    Dismiss Notice
14 650Wee build...RTW focused!
Discussion in 'Japanese polycylindered adventure bikes' started by Dalmatino, Aug 31, 2019.
  1. Dalmatino
    Dalmatino Been here awhile
    Nov 21, 2008
    669
    Prison Planet Earth
    I started this project a year ago but resisted posting the build because I figured it would drag out too long...my prediction was correct lol. So a fair warning it could be slow still.
    So after building a new 15 DL1000 (was a tossup between it or 650) with typical "add on everything but the kitchen sink" mantra and adding on at least 60lbs I realized it wasn't the way to go...neither with the 1000 or the gear. For me the extra power wasn't worth the extra weight but mostly wasn't the trade-off for much lighter, nimbler and smoother 650. So out the door it went and in came a used 14 DL650 with slight cosmetic damage for a very reasonable price. Perfect platform!
    Out with the new and porky!
    In with the old and skinny..er!
    The goal is to keep it as light as possible and prep it for RTW capability. Hopefully it well see SA within next year or so.
    I started by building a custom aluminum rear rack (getting rid of that plastic thing)!
    Hardly any more weight added but now I can load up the top box.
    Delkovic Exhaust was added primarily to save a good chunk of weight but more importantly to narrow down the right side which it did considerably!
    20180811_100635.jpg It sounds fantastic and is not loud at all...thank God because I want the bike as quite as possible!
    Now I had to do something about the boat anchor passenger pegs!
    SV650 was kind enough to donate it's :)
    Seat was done by Volker's out of Edmonton AB. He does great work!
    I've come to a realization that for me best scenario for luggage is a good lockable plastic top box and a set of Mosko Moto 80l soft paniers over the seat and that's it!
    I plan on a tool tube which is yet to be designed/made and basic small light side racks just to keep the bags sturdy and off the bodywork/exhaust.
    This is as far as I got last fall before cold, work and travel brought everything to a grinding holt.
    I got back last week and figured I better get at it quick before it starts all over again.
    Patiently waiting!
    TLR Race bike anyone? ;)
    So, I got at it and installed this kick ass top of the line TFX Adventure shock from TFX in Holland. It's a beauty! Thanks Hans!
    While I was there I took apart all the linkage and swing arm, cleaned and regressed everything.
    I had Too Trick racing (thanks Al) in BC install a complete Cogent package (thanks Rick) in the front forks. Also Swapping out the steering stem bearings for tapered ones and having the T-clamps powder coated satin black along with my tail rack and passenger peg setup.
    The complete header system is being ceramic coated in satin black also.
    Cleaned up the rotors and installed SS braded lines.
    Now a bit of a wait for the stuff to come back from coaters...hopefully by mid week.
    Also waiting on;
    520 sprockets and chain from sprocket specialists (15/49)
    Hyde bash plate
    Adaptor plates for sv1000 calipers
    Buell Ulysses foot pegs
    PCV
    Still to do;
    Install electrical stuff (heated grips, power outlets, auxiliary fuse box, extra led tail light etc.)
    Make tool tube
    Replace antifreeze and brake fluid
    Do the 24k valve check and check/sync the throttle bodies
    I'm sure there's few more things...
    Hope someone finds this somewhat interesting and/or informative lol
    I'll try my best to be prompt with updates as things happen.
    Cheers :beer
    v..
    orestis, dtysdalx2, Argus16 and 2 others like this.
  2. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    8,369
    I had 2015 wee which expired last November coming back from Mexico.. didn't make last 11mi lost fight to a deer. Had 73k at that point. Nice bike it would be fine as long as you are not planning to ride from Urique to Bata on it.
    You need to go through what you be carrying; weight in top case makes huge difference good luck.
  3. Motomantra
    Motomantra Registered Lurker
    Mar 6, 2008
    3,155
    Beaverton, OR
    Digital volt meter.
    dtysdalx2 likes this.
  4. Dalmatino
    Nov 21, 2008
    669
    Prison Planet Earth
    Hope you got through that well!
    What did you replace it with?
    I got ya regarding the weight in top case. I figure I need the top case for things that should be under the lock and soft bags just pick up and go.
    My idea of riding SA is a bit different. I plan on spending months at a time in same country living and exploring and slowly moving on. When I'll be living in an area for a while top box is there for every day use. At some point when I have to go back I'll just leave the bike and come back in few months to continue. This is why I chose the Wee versus say a DR650 for this trip. Comfortable, good for two up and 75% tarmac use. I don't plan on any real gnarly off road stuff.
    Fill me in on Urique to Bata?
  5. Dalmatino
    Nov 21, 2008
    669
    Prison Planet Earth
    Thanks Motomantra, got one in plan!
  6. cyclopathic
    Dec 23, 2007
    8,369
    It's technically a road 70km in Cooper canyon; last guy I know of who did it on wee did it in 11 hours and bent headers badly.
    It's dr650 territory.
  7. Greg the pole
    Greg the pole There are no stupid questions, only stupid people
    Mar 1, 2011
    2,292
    Calgary, AB
    @Dalmatino
    get rid of the front cast rim...softer than warm cheese. The spoked rims from the XT will be a slightly better choice. Failing that, bring a 19" tube and tools to swap in.
