100000 Trouble Free till Yesterday
Discussion in 'Parallel Universe' started by Strawdog, Aug 27, 2016.
  1. Met n GS
    Met n GS Been here awhile
    May 6, 2016
    147
    how were you riding when the chain snapped?
    #21
  2. Strawdog
    Strawdog Strawdog
    Jun 5, 2012
    374
    Fannystelle
    That's where the case breaks. Mine was worse and leaked oil. Clean it up well and monitor.
    View attachment 618243 [/QUOTE]
    Hi Reaver
    You have a good eye cleaned it up It is cracked
    #22
  3. 70East
    70East Been here awhile
    Feb 4, 2013
    688
    NOVA, not by choice.
    Ahh that sucks.
    #23
  4. Strawdog
    Strawdog Strawdog
    Jun 5, 2012
    374
    Fannystelle
    On the bright side I didn't crash
    One night in a beer induced Internet frenzy bought a spare engine before xmas at the time in some what drunken thought it would be a good idea
    Now its rime to get it home
    #24
    SmittyBlackstone and Dorito like this.
  5. Reaver
    Reaver Why am I still here?
    Aug 7, 2008
    22,696
    CR
    Yeah that sucks. But if it doesn't leak oil then there's no rush to change it. It may or may not progress.
    I bought the 2012 pre broke and it was cheap. I also have a spare engine at home.
    #25
  6. Strawdog
    Strawdog Strawdog
    Jun 5, 2012
    374
    Fannystelle
    Reaver what so u think ?
    #26
  7. Reaver
    Aug 7, 2008
    22,696
    CR
    There are people who can weld that. Remove all the computers first, including ABS. You cannot change that lower crankcase by itself. The bearing and crank bores are line bored together so it's a matched set. Mine was way worse so I parted out the engine after finding another. In Canada, no one cares about the engine SN. Here in Costa Rica, they'll take the bike if the number is wrong!!
    #27
  8. Met n GS
    May 6, 2016
    147
    so how were you riding when the chain snapped? any injuries?
    #28
  9. Strawdog
    Strawdog Strawdog
    Jun 5, 2012
    374
    Fannystelle
    I was west of Kamloops BC was at 100 KPH felt a slight vibration in peg then it let go Was lucky it all piled up on front sprocket
    Got it all cleaned up and back together for tomorrow test drive Chain punched holes in rear fender below pax seat area as well.
    If all goes well with test drive will start heading back to Winnipeg
    I have got allot help and input from ADV community Thank You
    #29
    SmittyBlackstone likes this.
  10. Reaver
    Aug 7, 2008
    22,696
    CR
    Winterpeg? There'll be lots of time to fix it then if you have a garage.
    Sorry, had to. :-)
    I've changed a few of these engines. It's like a puzzle. They only come out and go in one way.
    I did this 2012 Triple Black in the basement in winter. Ran a strap from the ceiling joist to lift the engine in.
    #30
  11. Strawdog
    Strawdog Strawdog
    Jun 5, 2012
    374
    Fannystelle
    Got first test ride in all good Next highway then make my home
    #31
  12. Strawdog
    Strawdog Strawdog
    Jun 5, 2012
    374
    Fannystelle
    Reaver do know what kind of aluminum cases are I assuming its cast
    #32
  13. FinTec
    FinTec Been here awhile Supporter
    Sep 27, 2013
    574
    Colorado
    I like that of all the things that came off, the seat is still there :D
    #33
  14. Reaver
    Aug 7, 2008
    22,696
    CR
    I was making vroom vroom noises so it was necessary!
    #34
  15. Reaver
    Aug 7, 2008
    22,696
    CR
    Yes, cast for sure but I don't know the specifics of the alloy. All the side cases etc are the same blend if you need something to experiment on. You have your spare engine to play with. I have a number of components but forget which. My remaining spare engine is an F800R.
    #35
  16. Strawdog
    Strawdog Strawdog
    Jun 5, 2012
    374
    Fannystelle
    Well made it Banff just keep dumping oil in every 200 km
    Its to bad it a good engine I think what happened is front sprocket was so worn compared to the back
    Back looked almost new front wow it was bad both new when installed it was a JT sprocket last time I use that brand
    #36
  17. sarathmenon
    sarathmenon Armchair Adventurer
    Mar 29, 2012
    1,540
    SFO Bay Area
    Doesn't JB weld work on Aluminum?
    #37
  18. Strawdog
    Strawdog Strawdog
    Jun 5, 2012
    374
    Fannystelle
    Yes but it has its limitations we used it allot on Pratt & Whitney 985,1340 & 2800
    Needs have all oil removed to bond and is not strong enough for a part under a high load.
    I have ferried airplanes from the north with cracked cases with JB weld but was in areas that did not involve support structure
    #38
  19. NCD
    NCD Dirty Hairy Supporter
    Nov 13, 2008
    876
    NE Ohio
    Funny. 12000 miles ago I put on JT sprockets and a DID chain. Just last week I was looking at the sprockets and thought they looked more worn than they should, while the chain looks excellent. Was considering putting OEM sprockets on to make sure the chain sees it's actual useful life without issues.
    Is that a reasonable route to take?
    #39
  20. Strawdog
    Strawdog Strawdog
    Jun 5, 2012
    374
    Fannystelle
    My rear sprocket was almost new I think it was OEM front was JT Looked almost 3/4 worn with front teeth looking like a wave breaking 12000 km on it
    #40
