take it to a different dealer.
    #29
  10. 'Flagger
    'Flagger ..this space for rent..
    Mar 7, 2004
    2,661
    Columbus, OH
    He did. :lol
    #30
  11. LukasM
    LukasM Long timer
    Nov 15, 2006
    5,513
    On a RTW ride - currently touring the U.S.
    Did they really replace the whole speedo or just the upper cover? What a waste that would be... :eek1
    #31
  12. 4jranch
    Jul 6, 2011
    944
    Brenham,Texas
    The whole thing, they said they could not just replace the plate.
    #32
  13. LukasM
    LukasM Long timer
    Nov 15, 2006
    5,513
    That's strange, the upper bezel is the only spare part that is readily available for the speedo...
    If you have a crack in the back of the housing you need a whole new $800 assembly. :baldy
    #33
  14. lmclamore
    lmclamore Citation Collector
    Jul 9, 2010
    412
    Washington DC area
    Absolutely LukasM. My car's temp guage quit working right after the warranty expired. The service department could only recommend that my entire instrument cluster had to be replaced and reprogrammed to the tune of $1,500. And that was on a Ford made right here.
    Needless to say, I now live with the temp reading on "overheated to the max" all the time. I do have an idiot light to let me know if that is ever really true.
    #34
  15. richard weed
    richard weed Been here awhile Supporter
    May 19, 2010
    102
    Denver
    Had a "warped" speedo cover incident today. Driving home on the freeway after work and the speedo reads 50-70% off. Stop at a light, it works. Next light it doesn't. Stopped at my dealer, got the warped instrument cover story due to an aftermarket windshield. Known problem I asked? Oh yea says the service manager. I'm calling B/S on the windshield story but it was suggested to cover the speedo with a towel in hot weather/direct sunlight. That seems simple and reasonable. FYI
    #35
  16. Loufish
    Loufish Been here awhile
    Apr 27, 2016
    204
    Burbank CA
    My bezel on my 2016 F800 just melted down with a little pin hole....Told my dealer and he said no problem we'll get that replaced.....of course I do get great service....maybe it was the 200 bikes I bought from them over the last 2 years :)
    #36
  17. SnoDrtRider
    SnoDrtRider I've been lost here before...
    Mar 21, 2006
    7,170
    South Jersey... Close to the Pines
    This is more common that one would think and not just on vehicles.
    I first noticed this on vinyl siding about 10 years ago. I went to a customers house on a service call and it looked like they had put the grill a bit too close to the house except there was a bush and no access for a grill where the siding was melted.
    I attributed it to the fact that the area was in an inside corner and the sun reflecting and being concentrated in the corner caused the problem so I did a little research and found that it is common and usually from the sun reflected off of THE NEIGHBOR'S windows. In some cases 20-30 feet or more away!
    http://www.finehomebuilding.com/2012/05/17/melted-vinyl-siding
    #37