    We bent two of the two DL650s that came on the ID BDR...on the 1st day.
    Oh ya...call me when you get in...need to talk about that SV frontend..otherwise...carry on.
    you brought the thou back with you? or left it in the home state??
    BlueRidgeKat likes this.
  8. Dalmatino
    Nov 21, 2008
    669
    Prison Planet Earth
    It's got to be the riders lol.
    I'll be safe from bending any rims if I don't go on any rides with you guys :rofl
    We'll catch up soon..
    #8
  9. Greg the pole
    Mar 1, 2011
    2,292
    Calgary, AB
    Dammit man! Always blame the equipment!
    #9
  10. Dalmatino
    Nov 21, 2008
    669
    Prison Planet Earth
    Update with more progress in last week.
    Stuff came back from powder coaters, Hyde bash plate arrived plus the caliper adapters with new pads.
    Got busy with all that and had the valves checked and adjusted. Few exhaust valves ware on the tight side so shimmed accordingly.
    Threw in new plugs, air filter and water coolant.
    Powder coated top and bottom triple.
    Ceramic coated the whole header system and powder coated the passenger foot pegs.
    Wired in the PC5 and PC8 accessories fuse block along with the Oxford heated grip power wire..
    Hoping to have things pretty much together by end of this week if my 520 chain and custom sprockets from sprocket specialists come in.
    On a side note...Last week had an unexpected guest pop up and make itself at home.
    Says he wants a makeover too :-)
    Shit never ends lol..
    Build report https://advrider.com/f/threads/lord-yes-another-dr650-build.1414621/
    #10
  11. Dalmatino
    Nov 21, 2008
    669
    Prison Planet Earth
    A bit of an update.
    Bodywork back on but cant decide on the wind screen so haven't ordered one yet.
    I'm pretty happy with the stock one so I may just do a new tinted replacement.
    I'm also quite pleased with my custom rear rack and smaller much lighter SV foot peg mod.
    520 Sprockets and chain installed (15x49)
    Had the sprocket specialist make me a 49 tooth hard anodized aluminum rear sprocket.
    Could not get one in steel and I was bent on going up 2 teeth on the rear. Did not want a smaller sprocket in the front. At least 3 lbs off rotating mass gone with the whole conversion.
    Sv1000 caliper and master conversion with ss lines...lots of stopping power now :)
    And some more weight shaved off.
    The Hyde skid plate is nice and light and will do a pretty good job I think but not the craziest about the looks.
    But I want to keep this bike as light as possible. Looking forward in weighing the bike once all done! If 472lb stock wet weight is correct, I'm hoping to come in at least 15lbs less in this trim.
    We'll see lol..
    thumbnail_IMG_20191027_142618.jpg Is my ass slim lol..
    Delkovic exhaust is nice and tucked in keeping the bike as slim as possible which this and weight saving was the main reason for replacing the stock one.
    I cant say enough about this exhaust system especially the quality and quality of the sound without it being loud at all which was the icing on the cake.
    Bottom pic for reference of how much it tucked in.
    Next few more electrical things and so on but not having a heated work space time is running out.
    In the spring it will be dyno tuned to properly take advantage of the exhaust and air box changes.
    #11
  12. dtysdalx2
    dtysdalx2 Only a matter of time.
    Aug 1, 2004
    26,483
    Moneyapolis, MN
    Nice! I have some 4 pot SV calipers too but still haven't coughed up the $82 for the adapters. Did the Galfer lines though.
    Looks more like a hot rod than bullet proof bike. AMHIK :D
    #12
  13. Dalmatino
    Nov 21, 2008
    669
    Prison Planet Earth
    Lets go with the bullet proof hot rod lol...
    #13
  14. eakins
    eakins Butler Maps
    May 29, 2002
    36,885
    Fort Collins, Colorado
    #14
  15. eakins
    eakins Butler Maps
    May 29, 2002
    36,885
    I like the Givi airflow shield.
    Tucks down low when hot and you want air & goes up high when you need protection.
    Laminar airflow insures it does not bufett.
    #15
  16. eakins
    eakins Butler Maps
    May 29, 2002
    36,885
  17. eakins
    eakins Butler Maps
    May 29, 2002
    36,885
    Those SV footpegs look sharp on there.
    #17
  18. Dalmatino
    Nov 21, 2008
    669
    Prison Planet Earth
    Yea thank for the reminder eakins!
    Got a Mosfat for the DR so I'm gona get one for the DL too.
    Actually got the fender riser kit already and I will have a look at that windscreen...
    #18
    eakins likes this.
  19. aussie dubber
    aussie dubber Adventurer
    Oct 19, 2018
    44
    perth australia
    love builds like this gets me kind of motivated
    #19
  20. ECN-ROL
    ECN-ROL Been here awhile
    Jun 28, 2009
    206
    Ontario, Canada
    I've got a buddy who wants to know if you're interested in this 2005 gsxr1000. It's been garaged for quite a few years due to losing the ownership. But thinks you won't have a problem getting one.
    #20
