1200GSW Fixed Fork Tube Issues & Recall Threadfest
Discussion in 'GS Boxers' started by chef_of_the_future, Nov 4, 2016.
  1. GroceryRun
    GroceryRun Been here awhile
    May 4, 2010
    227
    Central NJ , USA
    Found fiche for R1200GSW ADV 14-15 (K51) so not sure if same bike.
    Is it part number 1 that has the crimps on this Stanchion diagram ?
    Is the black tubular thing part number 4 ?
    #41
  2. GroceryRun
    May 4, 2010
    227
    Central NJ , USA
    R1200GSW ADV 14-15 (K51).
    Fiche of Upper Fork Cross Brace.
    #42
  3. GroceryRun
    May 4, 2010
    227
    Central NJ , USA
    I guess what we are saying is that the top assembly (where the #3 is pointing at of the Stanchion diagram ) is separating from the Stanchion ( can I call it an inner fork tube ? ) ? I am assuming that the top assembly is held on by the visual crimps some how.
    Can I also assume the Stanchion is held into the Upper Fork Cross Brace by the what looks like a threaded rod of the Stanchion top assembly , thru part #2 (Upper Fork Cross Brace fiche, joint link ) and held on by part #7 ( Upper Fork Cross Brace fiche , hex nut ) ?
    #43
  4. Zevulun
    Zevulun Been here awhile
    Apr 15, 2015
    130
    Celebration FL
    I'm curious how many inmates that have bikes on order will seriously reconsider.
    #44
  5. Trixie
    Trixie Adventurer in my own mind
    Jul 19, 2001
    5,039
    Central MA
    My '15 GSAW has what looks to be a set screw that angles inward from the cap. Design change, or different spec for Adv models?
    #45
  6. GS Addict
    GS Addict Pepperfool
    Sep 24, 2006
    6,309
    Sunshine Coast B.C.
    Its a great design IMO
    I have yet to see an oilhead or hexhead do this....
    I wonder if all the pursuit of making things lighter has shown the new weakness.
    #46
    SmittyBlackstone likes this.
  7. miker325
    miker325 Been here awhile
    Sep 9, 2015
    585
    Sonoma County, CA
    Checked my '15 and found no gap at the top of the tube, where it snugs against the top assembly. It too has the set screw Trixie mentions above, but I couldn't say for sure what that screw does because my repair manual DVD is in my office at work.
    #47
  8. Trixie
    Jul 19, 2001
    5,039
    Central MA
    It looks like the tiny screws are just vents.
    (+) Venting fork legs
    (-) Venting fork legs
    Remove threaded plugs (1).
    Dispose of O-rings (2) in the appropriate manner.
    Install threaded plugs (1) with new O-rings (2).
    [​IMG] Tightening torques
    Sealing screw in fork plug
    M4 x 8, Replace O-ring
    2.5 Nm
    #48
  9. nobody0101
    nobody0101 Been here awhile
    Jun 16, 2015
    912
    Michigan
    Concerning for sure, but have to keep in mind the fact that basically all other bikes have had no problems.
    Will probably be fine just as on the other 99.9% of bikes in use.
    #49
  10. Trixie
    Jul 19, 2001
    5,039
    Central MA
    The fixed fork tube (inner) as it is called, doesn't seem to be serviceable, from what I've searched on the repair manual. There are a number of bushings and seals on the fork slider, but no springs or any other items inside, save for some oil for slide lubrication.
    #50
  11. miker325
    Sep 9, 2015
    585
    Sonoma County, CA
    Couldn't load the photos, Trixie. Might be my computer, but can you reload and try again?
    #51
  12. rider1150gsadv
    rider1150gsadv Long timer
    Oct 6, 2003
    6,855
    Ft Likkertail , USA
    I'm sure it'll be taken care of by the mothership but I'd hate to be the one stuck in BFE with a busted bike like that. I would have though that by now BMW would have their sh^t together for the most part..:arg
    #52
    cide1 likes this.
  13. ragtoplvr
    ragtoplvr Long timer
    Oct 18, 2007
    9,253
    central USA
    Report any failure to the NHSTA web site. They seem to be aware of some issues, if a few more are reported along with Photos etc they will force a recall.
    The life you save may be your own.
    Rod
    #53
  14. Trixie
    Jul 19, 2001
    5,039
    Central MA
    That's weird, they were up for some time, now they are gone.
    try again:
    Core activity
    (+) Removing fixed fork tube
    (-) Removing fixed fork tube
    Remove protective cap (1).
    Remove bleed screw (2) with O-ring (3).
    Carefully pull fixed fork tube (4) out of slider tube (5) and catch escaping oil.
    ATTENTION
    Slackening the threaded fastener in the quick-release axle bore of the slider tube.
    Causes permanent leakage of the slider tube.
    Do not slacken the threaded fastener in the quick-release axle bore of the slider tube.
    Turn slider tube (5) upside down and drain out the oil.
    Carefully pry out sealing boot (1).
    Remove circlip (2).
    Remove radial shaft sealing ring (3) with internal puller (No. 00 8 561), thread adapter (No. 00 8 564), pull rod (No. 13 5 251) and impact weight (No. 13 5 253).
    #54
  15. WVhillbilly
    WVhillbilly Long timer
    Oct 20, 2010
    32,716
    WV
  16. Mainecoons
    Mainecoons Been here awhile
    Feb 18, 2014
    306
    Beautiful Lake Chapala, Jalisco
    Can't see the photos.
    Thanks.
    #56
    JimVonBaden likes this.
  17. JimVonBaden
    Feb 11, 2005
    78,675
    Alexandria, VA
    Two or three people are posting on several threads about the same "potential" situation. Seems like an isolated incident blown out of proportion, with the flames fanned by a few new posters.
    #57
    Mav, Pch123, Callisto224 and 3 others like this.
  18. dnrobertson
    dnrobertson Big Bike, Slow Rider
    Jun 30, 2008
    1,281
    Frankston, Australia
    Trixie, you need to put the photos on a picture hosting site and past the URL. At the moment the URL is pointing to your local computer. if your URL has http://127.0.0.1 as part of the address, nobody but you will see them.
    #58
  19. Duane1969
    Duane1969 Been here awhile
    Jan 7, 2008
    418
    Little Rock, AR USA
    What he said!!!!!!!!!
    #59
  20. Bundi
    Bundi Adventurer
    Oct 21, 2005
    10
    Dunoon, Australia
    Sorry, been busy all day and only look at my computer in the evening. We left SA for home two days after the tour so I don’t know what the BMW engineer had to report OR if he turned up. I will try to contact the guy who had the crash and see if he has any news. He lives in the US so probably won’t hear until tomorrow same time.
    I walked back over 100 meters from where the bike ended up and looked for a pothole or rock…anything! Found nothing on the road AND the road was dead straight. I was the second one on the scene, his riding mate had just got to him before I arrived. They were both a little shocked. He kept saying, “The front just collapsed and folded under me…never happened to me before”. I have no reason not be believe him. If you are going to make some BS story up it's not going to be that one.
    As I mentioned before he is a gun rider. Prior to this the bike had not been dropped. It had been ridden hard and fast but not abused. No other bikes on the trip had any such problems. We ALL checked the fork tops for oil before proceeding!
    If I hear from him I will post again.
    #60
    mtopham likes this.
