1190 MTC faults in rain, which connectors need sealing?
Discussion in 'Hard. Core. (1090/1190/1290)' started by Arra, Dec 7, 2018.
  1. Arra
    Arra n00b
    Mar 12, 2016
    5
    Wellington, New Zealand
    I have an 1190 adventure r, 2013, and the MTC faults after extended riding in the rain but is OK once it dries out. I'm assuming I can seal some electrical connectors and sort this but I'm not sure which ones I should look at, does anyone on here know? Any other advice? I've looked at other posts on MTC issues but didn't see an answer.
    Grateful for any advice!
  2. kokos79
    kokos79 Nomad
    Apr 13, 2009
    1,535
    Greece
    I would start with the ABS sensors.
    TheBritAbroad likes this.
  3. kuyohtay
    kuyohtay Been here awhile
    Mar 16, 2015
    174
    South Central VA
    Get some weathertech silicon and some rubbing alcohol. Clean and seal very lightly where you can. Don’t use sweaty fingertips, use sterile gloves to apply and clean. New pair each task.
    That will make a good bond and keep the moisture out. It ain’t broken, s protection makes sense.
    Good luck, keep us posted.
    Ed.
  4. Arra
    Arra n00b
    Mar 12, 2016
    5
    Thanks for the replys, should I be sealing the actual sensor units that read the slotted discs (as in these photos) or some connectors located somewhere else?
  5. Lewilewi
    Lewilewi Ride it like you stole it......
    Oct 22, 2017
    2,892
    Europe
    Is it not worth looking at both sensor and connection end of this, if this is were your starting your problem solving..
    Do both....or buy new?
  6. kuyohtay
    Mar 16, 2015
    174
    South Central VA
    Sure, undo the connectors and also put some dielectric grease in there as well. Do whatever you can, the wet is getting in there right?
    Cheers!
    Ed
  7. brianbrannon
    brianbrannon They'll ride up with wear
    Dec 15, 2009
    2,260
    Denver, CO
    Just do all of them
  8. Lewilewi
    Oct 22, 2017
    2,892
    Europe
    Got a spare set of wheels for sale that will fit!!
    See flea market
    #8
