140/90/17 or 150/80/17 dual sport tires?
Discussion in 'Equipment' started by ChopperCharles, Aug 14, 2019.
  1. ChopperCharles
    ChopperCharles Long timer
    Jun 7, 2006
    4,617
    Durham, NC
    my bike comes stock with a 140/80/17. The speedo is off a bit and the gearing is a little too low, so I was thinking s slightly larger rear tire would fix that without having to replace expensive belts and pulleys. But... it doesn’t seem like dual sport tires are made in those sizes. Just street tires. Why is that?
    Charles.
  2. Panther6834
    Panther6834 Adventurer
    May 6, 2018
    82
    US
    First, you didn't specify what bike you're considering it for. I mention this because, most bikes have the Speedo sensor, & speed sensor rotor, attached to the front wheel...not the rear.
  3. ChopperCharles
    Jun 7, 2006
    4,617
    Durham, NC
    SCR950/Yamaha bolt. It’s similar to the R1 sensor which reads off the front sprocket. Except it reads off the front drive pulley. Stock rear tire is a 140/80/17. A 150/70/17 is also available, but is actually smaller in overall diameter.
    Charles.
