$10 Trail Jack aka Quick Jack
Discussion in 'Equipment' started by mromo98, Sep 1, 2007.
  1. mromo98
    mromo98 Adventurer
    May 18, 2007
    76
    Colorado Springs
    I posted this over at KLR650.net but you guys deserve this too!!
    So I searched and searched for a quickjack for sale online and could not find anything for as cheap as i wanted so i decided to build my own. Here are the instructions and parts for the build.
    Walmart cane and "heavy duty tool holder"
    The cane was about $9 and the hook was about $1.50
    The first thing i did was take apart the cane to see what i had to work with.
    Next I removed the rubber leg and sawed about 1/3 of the end off. (Dont saw the end off with the spring loaded pin!)
    Next i sawed the top of the cane off, again about 1/3 or more, you could saw all the way down to just above the first pin hole if you wanted.
    I then made two cuts and used some pliers to make a round groove for the hook to fit into.
    I used some old inner tube from a road bike and some electrical tape to make the bottom of the hook wider for a tight fit.
    The finished product!!
    Lifting the rear:
    And the front. (If you do not have the crash bars you could use the frame in the front, though you may have to make the jack shorter)
    Skinny Jones likes this.
  2. Oldrice
    Oldrice oldrice.com
    Aug 10, 2004
    533
    Detroit - East Side
    Huh. wow. and it's only $11 (+/-)
    Prettyy innovative if you ask me. I've been building my tool kit lately too. This was on the list. Thanks for saving me some dinero!
    Oldrice-
    www.oldrice.com/KLR650.htm
  3. mromo98
    mromo98 Adventurer
    May 18, 2007
    76
    Colorado Springs
    No problem, That is what KLRs are all about, denero or lack thereof.
  4. The Ragman
    The Ragman Uralist & Bulleteer
    Aug 28, 2007
    30
    Ethel, WA
    That is a very good innovation. I will make a couple - one for the TW, and one for the Ural.
  5. husky123
    husky123 Long timer
    Nov 17, 2005
    1,462
    Leesburg, VA
    Brilliant!:clap
  6. RSL
    RSL Long timer
    Jun 30, 2003
    4,361
    Does the knurled thingy on the bottom of the cane twist-tighten so you can fine tune the length, or are you stuck using just the holes as length adjusters?
  7. Trailryder42
    Trailryder42 Long timer
    Oct 3, 2006
    1,370
    Amarillo, Texas
    It does twist tighten, but I wouldn't trust it to hold the cane at any certain length once weight has been put on it.
  8. owtcast
    owtcast Adventurer
    Apr 3, 2008
    88
    Beaumont TX
    I'll bet you could move the cane foot closer or farther away from the bike a little to fine tune the length.:evil Sweet idea. Compact too!
    #8
  9. freeflow
    freeflow get in or go in Supporter
    Dec 13, 2004
    21,622
    GB-Wisconsin
    :dunno :lol3 your stick looks better than mine :lol3
    #9
  10. braindead0
    braindead0 Head Fisherman
    Oct 4, 2007
    1,698
    Reno, NV
    There was a similar write up on one of the KLR forums using a wally world cane that has a more horizontal grip.. I did that one, doesn't require anything but the cane and the grip has a depression in it that is just perfect for sitting under the frame. Works on KLR, DR and XT just fine.
    Cool enhancemnt with the tool holder though, probably a more secure that way.
    #10
  11. snare
    snare sittin and breathin
    May 20, 2007
    1,032
    exactly where I choose
    I made one a month ago based on this thread, works great! Thanks! I just need to fine tune the threaded end of the tool holder so it doesn't fall out when I have the jack mounted on the bike.
    Speaking of mounting, has anyone found small tool holder type clips for something of this diameter?
    #11
  12. RSL
    RSL Long timer
    Jun 30, 2003
    4,361
    Why not adapt this idea for dual use: Works as jack per this thread, but can also be used as mechanism to adjust variable windscreen, which could also be the normal place to carry it.
    Whatdya think?
    And, speaking of dual use, what other uses could be adapt this gizmo for? Highly leveraged tire iron? Grab bar for passenger? For camping, why not use one of those adjustable walking sticks for this purpose, which also acts as a tent pole, etc.?
    (just brainstorming about adaptable uses for a telescoping pole)
    #12
  13. VStromTom
    VStromTom Long timer
    Aug 26, 2004
    1,579
    I have a Swiss Gear tent I found at Walmart this Spring on closeout for $11, one person, that uses an extendable walking stick for the pole. Not a very confy tent but your pole suggestion put to use. Pole can be taken out for day use without taking down the tent. FWIW
    #13
  14. the kaz
    the kaz has become "FERAL"
    Feb 5, 2007
    1,764
    West Coast EH.....
    that is WAY better than useing tree parts like I have been :D
    Excellent idea !!!!!!!!!!!
    #14
  15. sandiegoland
    sandiegoland Adventure Boy®
    Oct 3, 2005
    1,743
    4 8 15 16 23 42
    KLR Farkle Engineering Rox :D
    #15
  16. RSL
    RSL Long timer
    Jun 30, 2003
    4,361
    What if, instead of putting the forked end on a Wally walking cane, you used a Wally hiker's telescoping adjustable walking stick with wrist loop?
    Then, could you not use the wrist loop around, say, the handle bar to hold the front of the bike off the ground? Secure the wrist loop around the upper rear frame to hold the rear of the bike up.
    Then, you'd have the walking stick for multiple use as as tent pole, for walking, etc.. Comes in 2-pack for ~$20.
    http://209.85.141.104/search?q=cach...61+Walmart+SwissGear&hl=en&ct=clnk&cd=1&gl=us
    #16
  17. kenk
    kenk Adventurer
    Jun 17, 2008
    91
    Austin, TX
    What a great idea. I just used mine for chain maintenance. Makes it a breeze. I also tried it on my Ducati Multistrada....works, but the Multi is quite a bit heavier when lifting the rear end and pushing the jack under with my foot.
    Ken
    #17
  18. ibafran
    ibafran villagidiot
    Apr 16, 2007
    1,430
    chicagoland
    Just to help clarify this thread, would one or more of all y'all describe how to use the prop to get the rear wheel off the ground? The variety of techniques may not be obvious to all. The pix of the bikes show what the end result is but not how it got there. And it might be helpful to know that the front brake lever is secured in the activated position somehow so that the bike doesnt roll away inadvertantly.
    And, maybe, the more clear and definitive of the posts might get sticky'd in the hall of wisdom along with the tire bustin' info.
    Jus' tryin' to be helpful here...
    #18
  19. RSL
    RSL Long timer
    Jun 30, 2003
    4,361
    Well, if you used the walking stick with wrist loop trick, and set the stick to approximate correct length with wrist loop tight to the upper frame, you could simply rock the bike over a few degrees on its kickstand. This would drag the tip of the walking stick along, so as to leave the wheel off the ground when you release the bike.
    If using the forked walking cane trick per original post, you could snug the cane into position, push on the upper frame from the right side so as to pivot the rear of the bike up on the kickstand, then nudge the walking cane into place with your hand or foot. Or, simply tie or bungie the forked end of the can to the bike and rock up into place as per paragraph above.
    The wheel only needs to clear the ground by a bit, so you can either remove the wheel (for tire change, etc.) or rotate it (for chain lube).
    #19
  20. RSL
    RSL Long timer
    Jun 30, 2003
    4,361
    Looked at WalMart hiker's walking sticks, with telescoping shaft, shock absorber, wrist strap, ergonomic handle, and built-in compass. Two for $15.
    This should work as a wheel jack, if the stick is secured to the bike by the wrist strap.
    #20
