12,000 Mile service
Discussion in 'Parallel Universe' started by johnparjr, Jul 1, 2011.
  1. johnparjr
    johnparjr Been here awhile
    Mar 7, 2010
    270
    Somewhere
    Dam $545 for the 12K service they charged me $48 bucks just to take my bash guard off:eek1 and another $25 to inspect my K&N Air filter:huh but other than that my valves where good.
  2. Apostolos
    Apostolos Been here awhile
    Feb 26, 2010
    391
    The Sierras
    I just had my 12k mile service done a few weeks ago and was charged around 300 dollars. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
    <o:p></o:p>
    Of course I did my own oil and filter change, and brake fluid flush as well (brake fluid is not part of the 12k mile service). <o:p></o:p>
    <o:p></o:p>
    All your fluid changes (brake, oil, coolant, etc.,) can be done at home and that will save you money. Also, most of the inspections can be done at home as well. <o:p></o:p>
    <o:p></o:p>
    When I called for the 12k mile serves, I just asked how much it was to have the valves checked. The rest of the service I can do in my garage. Why would I need to pay the dealership to check my clutch or throttle free play, or inspect the brakes, etc.,? I ride my bike every day. Those are things I'm constantly inspecting. If they want to check them for free, that's fine, but I want to know if any adjustments at all are made.
    <o:p></o:p>
    So they charged me 2 hours labor for the valve check (I think it's around 90 an hour labor), around 70+ for the gaskets, and I can't remember how much for a new air filter (however, the old one looked fine), then tax on top of that. Of course they also hooked it up to the computer and checked fault codes.
    <o:p></o:p>
    If I remember correctly, it was around 300 and some change out the door. My valves were in spec.
    <o:p>If you want to save money, learn to do as much basic maintenance as you can. I actually find it enjoyable and part of the motorcycle experience. <o:p></o:p>
    <o:p></o:p>
    God Bless,<o:p></o:p>
    David</o:p>
  3. Bayner
    Bayner Long timer
    Mar 27, 2008
    2,429
    Penticton, BC, Canada
    Wow, that's like $5 per bolt. They must have a really steep hourly rate or be really slow with a ratchet!!
  4. johngil
    johngil Reseda, CA
    Jun 28, 2007
    3,818
    Was it a BMW plate?
  5. Wolfgang55
    Wolfgang55 Long timer
    Dec 24, 2006
    4,376
    Only N flowin river emptying in an ocean
    Shut the fuck up & buy the service CD here.
    Host a tech day.
    That boxer motor is easy to do service on & you'll save so much time & $$$ you'll be getting more chrome shit for your harley in the back yard.
  6. Bayner
    Bayner Long timer
    Mar 27, 2008
    2,429
    Hey 55, pass that good shit you've been smoking.
    :bmwrider
    Might want to take some adult literacy classes while you're at it.
    JeepDawg likes this.
  7. Emperor Norton
    Emperor Norton Kilroy was here
    Jul 2, 2010
    1,346
    North of Alcatraz
    Are you really that ignorant or is this a bad case of PUI?:freaky
  8. The Griz
    The Griz Long timer Supporter
    Nov 26, 2008
    3,905
    Earth
    You got raped. $545 is ridiculous. My dealer is going to charge me $245 for the 12,000 mile service.
    #8
  9. Apostolos
    Feb 26, 2010
    391
    The Sierras
    I just found my repair order invoice from my 12k mile service.
    I was charged:
    $221.00---for the valve check (no adjustment needed)
    $68.97---for the valve cover gasket set
    $18.84---for the air filter
    Total Cost---$308.81
    God Bless,
    David
    #9
  10. itsatdm
    itsatdm Long timer
    Jun 19, 2004
    5,440
    Nor Ca.
    Maybe you did get screwed. Found my bill: Valve check, oil change w/filter, 2 gaskets and air filter $340. Brake flush and a couple of washers. $85 and 1 feed pipe $32. Have no idea what that is unless associated with the fuel tank swap. Total $ 472
    So what did you have done. Should be itemized.
