1200GS Injectors in the 1100GS and 1150GS... Vrooom!
Discussion in 'GS Boxers' started by RFK, Oct 17, 2016.
  1. Bee-rock
    Bee-rock Adventurer
    Mar 31, 2020
    18
    NJ
    Hi Roger I messaged you check your PM's need advice or to point me in the right direction
  2. CrustyAPO
    CrustyAPO Long timer Super Supporter
    May 7, 2008
    3,350
    New York state (unfortunately)
  3. Vinz Klortho
    Vinz Klortho Square Peg
    Nov 11, 2014
    1,146
    Fort Worth
    My injectors are lost according to the DHL website. Last know location was Omaha, Nebraska.
    Omaha?
    Frankfurt to Omaha?
  4. Mikeyfromgr
    Mikeyfromgr Been here awhile Supporter
    Oct 29, 2016
    327
    Somewhat off topic, but what is the most precise carb balancing tool aside from the harmonizer? Not having a balance is all that's holding me back from installing the 1200 injectors...
  5. NoiZboy
    NoiZboy Dirt to Track and Back Again
    Dec 24, 2012
    605
    Northern, VA
    I used a Twinmax on my R115GSA and it worked well. I know it's not as precise as you might be looking for, but the Twinmax has worked fine for me as long as the 9V battery is good and the unit itself isn't physically abused. Unfortunately theoptions are a little thin these days. A tall, homemade manometer might be your best bet tbh. Select an oil weight for ease of reading and the damping of your choice, make it tall enough to allow for 18" or higher columns and you'll have a pretty precise read on balance.
  6. Wandergives
    Wandergives Been here awhile
    Dec 22, 2015
    515
    NY
    Pretty sure the ones people make for like $10 are pretty accurate. I splurged and bought one of these cause I like cool tools. It’s magnetic and sticks to the tank. Simple to use. Not cheap though.
    rg sw wa. likes this.
  7. Vinz Klortho
    Nov 11, 2014
    1,146
    Fort Worth
    I had a Twinmax. I kept reading articles and posts about inexpensive, homemade manometers so I whipped one up. I was dumbfounded by how much better my bike ran after using it first time.
    rg sw wa. and NoiZboy like this.
  8. Vinz Klortho
    Nov 11, 2014
    1,146
    Fort Worth
    Well Herr Postman just delivered my injectors! How do you say YeeeHaaaw in German?
    ETA: Quick road test. Idle is smoother, Bike feels peppier. Feels like it winds up quicker but my seat-of-the-pants dyno may not be the most accurate means of collecting data. I need to read thru this thread again and figure out what I'm going to do with my AFXIED but I like it so far. Tomorrow I'll rebalance the TB's but idle speed is still right on the money.
  9. Vinz Klortho
    Nov 11, 2014
    1,146
    Fort Worth
    Remember that fable about the old cobbler? The gnomes or elves or whatever the hell they were would sneak in to his shop while he slept and fix all the shoes, right?
    Well those little bastards stuck a gixxer engine in my GS last night.
    Those injectors have transformed my bike! Wow!
    Yellow Dog likes this.
  10. NoiZboy
    Dec 24, 2012
    605
    Northern, VA
    I felt the same way once I had both AFXIED & the injectors running. It was a HUGE improvement that lasted. Glad you're happy with it!
  11. vagueout
    vagueout Long timer
    Mar 3, 2010
    4,457
    sydney, east
    Google up home made manometer, it's just a long piece of timber, length of clear tubing and a light engine oil. Its as accurate as any machine and as long as no leaks virtually fail proof. I have a set of gages for over thirty years, have used mercury tubes, and a Twin Max, i prefer the home made item.:*sip*
    Vinz Klortho likes this.
  12. Mikeyfromgr
    Oct 29, 2016
    327
    Does the digisync need adapters for the 1000 throttle bodies? I cant tell fron the pics and want to order everything at once...
  13. Wandergives
    Dec 22, 2015
    515
    NY
    Don’t think so. They were not needed on my 1150. Just plugged straight into the throttle body after removing vacuum hose.
  14. Vinz Klortho
    Nov 11, 2014
    1,146
    Fort Worth
    Anyone know if he does injectors for KTMs?
  15. Jodon
    Jodon Been here awhile
    Jun 3, 2014
    166
    Los Angeles
    Hi all, I'm 10 pages in on this thread and see there are 33 more, which I will get through, but eager to get my new injectors in and ride, and have spent the last hour on google, tills.de and injector-rehab, but still don't know exactly what I need adapter wise.
    I've got a '98 R1100R, and have these injectors:
  16. GS Addict
    GS Addict Pepperfool Supporter
    Sep 24, 2006
    7,370
    Sunshine Coast B.C.
    That looks like an 1150/1100S injector - are you sure that is yours?
    Below is a typical 1100 injector
  17. GroceryRun
    GroceryRun Been here awhile
    May 4, 2010
    256
    Central NJ , USA
    Jodon :
    Just like "GS ADDICT" says, you do not want to get this wrong.
    There are two different kits.
    Can you double check or take a photo.
  18. Jodon
    Jun 3, 2014
    166
    Los Angeles
    So I've already gotten it wrong, as the one pictured n my post is what I have, the one in the reply is what is on the bike.
    But, I would think they would work if I can make them fit, no?
    Perhaps with this:
  19. GS Addict
    Sep 24, 2006
    7,370
    Sunshine Coast B.C.
    Why not just order the correct matched set kit?
    lewisjr1 likes this.
  20. Jodon
    Jun 3, 2014
    166
    Los Angeles
    I erred.
