1.25” thick cutting board material needed.
Discussion in 'The Garage' started by ChopperCharles, Nov 7, 2019.
  1. ChopperCharles
    ChopperCharles Long timer
    Jun 7, 2006
    5,338
    Durham, NC
    Basically, I want to make a little puck to attach to the bottom of my side stand. I put bigger wheels and tires on, and the bike leans over too much now (and it leaned over too much when stock as well, so it REALLY leans over now). I have a hole in the bottom of my side stand foot, which had enough material for me to drill and tap with M8 threads. I could just shape a puck out of plastic and bolt it on... if I could find the raw material. Any ideas?
    Charles.
  2. YamaGeek
    YamaGeek Skeletor sparklemuffin.
    Jun 24, 2007
    29,676
    western oregon
    There's this plastic used for conveyor belt guides and wear points called High Density Polyethylene
    It was used at the tandem bicycle frame builder I worked at for surfaces used to ovalize and mandrel bend CroMoly bicycle frame tubing. It's damn tough material.
  3. ChopperCharles
    Jun 7, 2006
    5,338
    Durham, NC
    Cool. That’s what I need. But finding it in small quantities appears to be a problem :/
    Which is the same issue i was running into looking for 1.25” thick aluminum bar stock.
    Charles.
  4. YamaGeek
    Jun 24, 2007
    29,676
    western oregon
    Yeah raiding your wife's HDPE cutting board maybe an issue.. Check for used ones at GoodWill or StVidePuh?
    Old Hockey Pucks?
  5. yokesman
    yokesman Long timer
    Sep 12, 2008
    2,532
    SW. Idaho
    our local plastic supplier has scrap in various thicknesses, sold by weight.
  6. CRW
    CRW I dont want a pickle
    Oct 8, 2005
    915
    Cotati Ca. USA
    why not use a skateboard wheel (or roller blade)and shave to the desired hight. Stop buy a local skate shop and they will probably give you a old wheel! Really just a trip to a hardware store and thinking out of the box will get you something cheap..
    YamaGeek likes this.
  7. Motopsychoman
    Motopsychoman Not a total poseur Supporter
    Jun 2, 2013
    5,426
    Oaklandish
    I used 1" UHMW polyethylene to make a "puck" before I decided to move the side stand mount down lower which fixed the problem. Nice thing about UHMW is it will hold threads, unlike most other plastics.
    McMaster sells pieces as small as 6"x6", but not in 1-1/4" thick.
    greasyfatman and dtysdalx2 like this.
  8. jimroid
    jimroid Long timer
    May 14, 2013
    1,102
    Pisgah Forest,N.C./USA
    Chopper, let me know what size piece you want asap. I’ll look tmrw. Black or white?
    #8
    mitchapalooza likes this.
  9. ChopperCharles
    Jun 7, 2006
    5,338
    Durham, NC
    Black, 1.25” thick ideally, but 1” thick will work. 3” x 2” would be ideal. Thanks!
    Charles.
    #9
    jimroid likes this.
  10. HarveyM
    HarveyM Been here awhile
    Sep 10, 2010
    680
    Ottawa, Canada
    I like the hockey puck idea 1" thick, 3" diameter hard rubber and a buck or two new.
    #10
    sieg likes this.
  11. ChopperCharles
    Jun 7, 2006
    5,338
    Durham, NC
    But I can’t cut and shape rubber with a sanding disc and a dremel.
    Charles.
    #11
  12. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    12,975
    Orange County, CA
    cut it with a hacksaw, shape with a sanding disc for sure.
    #12
    sieg and scot_douglas like this.
  13. tinwelp
    tinwelp Professional Idiot
    Dec 5, 2010
    721
    Deepest Southern France
    The traditional approach is to just extend your side stand. If you're not equipped to do it yourself, I'm sure any reasonable engineering shop will be able to do it for you for not much money.
    Just a thought.
    Cheers... Paul
    #13
    jamracing likes this.
  14. svtride
    svtride Been here awhile Supporter
    May 5, 2013
    443
    SE Michigan - MotorCity
    https://www.amazon.com/dp/B0728KK5V5/ref=cm_sw_r_cp_api_i_mZrXDbHGC51VT
    Address to block of Delrin plastic on Amazon
    #14
  15. ChopperCharles
    Jun 7, 2006
    5,338
    Durham, NC
    While I can cut and weld my stand, it is powder coated the same red color as the frame, and if I weld it I will have to paint it black. I’ve been unable to find touch up paint that matches (the manufacturer doesn’t make it available for the frame, since its powder not paint). Since I’d also like a bit wider foot, a simple bolt on puck seems like a better way.
    Charles.
    #15
  16. okennon
    okennon Been here awhile
    May 17, 2009
    268
    Surprising and damn flat Suffolk
    McMaster Carr
    #16
  17. dhally
    dhally Hammerhead Supporter
    Feb 18, 2006
    5,763
    Kennewick, WA
    Wood
    #17
  18. 9mm
    9mm Been here awhile
    Apr 18, 2006
    599
    "Southeast of Disorder"
    In the boat world there is something called King Starboard. It is like uber polywood.
    #18
  19. ChopperCharles
    Jun 7, 2006
    5,338
    Durham, NC
    I was thinking of wood, but it won’t hold up to elements.
    Charles.
    #19
  20. nickguzzi
    nickguzzi Long timer
    Feb 17, 2010
    8,320
    below the sea
    I would use a hockey puck - if the springs are able to hold it. Have you considered the extra weight cantilevered way out there? Almost anything of sufficient strength to hold up longer tern will be quite an additional weight
    I cut and welded mine - both the side stand and main stand. I had access... so repainting wasn't an issue, but getting stuff re- powdercoated to any RAL colour is easy and cheap enough.
    #20
