$1000 brand new semi-trials bike?
Discussion in 'Trials' started by motodojo, May 24, 2019.
  1. Chadzu
    Chadzu Lost In Space
    Nov 7, 2017
    924
    Utah
    The Fast Ace stuff is actually really good. I have the FA stuff on my GPX full sized bike and it has been good. A pain to service, but works good
    #41
    GlennR, MATTY and Fallacy like this.
  2. MATTY
    MATTY BORDER RAIDER
    Jun 23, 2014
    5,399
    England On the Scotish border
    Ok good to know i never seen any of that stuff or looked especially.
    I have noticed some makes of Chinese seem better equipped but do not seem to be different in price. I can not work out how they price up these bikes sometimes.
    ATVs are the same scenario, its hit and miss on quality do the research i superpose look at the finer points of the spec if you can find any spec that is.
    The vertical singles 125 150 and 200ccs with push rod engines seem reliable the Mistang 150ccs that are all over mongolia and such places use this engine.
    These have normal clutch and would be a good engine in my opinion if you can get one in that frame.
    #42
  3. motobene
    motobene Motoing for 49 years Supporter
    Mar 9, 2013
    7,786
    ABQ NM & Wichita Mountains OK
    China makes great stuff. Phones, machines, etc. We handed them the keys to empire and they took them and ran. They even own our debt.
    #43
    Kiharaikido likes this.
  4. Chadzu
    Nov 7, 2017
    924
    Utah
    It’s here! Weekend fun awaits
    #44
  5. MATTY
    MATTY BORDER RAIDER
    Jun 23, 2014
    5,399
    Good! will be good to see it out the crate and running.
    #45
  6. sanjoh
    sanjoh Purveyor of Light
    Feb 13, 2007
    9,134
    ADVmonster, CFL, WNC
    Engine decision time? That daytona 190 is a bit pricey!
    #46
  7. MATTY
    MATTY BORDER RAIDER
    Jun 23, 2014
    5,399
    Whats wrong with a 125 or a 150.
    #47
  8. Old Plonker
    Old Plonker Adventurer
    Oct 29, 2011
    72
    Shadow of Pike's Peak
    The Zong 190 2-valve looks good and is the only 5 speed I've seen in this engine configuration. It's not exactly cheap either.
    #48
    JagLite likes this.
  9. markbxr400
    markbxr400 Been here awhile Supporter
    Sep 26, 2016
    676
    Lower Alabama
    So true, but I couldn't "Like" that! I'd rather we make our own, or at least deal with countries whose stated goal isn't to surpass the US as the world superpower.
    But this situation is kind of like Google at this point. We're just stuck with it.
    I'm sure the bike will function well. And if they have spare parts availability, should be maintainable.
    #49
  10. motodojo
    motodojo Rock Ninja
    Dec 11, 2014
    375
    Atlanta, GA
    My bike arrived yesterday after a month long weight. I can see now why dealers charge a $600 prep fee!
    Engine weighs 40lbs. Same as my GG Pro.
    Frame as shown in photo weighs 60 lbs
    More weight reduction can be made by removing kickstand, aluminum rims, pegs, kickstart, brake, shifter, axle spacers, rear brake bracket.
    Some weight will have to be added for a skidplate.
    It looks like a 18" rear tire will fit but a bigger engine would probably be needed.
    These motors cost $300 in a crate, so they are almost disposable. I bet a Honda Grom EFI engine will fit. IMG_0375.jpg IMG_0376.jpg IMG_0377.jpg IMG_0378.jpg IMG_0380.jpg IMG_0382.jpg IMG_0383.jpg IMG_0384.jpg IMG_0385.jpg IMG_0386.jpg
    #50
  11. sanjoh
    Feb 13, 2007
    9,134
    A flying eagle!
    I was going to fab a poly skid plate aka cutting board with matching color:super
    What did you pay for the eagle?
    #51
  12. Chadzu
    Nov 7, 2017
    924
    Utah
    That is the same bike as the one I had imported. No branding on mine, but it has the Time stunt logo on the parts. I am stuck on the rear wheel/brake assembly right now. I can’t seem to come up with a spacer configuration that works smoothly.
    #52
  13. Old Plonker
    Oct 29, 2011
    72
    Chad, are your forks the same?
    Oh, and did you get any documentation and a certificate of origin (in case you need to plate it)?
    #53
  14. Chadzu
    Nov 7, 2017
    924
    Utah
    Mine are Fast Ace, but look pretty much the same. If motodojo got his from Orion then it’s a no brainer. $959 is an incredible value.
    #54
    Old Plonker likes this.
  15. Chadzu
    Nov 7, 2017
    924
    Utah
    I do like the pretty blue paint
    #55
  16. MATTY
    MATTY BORDER RAIDER
    Jun 23, 2014
    5,399
    On a 150cc vertical single china dirt bike we have here, the rear wheel spacer has a very slight taper on one side, if you put it square shoulder to the bearing side it overloads the bearing float and is rough. i know this because i mended a puncture about 6 months ago and being in a rush i missed the taper, but feeling the harshness i checked and turned the spacer round then was fine.
    Not saying its same on yours but have a closer look, not a lot of taper but it is there if its like ours here.
    #56
    JagLite, Old Plonker and Chadzu like this.
  17. Chadzu
    Nov 7, 2017
    924
    Utah
    Mine does have the z-hua brakes which is a nice upgrade
    #57
  18. Old Plonker
    Oct 29, 2011
    72
    A tuning fork decal below the filler cap would have people scratching their heads! Is that one of Pitster's 140 engines on the floor?
    Also, are the Fast Ace legs sprung on one side like the others?
    #58
  19. motodojo
    motodojo Rock Ninja
    Dec 11, 2014
    375
    Atlanta, GA
    The differences I see from mine, which I bought from Shi Pao for $1200 is yours as a battery holder, different seat cover and nicer looking anodized parts: triple clamp, handlebar clamp. You got aluminum rims? Mine are steel. I have the same blue anodized parts behind the number plate and under the seat. I like your blue since I have a couple of YZs but I am going to go with all black and put some FX125 graphics on it.
    I am pretty sure my engine was installed at one time and ran through the gears from some markings and soot in the exhaust. And it looks like real motor oil in it.
    #59
  20. Chadzu
    Nov 7, 2017
    924
    Utah
    My bike would have had the 190 2valve Zong with electric start if the EPA would have allowed it. That is why the battery box is there. Yes my wheels are aluminum.
    I sorted out the rear wheel. I had to drill a spacer from 13mm to 15mm. It would fit over the threads, but bind on the axle. No big.
    #60
