1090 no start after new fuel pump???
Discussion in 'Hard. Core. (1090/1190/1290)' started by kermitiv, Jul 22, 2019.
  1. kermitiv
    kermitiv Adventurer
    Oct 25, 2015
    34
    Colorado
    So on the last day of my 2 week ID BDR trip my bike finally would not start. It started struggling to start 4 days early with really rough starts until it got hot then would run fine the until sitting overnight. Just put in a new fuel pump and filter and the bike still will not start?? Really baffled now and don’t want to take it to my terrible KTM dealer in the other town. Any ideas guys??
  2. OG1
    OG1 Been here awhile
    Oct 8, 2018
    225
    Oregon
    Is the fuel pump cycling when you toggle the stop/run switch?
    windblown101 likes this.
  3. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    9,196
    Star Tannery, VA
    Basics first. Fuel pump cycling and then turning off to indicate it came up to pressure? Fuel line Quick connect firmly attached?
    The deeper question in my mind if all seem well with the work performed is what makes you think it was the fuel pump causing the problem?
    Wodger63 likes this.
  4. Wodger63
    Wodger63 Long timer
    Oct 30, 2011
    4,472
    Homeless
    Even being familiar with fuel quick connect after owning a 1190 and then a 1090 having the tank off numerous times.
    I got caught out once with quick connect not seating right with the result being a non start.
    Best thing to do @kermitiv with any issue like that is to work backwards and double check your work.
  5. kermitiv
    kermitiv Adventurer
    Oct 25, 2015
    34
    Colorado
    Thanks for the suggestions. Yes fuel pump cycles. My thought was that the filters where plugged or the pump was bot building proper pressure. The quick connect is seated properly but wondering if I need to try and bypass to see if it is malfunctioning. However doesn’t explain the hard start and rough running then running normally the rest of the day??
  6. Newbusa
    Newbusa Long timer
    Aug 21, 2006
    1,469
    Qualicum Beach
    Just wondering if the clips locking the fuel pump top and bottom are locked on. I had them back off before so know when I replace fuel filters I always throw a zip tie around the clips so they can’t back off. Also make sure the quick disconnect fuel line is properly engaged.
  7. kermitiv
    kermitiv Adventurer
    Oct 25, 2015
    34
    Colorado
    The clips are locked and the quick connection is locked in place. Really wondering about removing the quick connection in case it is malfunctioning inside and replacing with a filter instead
  8. ianblomeyer
    ianblomeyer ianblomeyer
    Nov 10, 2014
    108
    south africa
    It may not be the pump. It may be the valves.
    #8
    djroszina likes this.
  9. crossbones
    crossbones Been here awhile
    Nov 28, 2007
    531
    Tight intakes will do that.
    #9
  10. Throttle-jockey
    Throttle-jockey Been here awhile
    Apr 18, 2009
    456
    San Diego, CA
    Sounds dumb but did you turn on the shut off valves?
    #10
    Doktor likes this.
  11. phil80
    phil80 Adventurer
    Mar 11, 2016
    83
    U.K.
    So the bike started to have issues, when it didn't start you chose to change the pump??
    When it did not start initially - did the pump still run?
    Is the 1090 ride by wire - if so can you here the throttle body servo whine when ignition on? Can you see the link between the to butterfly valves move when operating the throttle?
    Is there a spark? If possible take a plug out and plug it back in to the coil and check- if no spark likely to do with crank sensor I imagine. if spark, likely fuel issue.
    OR
    If the pump runs, and you don't want to remove a plug - you could remove the tank and meter the crank (pulse generator sensor) that will tell you if it faulty which then won't tell the eco when to fire.
    Maybe that's your best option (from my view) if the throttle linkage moves (have to look under the right side (if your sitting on the bike), tight to see - get on the floor and look up into the frame, and if pump primes.
    Not saying it is - but I have literally just had this sensor fail on my bike, would turn over but not fire.
    #11
  12. kermitiv
    kermitiv Adventurer
    Oct 25, 2015
    34
    Colorado
    I chose the pump because of the ton of threads that listed it and the filters as a constant problem. I will try the throttle linkage but I can hear a change in pitch from the carb when I move the throttle so I don’t believe this is the problem. If I bypass the quick connection and it doesn’t resolve then the next step is to check plugs. Bike only has 9k miles so this is really frustrating. Thanks guys
    #12
  13. phil80
    phil80 Adventurer
    Mar 11, 2016
    83
    U.K.
    Any error on the screen or flashing engine light?
    #13
  14. kermitiv
    kermitiv Adventurer
    Oct 25, 2015
    34
    Colorado
    No error codes at all
    #14
  15. Marki_GSA
    Marki_GSA Long timer
    Sep 6, 2011
    2,271
    Scotland
    What miles are on your bike?
    I don't think it's the pump, more the guys saying check the valves have a point. If it runs OK when warm it isn't the pump or filters symptoms of that is bad running under load what max fuel flow is needed.
    #15
  16. kermitiv
    kermitiv Adventurer
    Oct 25, 2015
    34
    Colorado
    8700 miles so valves should be fine
    #16
  17. 3rdgeargrndrr
    3rdgeargrndrr Long timer
    Jan 19, 2017
    1,306
    Sacramento
    make sure your battery is not the issue either.
    and +1 check throttle linkages
    #17
  18. ls6777
    ls6777 The Dude abides Supporter
    Mar 25, 2015
    848
    Vista, CA
    Are you implying you just had them checked? Isn't first check at 9k? or is the first check at 18k? I cant remember.
    #18
  19. crossbones
    Nov 28, 2007
    531
    Hi,
    I had a real tight front intake at 6k
    #19
    nk14zp likes this.
  20. kermitiv
    kermitiv Adventurer
    Oct 25, 2015
    34
    Colorado
    Ok. Thanks. Gonna have time to look at it more tomorrow. Thanks guys
    #20
