1190R Centerstand Bolt Broke
Discussion in 'Hard. Core. (1090/1190/1290)' started by RZRob, Mar 28, 2019.
  1. RZRob
    RZRob Long timer
    Dec 18, 2008
    1,950
    Anaheim Hills, CA
    Well, I'm bumming. My right side centerstand bolt sheared. I drilled it out and it isn't even thinking of budging. I tried a large EZ-Out and even forced a 6mm allen screw to try and continue threading it out the other end. It's frozen solid. I guess at this point I'm going to just trill it all the way and try to go back to original size. That's a 6mm tap in there now (photo).
    Anyone else had anything like this happen?
    RZ Rob
  2. comradecasey
    comradecasey Been here awhile
    Jun 5, 2018
    637
    Oregon / Tennessee
    Your image is as broken as your centerstand bolt is.
    Schuk, KTM 1190advR, RZRob and 2 others like this.
  3. Barekat
    Barekat Looking to get dirty
    Jul 28, 2013
    4,532
    North of Toronto
    Jaimoto likes this.
  4. Insane rider
    Insane rider Been here awhile
    Jul 19, 2016
    118
    Happened to me last year while putting gas...
    The bolt was seized and had to drill it.
    I was not able to do a clean job so I drilled a bigger hole and used a Helicoil.
    ScooterNoMore and RZRob like this.
  5. RZRob
    RZRob Long timer
    Dec 18, 2008
    1,950
    Anaheim Hills, CA
    I think I read your post last night. Hope I don't have to go that route, but I'm almost there if I do.
    RZ Rob
  6. miken0vf
    miken0vf Been here awhile
    Apr 17, 2018
    330
    Broomfield, CO
    Your pic isn't working but if you're using the ez out out that is cone shaped it could cause the bolt to bind. The issue is that when you are getting it to bite the bit is getting bigger and could cause the diameter of the bolt to swell just enough to cause a bind. I like using the through bits. Specific size hole drilled and bit tapped in, no swelling and no binding. Here's a pic of a peg mount bolt that sheared and it came right out.
    RZRob likes this.
  7. OhBoy
    OhBoy Got Out
    Mar 30, 2009
    1,899
    Merrimack Valley, NH
    I forget which side but, mine had been loose a couple of times.
    Let it go too long and the bolt had fallen out during a ride.
    Replaced it with something laying around in the tool box.
    WTF
  8. touil
    touil Been here awhile
    Jan 3, 2017
    233
    To avoid problème with double stand bolt, i sugest all owner to instal BDCW side stand relo. The kit mary the foot peg bolt with double stand end bushing. With this modif your double stand will be indestructible
    #8
  9. Harro
    Harro n00b
    Dec 29, 2018
    4
    Gold Coast
    Mine threaded, used a wurth insert...
    #9
  10. RZRob
    RZRob Long timer
    Dec 18, 2008
    1,950
    Anaheim Hills, CA
    I was considering that thought as well. Especially since I've drilled it as large as I have.
    RZ Rob
    #10
  11. RZRob
    RZRob Long timer
    Dec 18, 2008
    1,950
    Anaheim Hills, CA
    Do tell. I'm interested in details about this.
    RZ Rob
    #11
  12. brianbrannon
    brianbrannon They'll ride up with wear
    Dec 15, 2009
    2,446
    Denver, CO
    Nope. Broken and bent those bolts with the side stand relo kit.
    #12
    comradecasey likes this.
  13. RZRob
    RZRob Long timer
    Dec 18, 2008
    1,950
    Anaheim Hills, CA
    I’m happy to report I was able to drill out the bolt then use a chisel and didn’t harm the threads. I’m back in action. Thanks for the help everyone.
    RZ Rob
    #13
  14. touil
    Jan 3, 2017
    233
    Curius.For me, this assembly stay very ridgid since 4 year. Sometime, i have 60 lbs of laugage plus my wife when motorcycle is on double stand. I reguliary use my double stand without any issue. Do you use the hardware include in the kit. All bolt are 10.8 mpa and do the job for me. Good day
    #14
  15. brianbrannon
    Dec 15, 2009
    2,446
    Denver, CO
    I ride it off road and bash it into rocks
    #15
    RZRob, miken0vf and nk14zp like this.
  16. touil
    Jan 3, 2017
    233
    Ah ok. For myself i ride on pavement on gravel road and sometime on tigh trail but never hit rock. Beer.
    #16
