1. ADVRIDER Print Magazine!
    We're doing two more print magazines this year. July & November. 144 pages of high quality adventure riding stories, photography and interviews!
    Click here to purchase both for $35.
    Dismiss Notice
1200GS: New handlebar risers
Discussion in 'GS Boxers' started by GB, Jun 8, 2006.
  1. hshaw
    hshaw hank-went-thataway
    Apr 18, 2008
    9
    Topanga, CA
    Thanks, Jim. I ordered the Rox for the 08 GS. I'll post the results after delivery and install.
    #81
  2. hshaw
    Apr 18, 2008
    9
    Topanga, CA
    Okay, I got the Rox Risers and installed this morning in 15 minutes prior to riding to work. They perform as advertised. No problems with the cables. Next: winglets. Let the farkelizing begin...
    #82
  3. nharrisn
    nharrisn Adventurer
    Jul 22, 2007
    37
    I have ordered the new Verholen risers for the 08, check them out here
    http://www.mv-motorrad.de/lshop,shopstart,3275,e,1213925170-3275,,,,,.htm
    #83
  4. pavement pounder
    pavement pounder The road to Paradise is "UN-Paved"
    Mar 22, 2008
    745
    East Coast Canada N46.313282,-64.598851
    I just got the rox, not a sexy as some of the others but work well. Brake hose a little snug when you turn right so i snipped the zip tie part way down the frame and pushed the "clutch lever, mirror bracket" towards the right about 1/4". it is fine now but just barely. I wasn't conviced that they were very easy to install untill i realized that BMW made the clamps in such a way that you dont need to be able to access the small bolts to tighten the risers to the bike. (ok maybe not but...)
    I now have two pillows behind me when i go riding with my wife! (nudge nudge wink wink)
    ...and she can see over my head better now too.
    Big ride coming up next week. I will post if the shoulder fatigue issue i had with stock setup is resolved.
    Also, droping the windshield a bit helps resolve neck burn.
    #84
  5. JimVonBaden
    Feb 11, 2005
    95,287
    Alexandria, VA
    If you move the hoses and wires behind the trippletree you will get a lot more freedome of movement from them.
    For half the price of others, I will go with less sexy, especially on a GS!:deal :D
    Jim :brow
    #85
  6. paulsgs
    paulsgs Been here awhile
    May 5, 2008
    143
    NY, NY
    Ok I have an 08 GS. The Rox installed w/o a problem with the cables? Did you have to disconnect any of the cables?
    #86
  7. mrmurph
    mrmurph Been here awhile
    May 29, 2008
    369
    Marietta, Ga & Edisto Beach, SC
    Did we ever get an answer as to whether the BMW tank bag will still fit with either the Adventurersworkshop or Rox risers? I'm talking about the front hook that goes under the stock handlebar mounts....
    #87
  8. P7M13_user
    P7M13_user Been here awhile
    Nov 26, 2007
    100
    SLC, UT
    +1 :lurk
    #88
  9. mrmurph
    May 29, 2008
    369
    Bump
    #89
  10. hshaw
    Apr 18, 2008
    9
    Topanga, CA
    Nope. No problem with the cables after install. I tend to worry more about the throttle cable getting pulled. After I installed the Rox, I fired the beast up and turned the bars in each direction to see if I got a higher rev (this happened when I put risers on my F 650 GS). But not this time.
    Ride comfort has improved greatly and I like the fact that the Rox is easily adjustable.
    No, it's not as pretty as some other systems but the price was better than the other options -- and if I wanted beauty I'd fiddle with an RT.
    #90
  11. pavement pounder
    Mar 22, 2008
    745
    Well as promised,
    Just got in from 3000 km trip over one week. with rox, no neck burn at all. Never once. really like them. I wont take them off now.
    as for the hoses being tight... i found a zip tie on the left side for the clutch, if you move it towards the tank about 3 to 4 inches, it gives you all the slack you need.
    no probs
    #91
  12. carternick79
    carternick79 Cami's Dad
    Mar 27, 2008
    262
    Georgia
    Has anyone painted the AWS risers???? I am looking into buying the 65mm version but I am not liking the shiny metal look. I want it black...
    #92
  13. Sasquatch2112
    Sasquatch2112 Old Angry White Guy (OAWG)
    Sep 9, 2007
    11,519
    USA
    What about risers that go up and forward? With a 39" sleeve I need as much forward as I can get. At 6'6" I need a couple of inches of lift also.:huh
    #93
  14. JimVonBaden
    Feb 11, 2005
    95,287
    Alexandria, VA
    That is the beauty of the ROX risers, they go up and any direction you like.
    Jim :brow
    #94
  15. Sasquatch2112
    Sep 9, 2007
    11,519
    USA
    I had read here that some folks were having issues with getting them tight enough so that they wouldn't slip. The thought of them moving makes me nervous.
    #95
  16. carternick79
    Mar 27, 2008
    262
    Georgia
    Okay so I just put my new 65mm AWS risers on my 07' GSA after I sent them off for powder coating. Man do I love these things!!! The only things is that I can't mount my factory fog light switch in between the risers. For some reason my risers have two pre drilled and threaded holes in the risers. What are these for? They are just a bit to big for the factory riser bolts to go in which is where the fog light switch attaches.
    Does anyone know what these are for???
    #96
  17. paulsgs
    May 5, 2008
    143
    NY, NY
    One last question, which size ROX did you buy (if there are different sizes) ?
    #97
  18. Hotspice
    Hotspice Satellites not acquired Supporter
    May 17, 2004
    5,550
    Snow-Bound
    For your 1200 you'll want 1 1/8 .
    #98
  19. GSTed
    GSTed Been here awhile
    Apr 16, 2007
    239
    San Diego, California
    Holes are there to put Ram ball mounts in.
    #99
  20. carternick79
    Mar 27, 2008
    262
    Georgia
    Okay guys,
    I didn't want to put my factiry fog light switch on my handle bars like I have seen some do after I got my 65mm AWS bar risers for my 07' GSA.
    It just so happens that the new style risers have a 3/8 x 16 bolt holes to allow for 2 "RAM mounts" to be mounted into them but the spacing is spot on for the factory fog light switch braket to mount there as well.
    So off to my local home depot I went, I picked up two 3/8 x 16 stainless steel bolts and went to Grainger and ordered the tap and a drill bit. The next day my drill and tap arrived so I drilled and tapped the heads of each of the 3/8 bolts. I used a bit of Blue Loctite to secure the bolts to the bar riser cap. I then placed my fog light switch on the bolt heads and used teh factory screws to secure them on to the bolts.. And there you have it a factory looking job... :D On a side note if you have your risers powdercoated or painted make sure and chase the holes with a thread chaser or have who ever is doing the painting or powdercoating cap the holes. It will make things go much smoother. I had mine powder coated black but the plugged all the holes before shooting so mine was good to go...
    Tools Used:
    Drill Bit: 4.20mm
    Tap: 5mm x 0.8
    (2) Bolts: 3/8 x 16
