1190 EDS Failure - Fork Rebound Stepper Motor
Discussion in 'Hard. Core. (1090/1190/1290)' started by bikemoto, Apr 18, 2020.
Tags:
  1. bikemoto
    bikemoto Tyre critic
    Oct 24, 2004
    4,364
    Nelson, New Zealand
    My bike (2016 year) has an EDS failure warning on the dash. The diagnostic computer says it's a fork rebound stepper motor fault. Has anyone encountered this before? Any known/easy fixes?
    Looking at the parts diagrams, that stepper motor is in the fork cap? Seems like it just provides an electric version of the manual screw mechanism in traditional forks. From memory when I changed the fork oil, there's no wires or other electric connections below the cap. For disassembly the instructions I read simply said unscrew the fork cap from the cartridge pretty much like normal.
    If that is correct, and replacement is the only option, does anyone who's removed the EDS have fork caps spare they'd be willing to sell?
    Or am I mistaken and there's something else I have to replace? Whole fork leg?? :(
    TIA
  2. brianbrannon
    brianbrannon They'll ride up with wear
    Dec 15, 2009
    2,266
    Denver, CO
    The caps and motors screw off and on. No reason you can't just replace the cap
    bikemoto likes this.
  3. bikemoto
    Oct 24, 2004
    4,364
    Nelson, New Zealand
    Thanks Brian. That was the impression I got from reading the various EDS threads, too.
  4. sproot
    sproot Been here awhile
    Oct 16, 2007
    385
    Londinium
    Does the stepper motor just alter the damping, or the preload as well? Seems like a pretty small motor if it's doing the preload, the preload motor on the rear is pretty big.
  5. bikemoto
    Oct 24, 2004
    4,364
    Nelson, New Zealand
    I thought I saw a thread around here recently that confirmed that preload adjustment was on rear shock only.
    I can't say I've ever noticed the front moving when you change the load setting, but the rear ride height changing is very noticeable.
