1200GSW Fixed Fork Tube Issues & Recall Threadfest
Discussion in 'GS Boxers' started by chef_of_the_future, Nov 4, 2016.
  1. chef_of_the_future
    chef_of_the_future Currently reading the Pepperwood Chronicals
    May 10, 2006
    349
    Here I go again - first recall on 2016 GSA (clutch slave) which I didn't even know about till I brought it in for the 1 year/6000 mile service. Then I get the dreaded "somethings broke" call from service department. The crimping on the upper stanchion is bad and failed. According to tech when the test rode after service they were shocked that it occurred because it's very dangerous. So now parts are ordered and blah blah don't get bike back for several days..
    So help me out. - what is this issue, anyone ever had it happen and what could have happened? I googled the stanchion on fiche but did not note an upper and lower nor a crimp.
    tramp likes this.
  2. Loutre
    Loutre Cosmopolitan Adv Super Moderator
    Nov 28, 2010
    14,136
    :o)
    who cares what could have happened. your bike is being fixed under warranty as we speak. hope you got a loaner for the time being.
    Phillyb and Roadscum like this.
  3. chef_of_the_future
    May 10, 2006
    349
    You are right - that's water under the bridge. I am more looking to be educated on what the upper stanchion crimping is, how it works, how it could have failed etc.
    Loutre likes this.
  4. Brokein2
    Brokein2 Long timer
    Feb 17, 2010
    1,192
    Morton, Wa
    Upper stanchion crimps... (now we have all heard of one failing)
  5. gr8ridn
    gr8ridn Been here awhile
    Jun 13, 2009
    500
    Kern River Valley, CA
    Interesting, I recall a similar recall on the very first 1200 GSWs in 2013. Seems the Canadians caught the issue after a few were already on the road. All of the early GSWs were recalled for the mod involving a special tool sent to the dealers.
    Your dealer is right, if the cast upper piece separated from the steel tube you would loose steering control. In this case your dealer did good in spotting the impending issue. This is the first case I have heard of since the introduction of the GSW in 2013.
    Everyone should pull the rubber boot down to insure the fork tube is tightly fitted the the cast aluminum cap. That cap is what locates the top the tube to the upper tree through a spherical bearing.
  6. chef_of_the_future
    May 10, 2006
    349
    Thanks Broke! Mystery solved- for me anyway.
    Glad the tech found it at service time and not me finding it hitting a pot hole on highway!
    ed_hale likes this.
  7. wired2008
    wired2008 n00b
    Nov 14, 2010
    7
    Two week ago I took the my new GSA 2016 from the BMW dealer and on my way home I drove over a street pothole. Both inner fork tubes deformed and bent.
    Did anyone had this problem ?
    I asked the BMW dealer for the guarantee and they told me BMW said I should repare it (pay for it) before they look at the broken parts.
    El Chorizo likes this.
  8. krellheat
    krellheat Milk Crate Challenged
    Nov 13, 2007
    2,969
    Pipestave Swamp, CT
    No. The dealer and BMW are going to want to figure out why the forks failed.
    #8
    Bruz and jwaller like this.
  9. CJ3Flyer
    CJ3Flyer Long timer Supporter
    Jun 22, 2014
    1,827
    Acworth GA
    Yikes!!!
    Obviously, look the bike over pretty good. I'd really focus on the front rim. A hit that hard would have to damage the rim I would think unless there's some real defect in the forks.
    #9
    NMS24 likes this.
  10. bemiiten
    bemiiten League of Adventures
    Jul 10, 2003
    5,737
    Hamilton NJ.
    Looks like the rubber cover is dislodged, but I don't see what is broken.
    #10
    jwaller likes this.
  11. nobody0101
    nobody0101 Been here awhile
    Jun 16, 2015
    975
    Michigan
    Is the fork tube split?
    #11
  12. WVhillbilly
    WVhillbilly Long timer
    Oct 20, 2010
    40,345
    WV
    :eek7
    #12
  13. Zevulun
    Zevulun Been here awhile
    Apr 15, 2015
    130
    Celebration FL
    #13
  14. Zevulun
    Apr 15, 2015
    130
    Celebration FL
    Can someone please explain to me why BMW chose to engineer an upper fork tube this way with an outer sleeve, why not a one piece fork tube that inserts into a triple clamp like 99% of motorcycles. I have a 2017 GSA Triple Black coming in, seeing a failure like this for a bike this expensive is a bit perplexing.
    #14
  15. ElMartillo
    ElMartillo I See Faces...
    Sep 18, 2009
    969
    Nationwide, USA
    The telelever front suspension requires the top of the fork tubes pivot. On some other models they put a ball joint as the top central pivot point and used a traditional top triple clamp.
    #15
    GS Addict likes this.
  16. GS Addict
    GS Addict Pepperfool Supporter
    Sep 24, 2006
    7,874
    Sunshine Coast B.C.
    Like the 1100S & 1200S
    #16
  17. JimVonBaden
    Feb 11, 2005
    94,598
    Alexandria, VA
    We need a lot more detail. What were your riding conditions, and your location? I am guessing NZ or AUS.
    #17
  18. Zevulun
    Apr 15, 2015
    130
    Celebration FL
    #18
  19. Greg J
    Greg J Rocky Creek Supporter
    Oct 21, 2005
    19
    Dunoon, Australia
    I was on a ride in SA in September with a group. Day 11 one of our guys went down. He is an extremely good rider. Travelling on a dead straight road, speed between 120 and 140KPH. He claims the front end just fell away and he went down. There was NOTHING to hit on the road and NO potholes. The bike slide for 100 plus meters and came to rest on the side of the road. He was OK except for a couple of scratches and some bruising...very lucky boy. He was adamant the frontend just collapsed on him and tucked under the bike. I believe BMW SA engineer was called in to investigate. I haven’t heard the out come of the investigation.
    #19
  20. Hay Ewe
    Hay Ewe Just a Wannabe
    Jul 17, 2005
    7,013
    FNQ - AUS
    Fark!
    #20
