09 F800GS won't start
Discussion in 'Parallel Universe' started by sarkmych, Aug 17, 2010.
  1. JoelWisman
    JoelWisman Long timer
    Apr 22, 2009
    1,392
    STL, MO, USA
    It wasn't the spark plugs, Your fuel injectors were stuck and when you accessed them to determine if they were squirting, you knocked them around enough to un-stick them.
    The proper method for determining if the bike is fueling is to smell tail pipe emissions while it is cranking. Don't stick your face against it cause it sucks when it back fires. Cup your hand and smell from a distance.
    When you determine no fuel is injecting, remove the left black triangle cover and tap the injectors with a screwdriver while the bike is cranking. This usually unsticks them
    #21
  2. prasta
    prasta Adventurer
    Apr 26, 2011
    64
    Cambridge, VT
    And if you can smell fuel while the bike cranks...? What do you suggest?
    #22
