1150 engine service videos
Discussion in 'GS Boxers' started by Jarvis, Jun 5, 2006.
  1. Jarvis
    Jarvis DC GSer
    Dec 3, 2002
    14,924
    Washington DC
    These are helpful:
    600 mile service, with valve adjust: https://www.bmwmc.net/uploads/tm11/R4V EngSvc115_medium.wmv
    Ignition timing / Hall sensors: https://www.bmwmc.net/uploads/tm11/R4V Ignition timing_medium.wmv
    Throttle body synch: https://www.bmwmc.net/uploads/tm11/R4V Throttle Synch_medium.wmv
    V-belt adjustment: https://www.bmwmc.net/uploads/tm11/Poly V-belt sequence_medium.wmv
    (Credit where credit is due: I stole the links from BMWBMW board. The links are from deep inside the BMW Authority Motorcycles (police bikes) site.)
  2. space
    space a.k.a. Jake
    Jan 1, 2006
    2,669
    Los Angeles
  3. Baba Iguana
    Baba Iguana Bored Track Racer
    Mar 30, 2004
    544
    Ottawa
    :thumb :thumb :thumb
  4. GB
    GB . Administrator Super Moderator Super Supporter
    Aug 16, 2002
    67,931
    wow!! :thumb anyone want to do the same for the 1200GS?
  5. Scrotie
    Scrotie Chuck U Farley
    Aug 10, 2005
    1,736
    Seattle
    That's a great visual aid. Thanks :thumb :thumb :thumb
  6. space
    space a.k.a. Jake
    Jan 1, 2006
    2,669
    Los Angeles
    Wow. Just finished watching all of them. My first reaction: I want that beeping snap on torque wrench! That thing is SLICK! Maybe I'll buy it after I finish paying off my GT1 computer.... :rofl
    Anyhow, good stuff. A nice supplement to the Halls of Wisdom explanations.
    One discrepancy I did notice: after the valve adjustment, the video stresses that the rubber spark plug seal be reseated such that the indentations line up with the metal bits that made them. The OVAD manual says the opposite, that you should rotate the seal so they do not line up. Probably not important, but it caught my attention. (Especially since I've followed the OVAD manual's advice and not lined them up.)
  7. Boingo
    Boingo Comfortably road numb
    Nov 26, 2003
    193
    Pleasant Hill, CA
    Great find jarvis!
    :clap
    I noticed that also. I'm sticking with the OVAD.
  8. hogmolly
    hogmolly Dude
    May 28, 2003
    3,245
    McKinney, TX and San Jose, CA
    cool :clap
    #8
  9. Ridemuch
    Ridemuch Ciao
    Nov 23, 2005
    2,289
    GTA,Ontario
    you are my new friend...thanks!!!:clap
    #9
  10. CaptTurbo
    CaptTurbo Long timer
    May 29, 2006
    1,099
    Ft Myers
    Thank you for coming up with such a great resource!:clap
    #10
  11. 40MileDesertRat
    40MileDesertRat Born Again Pagan
    Jul 27, 2004
    1,484
    67km east of la república socialista de Kalifornia
    Jarvis,
    Thanks for this.
    40mile
    #11
  12. piratetreasure
    piratetreasure Been here awhile
    Feb 24, 2004
    619
    SW Florida, FMB
    Jarvis- This is great stuff! Thanks for digging it up and posting.
    #12
  13. Anorak
    Anorak Woolf Barnato Supporter
    Jul 23, 2004
    55,456
    San Rafael, Marin County
    That's the best choice because the ovad designed and built your bike.
    #13
  14. 761
    761 Been here awhile
    Dec 1, 2004
    346
    La La Land
    I'd be up for helping out with the audio/video side if someone can help with the mechanical side.
    #14
  15. smallcandle
    smallcandle Lick the world...
    Apr 27, 2005
    143
    Winfield, KS
    I've been looking for something like this for months! THANK YOU!:thumb
    #15
  16. johnjen
    johnjen Now, even more NOW!…
    Nov 28, 2001
    17,033
    The reason that we recommend rotating the spark plug tunnel seal is if you (re)move the seal to clean out the oil, the chances of getting it back exactly where it was is very slim... Using a new surface means minimizing the chance for oil seepage/weepage/leakage. It also means that the seal will have a chance to fill out and be re-used, over and over again (I'm still using the ones that came with my bike, an '00).
    Another aspect that caught my attention was the torqueing the lock nuts to 10Nm when my (1150) Repair Manual calls for 8Nm. And the method he used, torqueing the lock nuts after setting the gaps, is mighty short sighted in my book... In my experience (and I invite you all to check this for your self) it WILL change the gap. It does make sure that the lock nut torque will be matched (which is a good thing). But using the same torque wrench (an assumption on my part) is not a wise thing to do...
    And rest of the video is great, I wish we had the resources to augment OVAD like that. It would help in demonstrating some of the finer aspects of matching the gaps...
    JJ
    ps I really like that tone based torque wrench. Of course it will be expensive (it's probably made of unobtainium):evil
    #16
  17. hogmolly
    hogmolly Dude
    May 28, 2003
    3,245
    I noticed the torque value error myself. I also believe he set the valves like I do, that is to say that I set the feeler gauge drag so that when I torque the locknut the final drag is where I want it. The same thing most of us do when we sync the throttle cables. We offset the balance just enough that tightening the locknut brings it back to perfect.
    I agree with you on the rubber plug hole seal. I always rotate mine.
    #17
  18. Anorak
    Jul 23, 2004
    55,456
    I have one of those torque wrenches. It also vibrates when torque is reached. Snap-On has an even fancier one that also does torque to yield with some sort of nifty sensor. You just input the degrees and it beeps when you reach the angle.
    #18
  19. johnjen
    Nov 28, 2001
    17,033
    Does that nifty electronic torque wrench have the same limitation of not being really accurate at the extreem low end?
    JJ
    #19
  20. b737jets
    b737jets Baja Explorer
    Jun 2, 2005
    176
    Big Bear City Ca.
    thanks great post...........!!!
    #20
