1150 engine service videos
Discussion in 'GS Boxers' started by Jarvis, Jun 5, 2006.
  1. Anorak
    Anorak Woolf Barnato Supporter
    Jul 23, 2004
    60,298
    San Rafael, Marin County
    No, it came with a calibration card. It is supposed to be within 2 percent the card showed it to be within .2 percent from bottom to top. If you use a torque wrench regularly, it is worth it. Don't drop it or use it in place of a hammer though.
    #21
  2. Boingo
    Boingo Comfortably road numb
    Nov 26, 2003
    193
    Pleasant Hill, CA
    How I wish they had…then maybe we wouldn’t have to do clutch spline lubes at 40k.
    Works for me. Oh…thanks for the OVAD and TBSD, awesome resources.
    #22
  3. picard
    picard engage!
    Oct 9, 2005
    2,229
    The Front Range, CO
    Hi All,
    maybe the more computer savvy of you can help me. I can watch the video but the colors are all screwed up - like a "fuzzy negative" - am IU missing a video decoder or something? Thanks much!
    Frank
    #23
  4. dog rocket
    dog rocket If I have 2 eggs plain...
    Apr 21, 2006
    278
    Northern CA... Sierra Foothills
    I thought for sure the feeler gauge was going to be pinched in after that and was surprised that it wasn't! But then again, that wouldn't make for a very convincing instructional video... :wink:
    Great stuff... I want more!
    #24
  5. A. T. T-W
    A. T. T-W Can't be bothered.
    Aug 24, 2004
    4,422
    Centre of my universe
    Well I found them disappointing after the F650 Chain Gang videos!
    Not once did this bloke mention "doohickies"! :D
    (Very useful stuff, thanks.)
    #25
  6. Reprobate
    Reprobate Sarcasm Loading....
    Feb 17, 2003
    6,375
    Amsterdam, The Netherlands.
    Bit slow to load at work, but I have time...
    Thanks for finding this!
    #26
  7. charleshmosesii
    charleshmosesii No skills no worries
    Feb 16, 2005
    861
    Tampa, FL
    Is the 12GS (hexhead) procedure materially the same, such that a noob who follows these videos can figure out how to do his 12GS?
    #27
  8. Global Rider
    Global Rider Alps Adventurer
    Nov 26, 2001
    3,965
    Canada & the Alps - N 46° 31.714' E 010° 27.212'
    When the course instructor demonstrates how to check and adjust the cable free play at the throttle body, he is actually pulling the cable casing enough to pull the thottle cable as well, the latter which shouldn't be done. You can see the cable move in the video.
    To do that step correctly, using the other hand, place a finger on the cable pulley located on the back side of the throttle body, so as to force the pulley against the idle stop. Then with the other hand, pull on the cable casing and check the free play. Adjust as necessary.
    Damn amateurs!
    #28
  9. BeemerBill
    BeemerBill fillerup agin'
    May 2, 2005
    611
    That's a cool tool to torque the head bolts with but wouldn't a half turn do the same thing?
    #29
  10. eatpasta
    eatpasta Lawnmower Target Supporter
    Jul 5, 2006
    16,409
    Santa Barbara, Ca
    Cool! Now I have no excuse to not learn how to do this now...
    :D
    #30
  11. Jim Bud
    Jim Bud Long timer
    Apr 25, 2003
    3,440
    Sedalia, CO
    Thanks........:clap
    #31
  12. RacingMike
    RacingMike Adventurer Wannabe
    Oct 13, 2003
    119
    Montreal, Canada
    great video...
    but I do have a question:
    he "torques" the rocker nuts to 40N-M AND apply another 180 degree turn....why not indicate the proper torque value rigth away?
    (btw I am not a mecanic)
    #32
  13. johnjen
    johnjen Now, even more NOW!…
    Nov 28, 2001
    17,083
    That is the 'new' way that these heads are torqued. If you get a tech manual you'll see it spec'd out just that way.
    JJ
    #33
  14. Aidan1150
    Aidan1150 Call Me The Breeze
    Dec 27, 2005
    283
    South Armagh, Ireland
    Thanks Jarvis. Great find. :thumbup Downloaded and saved.
    #34
  15. Poolside
    Poolside Syndicated
    Apr 1, 2003
    11,889
    Silicon Beach, CA
    <BR>The 1200?
    Valve Adjust: The rocker arm assembly and valve adjust are the same as 1100/1150.
    Ignition timing / Hall sensors: The timing cannot be adjusted; the sensor is in a fixed position.
    Throttle body synch: The idle sync cannot be adjusted. The high speed/cable adjust is the same.
    V-belt adjustment: No V-belt adjustment possible. The alternator is fixed and the special elastic belt stretches around the pulleys. If you've ever put a slipped chain back on your bicycle you have installed the V-belt on a 1200.
    - Jim<BR><BR>
    #35
  16. Global Rider
    Nov 26, 2001
    3,965
    Because "angle torquing" is far more accurate.
    You "pre-load" the fasterner by applying an initial torque so that you have a relative starting point for the torque applied by the angle torque.
    Using just a Nm value, you have far too many factors that can affect the torque: finish on the fasteners, dry or lubricated, etc. Torquing by angle, none of that comes into play.
    #36
  17. AntonLargiader
    AntonLargiader Long timer
    Aug 28, 2003
    7,295
    Charlottesville, VA
    Looks to me like he torques to 20 Nm. Where did you see 40? That's only on the M10 bolt.
    #37
  18. GS simp
    GS simp Been here awhile
    Jul 9, 2006
    113
    N Ireland
    Good stuff i enjoyed those gives me a better insight into the motor.
    steve
    #38
  19. RacingMike
    Oct 13, 2003
    119
    Montreal, Canada
    well, I incorrectly wrote 40 then, too much beer I guess.....:1drink
    #39
  20. BeemerBill
    May 2, 2005
    611
    I find that if I pretighten the lock nuts somewhat less than the torque value needed, and then use the torque wrench, the gaps remain constant.
    #40