    #10
  11. johnparjr
    Mar 7, 2010
    270
    Somewhere
    Ill post my invoice once I find it I misplaced it
    #11
  12. johnparjr
    Mar 7, 2010
    270
    Somewhere
    Oil Change $18.79
    Crush washer $1.00
    Chemicles and Cleaners $5.00
    Spark Plugs $18.20
    Gasket Cylinder Head $68.97
    Parts Subtotal $111.96
    Labor
    Inspection 1 $81.48
    Oil & Filter Change $27.16
    Check Valves $135.80
    Ck/replace air filter $13.58
    Change Brake fluid $95.06
    Remove and Re install skid plate $48.50
    Clean K&N Air filter $18.43
    Labor Subtotal $420.01
    Stuff listed as no charge
    Ck Coolant
    Ck Brakes
    Ck brake lines
    Ck Spoke tension
    Ck Tire pressure & Depth
    Ck & Lube chain and tension
    Ck Side stand and Center stand
    Ck Head Bearing
    Ck Battery Charge
    I know there are a few things I could have done myself and I usually do but I have always had a dealer do the first major service and in a previous question my bash plate is not BMW
    #12
  13. JustBob
    JustBob Uh...who me? Supporter
    Dec 30, 2004
    1,120
    Young Harris, GA
    BMW Atlanta blessed me with a $460.90 bill for the 12K service. I had already done the oil/filter change. 4 hours at $86/hr. All the valves were in spec.
    #13
  14. johnparjr
    Mar 7, 2010
    270
    Somewhere
    That would be pretty close then to what I paid add $40 for the oil change and $50 for taking off the bash plate your cost then is about the same.
    #14
  15. rediRrakaD
    rediRrakaD Whoopdie do Supporter
    Jan 14, 2006
    1,503
    Deep in the Redwoods
    Since I'm close to 12k anyway...
    Got a quote from CalBMW (Mountain View,CA) yesterday,
    This includes the whole enchilada, (no home wrenching)
    Labor $335
    Parts $165
    Valve adjust, if needed $111
    Financial pain of owning one of these beauties... priceless :lol3.
    Cheers,
    S.
    #15
  16. Maniac28
    Maniac28 Journalist
    Apr 2, 2004
    496
    California
    One of the reasons I bought the BMW is that it's easy to work on. The 12k mile service is super easy. Anyone with a garage, a few tools, and a manual can do it. Why get raped at the dealer? And BTW, you don't need a new valve cover gasket. Just use a little sealant when you re-install, and it won't leak anymore.
    People bitch about the perceived high cost of owning a german bike or whatever. I call BS. I've spent less time and money keeping this bike going than I did any of my KLR's. Only time my GS has seen a dealer is for a warranty replacement of the rear wheel bearing.
    #16
  17. rediRrakaD
    Jan 14, 2006
    1,503
    Agreed, but...
    How do you reset the computer???
    S.
    #17
  18. tempeturtle
    tempeturtle Adventurer
    Oct 3, 2007
    40
    Tempe, AZ
    I broke down and bought the GS911. It lets me reset and set new service intervals. The one I purchased has blue tooth capability and works with my droid cell phone along with a usb connection for the laptop. Over the life of the bike it is a reasonably priced tool at around $300 and if you have other BMWs you can use it on them also. It works on my R1100R with an adapter.
    #18
  19. Dexxxedout
    Dexxxedout Adventurer
    Aug 14, 2017
    15
    So I just want to jump on and see what some guys are paying for the 12K service now. I called over to the local dealer and they fired back an estimate of $900.00. For a service that seems outrageous. They didn't even offer to throw in a bottle of lube!
    #19
  20. Tewster2
    Tewster2 Long timer Supporter
    Jun 17, 2011
    7,868
    DeLand Flatistan
    The 12k service for my 2017 F700 GS cost me $169....gallon of Motrex 15/50 ($50), oil filter ($10), valve cover gasket and bolt kit ($109). I learned from others here how to simply take the valve cover off and slide some feeler gauges in. Super easy because all valves were well in spec. My dealer said if any of the valves needed adjustment to bring the bike over stripped down and they'd change the shims and let me put it back together. Other fluids are easy to check.
    Many thanks to the folks here that post how to's. Has saved me TONS of money.
    #20
    amecr1200gs and shuswap1 like this.
