1150 engine service videos
Discussion in 'GS Boxers' started by Jarvis, Jun 5, 2006.
  1. BeemerBill
    BeemerBill fillerup agin'
    May 2, 2005
    611
    One important inconsistency I notice is that in the beginning of the 600 mile service video he instructs you to measure the rocker end play gap at the top of the rocker arm. Later, he actually does the adjustment at the bottom, consistent with all other information I've seen on this procedure. I find there is about a .2mm difference in the gap at the top and the gap at the bottom.
    #41
  2. johnjen
    johnjen Now, even more NOW!…
    Nov 28, 2001
    17,021
    Another aspect is that the pushrods have a slight up angle so measuring the rocker end gap from the bottom is 'better' since that is where the rocker 'sits' when being acted upon...
    JJ
    #42
  3. davevv
    davevv One more old rider
    Aug 17, 2006
    2,572
    Just north of Dallas
    Thanks. Very helpful for a new GS owner.:clap
    #43
  4. Mr Head
    Mr Head Adventure Hippie Supporter
    Sep 21, 2003
    15,565
    San Clemente, CA
    I liked these very much. I'm going to use them to aid in my arguement for yet another tool....:rofl
    Plus that cool beeping Snap-On wrench, $$$.
    #44
  5. MWM
    MWM Been here awhile
    Jul 26, 2005
    404
    Baton Rouge, LA
  6. Minnesota
    Minnesota Conform or be cast out
    Sep 5, 2006
    4,066
    The far unlit unknown
    When I replaced the head gaskets on my 2000 Ford Ranger, the 180 degree method was recommended as well. But I'll tell you, once we got that 180 degrees in, that sucker must have been close to 100 ft/lbs! Plus the head bolts are torx-types. It wasn't easy keeping the socket inside the torx hole while twisting that extra 1/2 turn.
    #46
  7. PhilLynot
    PhilLynot Been here awhile
    Feb 16, 2006
    318
    Leonard, ND
    These videos are excellent! Thanks.
    #47
  8. bigrichard
    bigrichard Long timer
    Nov 22, 2001
    2,242
    Northern California
    Sears sez the certification is for 10 - 100% of range on the ELECTROTORK so the calibration card bottom may not be the actual use bottom
    #48
  9. xdbx
    xdbx Motorcycle Connoisseur
    Nov 3, 2006
    2,519
    SLC
    I just found this fishing around in one of the sticky's and am going to need to do some of the mentioned work. Just wanted to bump it in case it might save someone's ass. :lol3
    #49
  10. def
    def Ginger th wonder dog
    Feb 28, 2004
    14,290
    The woods and mountains of Alabama
    Essentially, you are correct. If you are careful, the angle tool is not necessary. But initial torque is important. You are putting the studs into tension and stretching them to provide optimum compression of the head gasket.
    #50
  11. def
    Feb 28, 2004
    14,290
    Studs under similar tension is the desired result. The angle method provides more consistent tension at the four corners. BMW head gaskets never leak as a result.
    #51
  12. def
    Feb 28, 2004
    14,290
    One thing to remember, prior to performing valve lash adjustment, make sure the engine is stone cold.
    #52
  13. NDSinBKK
    NDSinBKK Adventurer
    Oct 10, 2007
    63
    Bangkok
    Can you elaborate on that? Wouldn't the bolts be over-torqued with that process? And where do you get that tool he used?
    Tks much, I also am not a mechanic, new 1150 owner and fully capable of making a lethal mistake when I try this for the first time...
    S.
    #53
  14. TOOOLDTORIDE
    TOOOLDTORIDE n00b
    Mar 15, 2012
    1
    For some reason, I cannot view the videos. I open the link and they are blurred and bright yellow, red and green. Any idea what I am doing wrong. Thanks,:D
    #54
  15. wotafm
    wotafm Adventurer
    Feb 2, 2008
    70
    try viewing with a different player i get that sort of thing when using divx player so i switch to windows video player and it comes good
    #55
